2011 4Runner LED fog lights Upgrade possibilities
Garcia9876
I have a 2011 4runner Limited and problem would be my current fog light Oem has less visibility. If I upgrade with the 2019 4Runner Trd pro edition led fog light part or
81220-48051 Left (Japan)
81210-48051 Right (Japan)
Also, I need the headlight bulbs to match up what are the size?
Hi Garcia9876,
All your lights: 2010 thru 2013 4Runner light bulb list
Low Beam Head Light Bulb Size: H11
High Beam Head Light Bulb Size: 9005
Parking Light Bulb Size: 2825
Front Turn Signal Light Bulb Size: 4157NA
Rear Turn Signal Light Bulb Size: 992 (7440A)
Tail Light Bulb Size: 7443
Stop Light Bulb Size: 7443
High Mount Stop Light Bulb Size: 921
Fog/Driving Light Bulb Size: H11
License Plate Light Bulb Size: 168
Back Up Light Bulb Size: 921
Front Sidemarker Light Bulb Size: 2825
Rear Sidemarker Light Bulb Size: 7443
Map Light Bulb Size: 168
Dome Light Bulb Size: DE3175
Step/Courtesy Light Bulb Size: 168 or 175
Trunk/Cargo Area Light Bulb Size: DE3175
Daytime Running Light Bulb Size: 4157NA
...for my fogs, I've been using these for three years w/o any problems:
https://www.ebay.com/itm/LED-Import...h=item4417d29c6e:g:wQkAAOSwvktaeK8O:rk:7:pf:0
"I originally bought these H-11 LED's (Below) for the low-beams but the Intensity of their output was FAR too bright, but they're just right for the fogs, sitting much lower on the vehicle!"
'Best to you',
rig
Hey Greg, Excellent list above, great resource!
I have a couple questions...
The link you provided to the ebay listing says the are H3 bulbs? not H11. Did you have to make a modification?
And second how does the brightness on these compare to the H11 to H9 conversion that is so popular here. (I have been running this for several years and I am just curious)
Thanks in advance for all that you do.
Hi Neal,
Yes, that one's in my shopping cart for a spare set... so when you order, be sure to give the page your specific details of the vehicle e.g., year, make and model; and I would include the "H-11" bulb status just to be sure they don't screw-up the order!
And to your other question: "These LED's are "MADD Bright"; which is why I couldn't use them in the 'Low-beam' Bezel as planned! But they're perfect for the fog-lights! Mine are "Ice-Blue" (6,000K) in color; which is legal in most states, and even went through State Inspection this year!
...and the price; I haven't seen any 'High Quality' LED H-11's for less! Again, I've had them in for three years and no trouble with them freezing-up, burning out, or other cars flashing me about any glare issues! Thanks for your questions! 'Best to you' Neal, and your loved one's,
rig
