XenonDepot DRL PWM LED Driver Available for Pre-Order
XenonDepot
AVAILABLE FOR PRE-ORDER NOW!
Have you been wanting to upgrade your 9005 High Beam bulbs to LEDs, but didn't want to be "That Guy" with the DRLs that are basically just High Beams because your LEDs can't dim? Well, worry no more, the solution you've been waiting for is almost here!
XenonDepot has developed a new LED Driver for our Xtreme PRO 9005 LED Kits, which allows the LED Bulb to dim in DRL mode to something more suited for daytime driving. Best of all - you get absolutely no flickering in this new setup. That's right - you get a true High Beam/DRL combination, with bright white light in both modes.
The Xtreme PRO Daytime Running Light LED Driver is a simple, 1:1 replacement for the existing driver (and any CANBUS/anti-flicker components you currently have installed) if you already have one of our 9005 LED Kits. It can be used instead of the regular LED driver that comes with the kit if you are getting these lights for the first time.
Check out the video below for a look at the difference the new DRL LED Driver makes and how simple it is to switch out from an existing installation.
Will this new driver come as part of the hi-beam kit, for those of us that are buying the kit for the first time (not replacing an existing driver)? Or do we have to buy the $110 kit, and then another $60 for the correct driver?
This.
Looks like both parts (LED kit plus DRL Driver) - don't add the PWM - using LIGHTS10 code my order came to $152 until there is a new kit posted for us
YES :bravo:
Order placed - thanks for the pre-order info !
I presume you guys will ship the lights with the drivers then at the end of the month? I'll try to be patient :hungry:
awesome new option. I am running a different brand led 9005 in mine and it also doesn't flicker and doesn't run full high in DRL. It also doesn't have that ballast like box.
What brand?
Sent from my SM-N950U using Tapatalk
Pmed you. I know Xenon Depot is on here helping us out and not trying to hurt their business.
Too bad this wasn’t available a few weeks ago, I could’ve saved $30 on the PWM module. :ohwell: Oh well, guess I’m ordering one of these too.
Great timing. Should be getting my new LE in a few weeks. Just put the order in. Now I don't have to do the disable DRL while keeping auto headlight mod :)
Where do I sign up?
[MENTION=164260]MaddoxPics[/MENTION] - You may pre-order the DRL LED Driver here.
[MENTION=4941]druuu88[/MENTION] [MENTION=262927]Eriee[/MENTION] - No, the DRL LED Driver is sold separately from the 9005 Xtreme Pro LED Kit so you'll need to buy both.
[MENTION=138947]azknuckles[/MENTION] - The Xtreme Pro DRL LED Driver is not designed to work with any other products as it was only designed and tested with the Xtreme Pro LED kits.
[MENTION=145534]Heelflip131313[/MENTION] - No, the DRL LED Driver is sold separately. Also, the H11 low beam LED kits do not need this item.
[MENTION=146993]cheerup38[/MENTION] - Unfortunately, not as the connection style is different between the LED bulbs and driver on our previous generation LED kits. These will only work with the Xtreme Pro LED kits.
Danny
[MENTION=119442]tristero[/MENTION] - I can't say with 100% certainty, but if uses the same PWM DRL tech as the T4R it should work exactly the same :)
Steve
[MENTION=12905]XenonDepot[/MENTION] The 9005 Xtreme LED Pro Headlight Kit comes with a driver, I'm assuming the DRL driver replaces that. Any chance you'll offer 9005 Kit with just the DRL driver, would it change the cost?
Has anybody in here tried the DDM Tuning Saber LEDs for their DRL/High Beams?
Any issues with output or flickering? I might just go that route since I am local to them but want to know for sure if their product is good.
