Headlight Aiming
airborneranger
Anyone else have headlight beams aimed too high from the dealer? When I have some stuff in the truck like 4 people its really noticeable.
All good now. Just lowered my sis' lights with the adjustment screws located behind the headlight assemblies.
The front radiator cover makes the bay look nice but is extra work to remove and put back on when working under there.
It's actually on the back of the lights.It's a 8mm adjuster bolt but I don't remember which way to turn to lower the lights.Somebody pitch in which way if you do it or know.
I had to lower mine when I did the front lift as they were way high then.The lights were shining off the back of peoples heads in front of me the first night out. That's not good!You should keep the light cutoff at or below a small subcompact car's trunk height in front you. I shot a pic of the passenger side. It's the big silver bolt in the middle and takes a 8mm wrench or socket.
<a href="http://s420.photobucket.com/albums/pp282/gharper60/?action=view&current=Picture086.jpg" target="_blank"><img src="http://i420.photobucket.com/albums/pp282/gharper60/Picture086.jpg" border="0" alt="Photobucket"></a>
The best way is to adjust it in front of a wall or garage door at night.
I have received a few 'flashes' from other drivers, so I have a feeling they are a little high. I think they are surprised when I flash back with my real 'highs' though :lol:
HeHe..me too!
But I don't want to be rude or blind someone..so I'm glad to see this an issue, I'll adjust mine tomorrow.
Always on top of it :)
Good work :thumb3:
Interesting Fact of the Day
Notice how there is only one adjustment for the headlights? Only Vertical. This is due to how well the truck is put together in Tahara. The body welding and panel accuracy are spot on.
Many manufacturers still can not do this. Thanks Toyota!
So by aiming the headlights do you guys mean that this procedure allows you to move the entire assembly up and down or is just the light bulbs inside that are being moved?
I finally adjusted mine last night, after getting flashed for the last time I could take it. One note, it takes a whole bunch of turns to make the lights move even just a little. And a little side story related to this:
Late on Christmas Eve, I was following a guy on the Interstate at normal 2-3 sec distance. He had a good tempo, so I liked following him. Then, I guess he got mad because he THOUGHT I had on my brights. So, he foolishly slowed down to 25 or 30mph in the left lane, so as to "teach" me a lesson or something. There was no other traffic. All he had to do was get in the right lane and slow down and let me go on by. I thought he was drunk, so I quickly went around him in the right lane and sped back p to 75 to get clear of him. He then sped up right behind me and rode my a$$ with his brights on for 25 miles. Every time I changed lanes, he changed lanes, etc. I kept asking my wife, "are his brights on????" It was hard for me to tell due to the 4runner's auto dimming mirror and window tint. He finally go off the road and as soon as he was veering off, he put on his dims.
Merry f*cking Christmas to you too a$$ hole!
Anyways, unlike me, you all should adjust these things right away if you are getting flashed, instead of waiting until Chrismas Eve.
Yeah after I lifted mine my lights where shining on the back of people's heads in CRV's, and anything smaller would flood their whole cabin with light. I knew this was not good and it only took me just about 5 minutes to correct the headlights.
Can anyone confirm which direction to turn the adjustment screw in order to lower the headlights? In various threads on here I have read clockwise AND counterclockwise.
I suggest you turn it one way, and if that doesn't work, turn it the other...:biggrin2:
+1. Best way to do it is to try it out. It's more than obvious which way the light aims as soon as you turn the screw.
Easiest way is with a Phillips screwdriver. Put the screwdriver down the channel leading to the nut and the Phillips head will engage the gears. Turn screw driver counterclockwise to lower. Note that the nut will turn clockwise. After lowering, turn screwdriver clockwise very little to "tighten" the gears.
JD, if you use a socket to turn the nut as you did, then clockwise is correct. Because the nut is turning the gear, which turns counterclockwise. If you use a Phillips head screwdriver and just turn the gear as Hawaiian-4runner suggested, then you turn it counterclockwise. Be Safe and have a very Happy New Years.
