08-28-2018, 07:42 PM
#46
Real Name: Chris
Real Name: Chris
Originally Posted by Rapid_Amble
Audio noob here, highly challenged with electricity and electrical engineering: It looks like you're using a ~300Hz bass blocker on the positive wire. Does the blue OEM plug also have a bass blocker?
OEM capacitors are taken out of the equation however they are still glued in place. Really no reason to remove them completely and if for some unknown reason I ever wanted to go back to the stock tweeters, they're super simple to swap back. The 300hz capacitors I'm using with the new speakers are perfect for the 3.5" speaker.
08-28-2018, 07:48 PM
#47
Awesome, thanks.
08-28-2018, 07:52 PM
#48
Real Name: Victor
Real Name: Victor
Well I did it anyway!
Bought the Subaru Kicker tweeters and just put them in.
By far the easiest parts swap I have ever performed on this ride. Easier than the rear-wiper replacement for sure lol!
Sounds crisper as expected from new tweeters. I have aged into simpler needs on the audiophile scale and feel it is a noticeable improvement without much extra effort.
YMMV depending on level of audio wants.
Thanks again for the post
@ Soccer13
2015 Black 4Runner TRD Pro
Mild add-ons - Toytec 2" TRD lift kit w/SAW 1.5" rear spring, Nitto Ridge Grappler 285/70/17 C, 1/4" Aluminum RCI Metalworks Skids - All but the TRD Pro skid. FJToyman lower Rear shock mount skids. C4 Fab sliders. axle & eLocker breathers to ARB under hood, tinted front two windows, BajaRack Stealth with Spylight Sytem, Extreme LED 40" single row light-bar, Blacked out chrome on tailgate. Weathertech in-channel window vent visors and rear cargo mat, Paracord Headrest Grab Handles. H11 LED fogs and XenonDepot headlight kit. Interior LED swap.
08-29-2018, 11:27 AM
#49
Originally Posted by VT4RunnerSR5
@ SBCam
what speakers did you use in the doors? Need to spend some more money I don't have.
I went kicker 6x9's in the front and kicker 6's in the back. All in all the sound is very good. I also changed out my head u it for a pioneer 8200nex which I'm extremely happy with. Android auto and apple CarPlay !
08-29-2018, 02:49 PM
#50
lol yes I absolutely could but I would need the OEM tweeters so I could disassemble them and make the adaptors. I don't have a source for the OEM plugs. PM me and we'll talk.
FYI Tacotunes sells the adapter.
https://tacotunes.com/shop/toyota-4r...ter-connector/
25 bucks
SKU: A3-77-EZSH02-1
NOTE: NOT COMPATIBLE WITH FACTORY INSTALLED JBL AUDIO SYSTEMS.
08-29-2018, 04:38 PM
#51
It was $78 yesterday with the 15% Ebay coupoon
2018 SR5 Premium MGM
TRD Pro wheels
LT265/70/17C BFG KO2
08-29-2018, 05:27 PM
#52
Real Name: Chris
Real Name: Chris
Originally Posted by Mr_Assault
Yes I know but the OEM plug is free. If someone wanted help I would solder them up same as I did mine for a small fee to cover material cost and time.
08-30-2018, 01:56 AM
#53
Real Name: Tom
Real Name: Tom
Just installed the $92. Subaru tweeters from Amazon.
Made a big difference in clarity & fullness. Tweeked with my Kenwood’s graphic equalizer they sound pretty good.
Great 10 minute mod!
A white 2017 Off-road for me, and a Cement 2020 Tacoma Off Road for the wife.
08-30-2018, 06:26 PM
#54
I used the taco tunes adapters, tiny bit of pipe strap on each side, and 300Hz bass blockers to install Hertz DCX 87.3 3.5” speakers. Also had to trim the underside of the driver side grille to fit with the new speaker. It was a science project compared to the Subie tweeter upgrade but fun to do and the sound is crazy good!
08-30-2018, 06:40 PM
#55
Real Name: Chris
Real Name: Chris
You should trim that cone off both sides completely if you want the full benefit of the new speakers.
08-30-2018, 07:37 PM
#56
Once more into the breach then!
Also I may be headed down the rabbit hole. Starting to look at upgrading the door speakers and sound deadening. . .
08-30-2018, 07:58 PM
#57
Real Name: Chris
Real Name: Chris
Something like this?
08-30-2018, 09:24 PM
#58
Now that’s a project!
09-01-2018, 01:52 AM
#59
Just installed mine and wow, serious improvement!
Should’ve been ten minutes but apparently Toyota had Hercules install my passenger side speaker.
09-01-2018, 10:45 PM
#60
I just installed the Subaru Kicker tweeter that I got for $78.
It is amazing. It sounds more clear, crisp, and detailed. Well worth the upgrade.
TRD Pro wheels
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
