Post your LIFTED pix here!
Nice!!! What are your wheel and lift specs?
Thanks! I'm happy with how it came together. The wheels are ProComp 7005, they are 17x8 with 0 offset. I have Bilstein 5100's all around, on the highest setting in the front with ProComp 2" spacers in the rear.
Officially making my first post after lurking for quite awhile. This is my daily driver and I've loved every second of it! I've been kicking around the idea of getting rid of the 18's in favor of 17's but I can't make up my mind for sure.
I may have missed it but what did you use to coat the front lower portion of the grill? I'm curious to see how it holds up to bug gunk over time, not sure if it would be better or worse.. all I know is bug gunk is the absolute worst if you won't get it off in time
I had a shop spray it with Pro Liner. It should hold up really well over time.
I finally can post here on this thread! LOL!!
IMG_1006_zps3rfse3tl.png~original
IMG_1001_zpswwoow2k8.jpg~original
'16 Limited with Icon Stage 2 lift, 17" Method wheels, and 285 Nitto Ridge Grapplers
<a href="http://s1378.photobucket.com/user/jjhoagland/media/IMG_4510_zpsbjs1zius.jpg.html" target="_blank"><img src="http://i1378.photobucket.com/albums/ah82/jjhoagland/IMG_4510_zpsbjs1zius.jpg" border="0" alt=" photo IMG_4510_zpsbjs1zius.jpg"/></a>
How are you liking those Ridge Grapplers? I'm installing a set on Saturday.
Really liking them! I wanted something aggressive looking but also that would be really quiet on the highway. Had to cut a lot of the fender lining out to keep from rubbing on turns just fyi
Very little to no trimming should have been required if you got the correct back spacing wheels. I ran a 285/70/17 on 17x8 FX Pro wheels with no lift at all and almost zero rubbing. Can you post a picture showing how much your wheels stick out?
16 TE with OME 2883 up front with bilsteins set to .85. In the back I put Wheelers/Eibach T13 springs with one OME 10mm spacer in left rear. Ended up with 2.5/1.5 Cooper Discover AT3 P285/70/17. Pic is with little weight in rear with almost empty gas tank and slight nose down slope on driveway. The stance can change a fair amout depending on load and slope of road/driveway.
2016 Trail
<a href="http://s1378.photobucket.com/user/jjhoagland/media/IMG_4522_zpsr3ka8w7a.jpg.html" target="_blank"><img src="http://i1378.photobucket.com/albums/ah82/jjhoagland/IMG_4522_zpsr3ka8w7a.jpg" border="0" alt=" photo IMG_4522_zpsr3ka8w7a.jpg"/></a>
Good point about the back spacing... that could be why
What are the specs on your wheels? Most likely due to that as you're lifted pretty adequately for the tire size.
Icon stage 2 (tubular), 17x8.5 method Con 6, 285/70R17 toyo AT2
Installed Kumho AT51 tires and got my post-lift alignment today. Very happy with the results!
With the cam bolts maxed out, the best caster values the alignment tech could get was 2.4º left, 2.8º right. Seems to drive fine, no wandering so far!
