Gear shift knob change
Gotta revive this one. I have my rock warrior shift knob on it's way and want to make sure I have the right set screw. I stopped in at Home Depot, and picked up some different length set screws, all 8mm. But that refers the the width, I really should have though of the thread size. How can I order the set screw that I need to make this shifter work?
what is set screws?
The engineer in me is thinking of a threaded plug with a hex socket so that you can use an allen wrench to screw it into the knob. This would then fill in the void needed to prevent the knob from bottoming out. Something like this, with a driver bit depression... However, the socket, I imagine, would be super small.
Sorry. I should've quoted this earlier.
for the 4th gen I had to cut my FJ knob down (alot) It looks like you do not have to on my 5th gen.....?
That's the same set screw problem I had with my Momo knob when I had it. The solution I used was to wrap aluminum tape around the shaft where the set screws were to grab the shaft. I cut about a 1/2' wide piece and wrapped it around the shaft to gain the necessary diameter just where the set screws hit. Here's the type of tape although we use the much more expensive 3M brand and in the aircraft world we know it as "speed tape" or 500mph tape. Scotch Aluminum Foil Tape 3311 Silver, 2 in x 10 yd 3.6 mil: Amazon.com: Home Improvement
If you really want to get longer set screws an you have to make sure the thread pitch matches the 1.25mm ,here they are..... Metric set screws, Allen, Cup point, Stainless steel 18-8, 8mm x 1.25mm - Bolt Depot
Thanks Harper. The set screws are on their way!! I appreciate the link and help. This forum is awesome, and like many, my wallet will feel the brunt of it!
My choice, a '13 Sienna shifter knob.
Check out my custom transfer case knob, always get the feeling someone's watching me :scared:
How did this turn out for you?
I'm in the same boat... specific set screw you used that was successful?
I'm planning to use something like this: M8 x 1.25 6mm set screw
Installed this Leather TRD Shift Knob (# PTR51-00110) about a week ago....
Which part number is the correct one? I have a 2011 4Runner:
PTR57-00110
This part fits the following vehicles:
Toyota: Sequoia 2012 - 2014
Toyota: Tundra 2012 - 2013
PTR57-34140
Toyota: 4Runner 2015 - 2015
Toyota: Tundra 2007 - 2015
Toyota: Tundra 2014 - 2014
They look identical!
I love the look and quality feel of the TRD Pro shift knob. Best looking one IMO.
sadly I like my faux wood gear shift knob.
bought a momo blue shift knob for the warden to match her upcoming new Tacoma.
it fits her current Tacoma but the adapters and what not turns me off. I would like if it was a drop in replacement.
she likes the color and I guess that's all that matters. me bleh, the feel even feels wrong imo.
Anyone have any experience with American Shifter?
Custom Shift Knobs, Cool Shift Knobs, Shifters & Custom Interior Accessories « American Shifter
Looks like most of their stuff is 16mm x 1.50 thread whereas our 5th Gens are 8mm x 1.25. They sell an adapter, but I was wondering if the shift knob had to be drilled or not. Here is the one I'm looking at: http://www.amazon.com/American-Shif...sbs_263_2?ie=UTF8&refRID=01CX5T0PB5AZW0309B5F
I do not, but a couple of other guys got some stuff through Hotrodshiftknob.com
I went with the Classic Toyota knob
Classic TOYOTA Logo Shift Knob - HouseOspeed - Hot Rod Shift Knob
Also, the trans thread is 12mm x 1.25. I think the transfer is 8mm x 1.25.
