Eibach, Ray 10s, and 285 KO2s Installed
After going back and forth I finally decided on the Eibach Pro Truck lift system based on the following.
  1. I realized most of my driving was going to be on road.
  2. I'm never going to adjust the height after its set, based on my previous experience with adjustable height suspension.
  3. I'm not going to be doing any sort of dessert running where I would need remote reservoirs.
  4. Price was right
  5. I didn't want a harsh ride, I wanted something similar to stock without the brake dive.
I couldn't be happier with the ride quality so far, I've only got about 100 miles on it as of right now. I'd say is slightly stiffer than the stock suspension, but not much and the brake dive is much improved.
For the wheels I went with the bronze Ray10s, timing happened to be right for me otherwise I wouldn't have played the supply and demand/hype marketing game. I decided to risk going with the 285/70/R17 KO2s and cross my fingers hoping they wouldn't rub... Well they did rub the front of the inner fender on both sides, just barely. I was able to push the fender liner up and screw it back down so it didn't rub. In reverse it was hitting the bottom of the bumper and the air dam. I marked these with 1" masking tape as a guide and trimmed them enough to not rub. I used a sharp box cutter, scored and cut through the painted bumper cleanly. I didn't want to use a rotary cut off wheel as they tend to melt the plastic.
In the sun:
Trimming:
Looks good. I've been looking at the Eibach pro truck lift for a while and considering going the same route. Doesn't seem like many run them so haven't been able to find a lot information. Interested in some updates as you put more miles on it.
Will do! I was skeptical as well due to lack of reviews.
Looks great! Did you go C or E load KO2s? E would make the ride a tad stiffer than C. Also any rubbing on the body mounts?
I have a feeling I will be doing this sooner rather than later. Can't help thinking that I'm driving a station wagon. My 96 Bronco only sits on 32's with no lift, but feels like it towers over the little 4Runner TRD premi.
Looking good, thank you for taking the time to share. Send us some photos (or tag us so we can find you) @eibach_world. Happy to share with our fans!
From the eibach site, front 2.75 and rear 1" of lift , but you still ran into issues with rubbing? May want to add your experience to the "Going Bigger" tire thread. In there it is suggested that 285/70/17 will fit with only moving the inner fender and removing mud flaps.
shocked you're not getting rubbing. i have 285 KO2 on Ray 10s and had to do fender liner, BMC and some bumper cover trimming.
have you had your alignment adjusted for the lift yet?
It was rubbing until I moved the fender liner forward and trimmed a small piece off of the bumper cover. I had the alignment done with it lifted on the stock tires and wheels. I don't think I have any rubbing on the body mount. I've read that you can have them adjust the caster to help, since it doesn't seem to be an issue at the moment I'm going to leave it as it.
I will, I don't know how the offset on the Ray10s compares to the stock wheels. They are wider.
I went with load range C since I didn't want the weight and stiffness of the E rated tire. The ride quality seems pretty good, however, it does feel noticeably slower even with the load range C tires, not terrible but noticeable. No rubbing on the body mounts so far that I've seen.
