20 inch wheels on LIMITED
I got the same set 275/55/20, nittos, they fit, don't rub without a lift and the ride is quiet considering how aggressive the tires look.
Hey digablekid, what size did you go with? I just got those in 275/55/20 and they said they wouldnt put them on. Just wondering
Mine are 265/50/20. The rep at Evans Tires in Vista, CA did a really good job and even went over the ratio calculations with me. $930.00 out the door, with alignment.
I've only driven 100+ mikes but so far; the ride feels so much better as the tires hug the road, cornering is much more stable and that "numb" feeling when while steering is even less noticeable.
Gas has dipped about a mile but that could be because my in-laws have been using Da Runner to get around since the tires have been installed.
Anyways, I'll loop around and give an update on wear and any other pros or cons after 5 or 10k miles.
Thanks man i went some where else and they said they would put them on. $ 930 for the tires and 130 to put them on. Hopefully it goes smooth. I had them on my 99 4runner and loved the way they look anyways thanks again
FYI, the first place said NO when they realized that your 7" wheel was not within Nitto's 275/55 recommendations for fitment. You will probably have better luck with smaller/independent shops than with bigger chains, but I wouldn't be surprised if you get the same response again if/when they check it out.
Plasti Dipped
I did this today, along with finishing off the chrome trim on the front. I only got two wheels done...
I did this today, along with finishing off the chrome trim on the front. I only got two wheels done because of people using my shet!
That give me the urge to powder coat my stock 20" rims!!!!
You convinced me to do it, semi flat black on those rims looks very good. I wonder, though, if semi flat powder coat exists?
How did you prep your wheels? Any special cleaners?
Also, is this just the regular Black Plasti Dip?
I didn't use anything special to clean them with, other than car wash soap and an alcohol wipe. Afterwards, let dry for about 10 minutes.
I would recommend taking the wheels off the car though. I've seen people leave the wheels on the car and stuff things inside to block spray from getting to the brakes and other components. This is half-azzed in my book.
And yes, it's just black Plasti Dip. It takes about 5-7 coats, waiting 15 mins between. Apply evenly and with even "strokes". Be patient and wait the 15 mins... otherwise, you'll get paint drips.
Thanks for the info. I'm running separate winter tires and rims so my plan is to dip some time next month before I put my 20s back on.
One other question: did you turn the wheels over and plasti dip the whole inside of the rim as well?
Good question. Yes, I didn't want it to look half done. Plus, I didn't want to take the chance of the dip from peeling off from where it ended. The inside and more unseen part if the rim doesn't take as many coats. Do the inside first.
Oh, and don't you use an alcohol wipe :biggrin2: ... I meant an alcohol wipe down.
Perfect thanks. Looks like you did a good job! Looking forward to seeing how mine turns out on the Shoreline Blue.
looks great! how many cans did it take for all 4 wheels? will this hold up if i take it to a hand car wash place?
Because I have a soft spot for shoreline blue :) (sorry to whomever I hijacked that picture from, lol)
Seems like it would go well, but you might need to black out that little chrome strip that runs across the rockers to tie it in better?
A can can cover an entire wheel, plus a few layers on another. If you've got the time, invest an entire can on a wheel to make it thicker and less likely to get damaged if nicked pretty good. I wonder if a sealant would work on PD... Hmmmm.
Holy mackerel... That's a good PS job! Looks pretty legit. Ask and you shall receive,, [MENTION=92682]JayceeP[/MENTION].
That's awesome- thanks for doing that! I agree: might have to consider the chrome strip as well.
Still wish the pre-2014 LE had the Limited badging. How's that for a bad mod? Lol.
I'm not sure I'd do flat black on Shoreline. That color really looks great with a little bright work rather than blacking everything out, IMO. Something like the liquid metal color that Lexus uses would be the tits on your shoreline.
Agree. SB seems a little too ....... what? ..... elegant maybe? ... for that wheel color.
