How to install roof rack crossbars
If I wanted to powdercoat (satin black) the two standard roof racks, would this write-up be a good way or the best way to remove them from the vehicle roof?
Thanks for the info in this thread...you guys are giving me too many ideas to spend $$! I was going to wait and see if we would really use the roof rack. Then I thought, we probably will on vacation and might be pissed I didn't add the cross bars before then. Don't want the wify mad! She probably doesn't even realizes it doesn't have them.... Dealer parts guy wanted $199! So I googled and best price I found was $124.95 so called the salesman that sold it to me and he price matched it. I should have made a stink about it when I purchased vehicle but again didn't think it a big deal. Not only matched but will have next day! Can't wait to try them on! Thanks again for the push! :)
Installing 4runner roof racks
Wow! This was perfectly explained. Once I read this I had the roof racks on in about 5 minutes. Thanks so much. Really nicely done!
Has anyone noticed wind noise or turbulence having added the roof racks at higher speeds. What happened, what speed? Just asking before I buy them.
They were installed on my truck when I got it and there was some wind noise. After I removed them, most of the wind noise was gone, however, I've never been positive that the bars had been properly installed in the first place. If one or both had been installed backwards, it would've created the noise. The only way to verify it would be to reinstall them and I'm too lazy. :)
I just added crossbars and remounted my Yakima Warrior Rack on top - noise? I really cannot tell a difference, even on the interstate. When I had my rack on my 4th Gen I could really tell but with the roof rack and bars further back I dont notice - .
Again, this is me as compared to my 4th gen. But I think I would have noticed a considerable difference between having and not having on my 2010.
:worthless
well maybe not worthless but it would be nice :)
Agree with previous post!
Need pictures for insight. Also ordered from Sparks in Myrtle Beach. $102, and $14 for shipping is a lot less than local dealership!
Just traded a 2008 Grand Cherokee Laredo on an SR5 4Runner. Can't even begin to compare, GC only had 12K on it, felt like 42K. Everything about the fit and finish in the Toyota is superior, everything!
Ordered mine for my Limited from http://www.toyotapartsoutlet.com
for $106.25 with free shipping. Got them here in 3 days.. This write up made it so easy to install them.. Thanks everyone for the post!!! I will think that this write up will be very useful to remove the ones on the truck to powder coat them.. just my 2cents
QUOTE
Please be careful the end caps are very fragile and the tabs seem fragile ensure you do not force anything and break your caps.[/QUOTE]
did anyone notice that the sr5 4 CYLINDER version has black end caps? cant get the part number though....:cry2:
QUOTE
That's probably because they are all come in plain black ABS plastic. They have to be painted to match the vehicle. The 4 cyl ones are probably just not painted or they are painted black.
anyone know where I can get the endcap that you are supposed to be careful with?? I lost mine and don't know which online site is a good deal. PM or message on here please. thank you!
Is the one your missing for a 2010 right?
SR5/Limited or Trail Edition?
Which one as all 4 are different ?
Front
Limited, SR5 Model R 63491-35040 $47.93
L 63492-35040 $47.93
Trail Model R 63491-35030 $47.93
L 63492-35030 $47.93
Rear
Limited, SR5 Model R 63493-35040 $47.93
L 63494-35040 $47.93
Trail Model R 63493-35030 $49.67
L 63494-35030 $49.67
Cheapest online is ToyotaPartSales.com
... or you could just spray-paint them black like I did with mine:
See more in my mod thread! :)
Danger - Danger
All worked great on my 2011 limited until the "roll" part to release the inner clips. Nothing epoxy can't fix .... :wow2: but could have been worse.
On the second removal, I slid a long take covered knifeblade back and popped off the tabs (inside tabs) easily. Once the outer tabs have been released, there is room to insert the blade (or screwdriver etc) against the inside of the rails down to the tabs. Actually the first one popped and the second one just let go.
No force needed at all. :trophy:
Hope that helps!
Frank
2011 Black 4Runner Limited
Photo please!
Hey,
I have a 2010 Black Limited; supposed to pick up a pair of cross bars tomorrow of Kijiji. They're black and my side bars are silver...anyone have a picture of their truck with this combo?
I ordered the factory cross bars for my 2010 4Runner Toyota Part number
PT278-89100 cost $140 after tax 150.85 shipped over night to my dealer.
In order to install the bars they must slide in from the rear which requires the plastic end caps be removed.
IMG_4614.jpg~original
The part is supposed to come with a nylon removal tool, which mine did not however a putty knife or small pry bar works I put tape on mine to prevent any scratches.
Push down and inward on the End cap and pry up on the outside where the small plastic tabs are.
IMG_4613.jpg~original
After the tabs are off the outside edge push the endcap up and inward to rock the inside tabs off.
Once removed you can see how they are attached.
IMG_4612.jpg~original
IMG_4611.jpg~original
After removing both end caps simply slide the cross bars in from the back. I did not tighten the screws which attach the bar until after I had slide them forward to allow a little play while installing them.
IMG_4609.jpg~original
Finished product.
IMG_4616.jpg~original
Thanks for your instructions, were very helpful. In my case I used a small laundry clip to open the end caps. Because have the perfect form to introduce it below the edge and with a small pressure the cap was released.
Thanks
I just installed the crossbars yesterday. I heated the end caps with a hair dryer, and used a paint can lid openner to pry under the edge and release the plastic tabs. It went very smooth thanks for the help.
