Post your LIFTED pix here!
2011 TE (converted to 2014 headlights)
4x4 labs front bumper, VR10000s winch, OME suspension, TC UCA's, OPOR sliders, Level 8 MK6 wheels, 285/70/17 Duratracs & Rigid SR30 behind grill.
Having filler pieces fabricated to fill in the gaps under the headlights after the conversion.
<a href="http://s1166.photobucket.com/user/konst1015/media/IMG_3075_zps7080b13a.jpg.html" target="_blank"><img src="http://i1166.photobucket.com/albums/q604/konst1015/IMG_3075_zps7080b13a.jpg" border="0" alt=" photo IMG_3075_zps7080b13a.jpg"/></a>
<a href="http://s1166.photobucket.com/user/konst1015/media/IMG_3076_zpsb0dd284c.jpg.html" target="_blank"><img src="http://i1166.photobucket.com/albums/q604/konst1015/IMG_3076_zpsb0dd284c.jpg" border="0" alt=" photo IMG_3076_zpsb0dd284c.jpg"/></a>
Looks Great. How did you mount the Light Bar?
Hands down best aftermarket front bumper for the 14+ 5th Gen.
Finally! Sonoran Steel rocks!
Finally Got the BFG AT K02s
Now it looks like proper vehicle with the BFG K02s
Overdue in posting these. Had the lift installed @ 100km's, Toytec Boss and 285 Duratracs
Toytec Ultimate 3" lift, TRD skid, American Outlaw 17" Revolution, Nitti Terra grappler G2 265/70/17
[MENTION=120494]Colo15T4R[/MENTION] looks good!
Just a heads up, if those American Outlaw wheels start to shimmy at about 65 or so miles per hour you may have difficulty getting them to balance. I had American outlaw Deputy wheels and Discount finally purchased them back as it proved to be almost impossible to balance the wheels because they are lug centric instead of hubcentric.
[MENTION=114439]Curly Jefferson[/MENTION] I haven't noticed any Issues with the rims at this point. I've only had them on for about a month and Discount didn't have any issues that I know of when balancing them. I will sure keep a feel out for it. Thanks for the Info.
Billie 2.5
I too am staying stock size tires - speedo stays accurate, mpg's don't suffer and it also looks pretty good as is. This is the Bilstein 2.5/1.5 daystar combo. Couldn't be more thrilled with the way it looks and handles!
20150217_134010_resized_zpsad8fe371.jpg~original
Did you put new shocks all around or just the Billy's in front with the spacer in the rear? Is there a reason why you went the route you did? Did you keep the stock springs?
New 5100's all the way around, I am a fan of matching front and rear when possible so that the damping works in concert. Stock coils.
I did this setup because I'm 99% street and commuting to and from work so I wasn't about to spring $1,000+ on any type of coil over kit. I also don't like the idea of just spacers because I think the stock SR5 shocks leave a lot to be desired - they're quite mushy and soft. Now, spacers on an XREAS or KDSS vehicle? You could probably get away with that.
For me this setup is best of all worlds for a primary street driver - it isn't too expensive, it gives you a level and lifted ride, and firms up the driving characteristics as well. I hate all the reviews on the roly-poly ride of the BOF 4runner because for short money, you can eliminate A LOT of that.
I ended up choosing close to the same route, but I am doing the toytec adjustables on the front 5100's because I will eventually add to the vehicle and wanted to make life easier down the road. Glad you like the ride because I was a little worried about the rear spacer.
