10-07-2010, 04:04 PM
#16
EBAY didn't work
Hi,
I got a key on EBAY ($15) that supposedly should work for my 2010 SR5. Just took it to the dealer today and he was unable to program it. So EBAY keys may not be a bargain. Anyone got a source for inexpensive key blanks that will work with the 2010 SR5? My dealer says he will program it for free if I can find one. He did not have a valet key in stock. I am looking for a valet key as I want one that will not get shorted out if it gets wet.
10-07-2010, 04:57 PM
#17
I think I've had my subaru key go through the wash about 3 times......each time requiring a $100 new key. It seems no matter how diligent I am about making sure my key is not in my pant's pocket before it goes in the laundry, there will be times I forget and my wife doesn't check.
10-08-2010, 05:59 PM
#18
Super Moderator
Super Moderator
IIRC, there are two types, if not more than two of Toyota immobilizer keys. On the 4th gen's key, it needs to be the one that has a dimple on near the key head to work. That may be the case with the 5th as well.
'06 Limited V6
Amy's Mom: "Who's that you're talking to?"
Amy: "It's Uneek, spelled in a 'unique' way."
10-08-2010, 06:33 PM
#19
My EBAY key that did not work had the dimple, my 5th gen keys have a small "G" stamped on the key.
10-08-2010, 06:48 PM
#20
FWIW, I accidentally left my fob in my pants pocket and ran it through the washing machine. I panicked at first, but was gratefully surprised when it still worked.
10-08-2010, 08:14 PM
#21
I did the same thing. Ours did not work, though, so I had my wife disassemble it and set it out to dry. A week later it worked perfect. The funny part is that I had my key and it was her's that was washed. So, I took my key apart at work while instructing her over the phone. She said it was kind of fun, haha.
2023 4Runner TRD Pro, 2023 GR Corolla
10-08-2010, 08:56 PM
#22
OP, this is simple. Have a plain key cut (by anyone...my dealer gave me 2 for free, cut from the VIN) so that you can unlock the door if you lock your keys in the car. On Toyotas with factory alarms, unlocking any door with a key (any properly cut key, including plain metal ones) disarms the alarm. The only thing you need the immobilizer chip for is to start the truck.
2018 Toyota 4Runner SR5 4WD, Black, 3rd row seating
Valentine 1 Gen 2/Savvy/concealed display hardwired, with custom power button. DRLs disabled. H9 / 9011 bulbs. Automatic locks disabled. Center console and glove box organized. Custom garage door opener button. Nav wire mod hack (with custom button). CarTrimHome motorized folding mirrors. Anytime backup camera with front parking camera & custom OEM-matching backlight LED.
10-08-2010, 11:14 PM
#23
For what it is worth I was speaking with a local place that installs electric starter kits into vehicles and the installer there told me the easiest way they get around the chip key immobilizer issue is just to permanently leave the chipped valet key inside the steering column. Then you can use any cut key to start your vehicle as you wish.
2014 Magnetic Grey Metallic 4Runner Trail: KDSS / Tint / Toyo Open Country AT II 265-70R17 Tires / Pro Comp 7005 17x8 Wheels
10-08-2010, 11:49 PM
#24
Super Moderator
Super Moderator
Some hardware stores refuse to cut a regular key if it is an immobilizer key. Don't know the reasoning behind it. I went down to Home Depot and had it cut, no problem.
The plain metal keys work great too. Thin enough to fit in a wallet.
'06 Limited V6
10-09-2010, 12:05 AM
#25
Originally Posted by ScottyTsR5
I just went to the dealer the other week and they programmed my key to open all the windows and sunroof (besides the back gate) by holding down the unlock button. Also had it programmed to open/close all windows by inserting the key in the drivers side door and turning it from left to right. Pretty nifty
Huh, how did they do that?
Current Toys: 2011 T4R Limited Blizzard Pearl w/stuff | 1979 Jeep CJ5 w/lots of stuff | 1989 Harley Davidson Sportster 883 w/lots of chrome | M416 Army Trailer
Past Toys: 1988 T4R 1-Ton SAS (1st Generation) | 1998 Tacoma Ext Cab Supercharged |1995 Wrangler YJ | 2003 Wrangler Rubicon
10-09-2010, 12:31 AM
#26
It is in your owner's manual, its do-able options, but only by dealer. IMO I think they should let the user that option to change it to fit each individual's preference.
2010 4x4 SR5 V6 Blizzard Pearl.
10-09-2010, 01:14 AM
#27
I had those features on my Mercedes.......shocked it doesn't come standard that way. Guess I'll be making a trip to the dealership sooner than I thought.
10-09-2010, 01:41 AM
#28
If you have the Limited, you don't have to go to the dealership. I forgot what buttons you have to press, can anyone else chime in?
'10 Limited Blizzard Pearl
RWD, Nav, 3rd Row, tint and Yakima rack
10-09-2010, 02:02 PM
#29
Originally Posted by westwind77
You can have a metal key cut but it will do nothing to start the 4R unless the key has the built in special chip, and that chip has to be programmed to match the code in the 4R you own.
Wrong: The RFID chip in the key doesn't get programmed. It just replies with a number when the car asks it who it is. The car must be programmed to recognize the key number as OK.
This is not expensive technology, they are thinking of putting RFID's in many products you buy. It is gouging for Toyota and other car manufacturers to charge so much.
My dealer told me that it is necessary bring in all your keys to add a spare. That is poorly designed computer software by Toyota.
I can't understand why the manufacturers behave so badly towards their customers. Maybe it is because we are helpless to prevent it.
10-09-2010, 04:26 PM
#30
Not true...doesn't work...I tried it. The antenna for the RFID reader is a loop around the ignition switch. If the RFID chip isn't right there, inside the loop, it won't be read.
The easiest way to get around the immobilizer is to buy an XPressKit Data Transponder Override Interface (XK05 model with PKT1 interface software works on my 4th gen). Simple hookup...just 5 wires. $32 at Amazon. Hook up the trigger wire to something secret/hidden that no thief will ever find, and you can store your fancy RFID keys in your closet and just use a skinny metal key to start the truck.
