Need to find VSS wire on 2010 non-JBL
they may have changed this, but you used to be able to just ground that wire for full features while driving. You should give that a try.
oh, and I don't know where the VSS wire is.
Check You Tube. I remember seeing a video that tells you how to do it. I believe it is the yellow wire on the top right. Sorry to be so vague.
You are referring to the parking brake override. I already did that override. I am looking for the vss wire to make the navigation more accurate.
maxx0695, I'm looking at the pin layout for the 8-speaker Radio Reciever Assembly.
Here is the code as written:
Pins
G9-3 (SPD) - G6-7 (GND)
Wire color
It's described as "Speed signal from combination meter".
