Towing experiences with your 5th Generation
dsir56
Has anyone done any serious towing with your 5th gen. V6 and factory hitch?
I want to buy an Equal-I-Zer weight distributing hitch to tow my 20' camper; it has an empty weight of 3600 lbs and a GVWR of 4950 lbs. I figure it'll be about 4500 lbs loaded. 500 lb hitch weight.
I can't find anything in the new owners manual that says not to use a weight distributing hitch with the factory receiver (rated for 5000 lbs.)
Also, has anyone found decent extended towing mirrors?
Thanx
I towed a rental 17 foot trailer for a week all around Michigan, about 2000 miles. I don't have much experience towing, but I thought it was a pain in the ass. Fifth gear was useless, so I left it in S-4 the whole time. I think I averaged 10 MPG, it was down to 7 MPG for a whole tank going across Wisconsin.
I think the trailer was around 3400 lbs and seemed to tow straight, it never swayed (even going over the Mackinaw bridge). It sat pretty level too, which surprised me.
af552c07.jpg~original
If you're really gonna have 500# on the tongue, you may want some rear end spring help, like Timbrens, etc. You're likely going to get some sag otherwise.
IMO every gasoline engine powered vehicle sucks at towing long distances, especially if there are any hills/mountains involved. I think I was spoiled by the one and only time I towed something long distance with a diesel powered vehicle. Anyway, I've used my 4Runner to tow a flat utility trailer to pick up a bunch of furniture. I'm guessing the trailer probably weighed 2,000 pounds empty and maybe another 500-800 with the furniture on it. The 4Runner performed as I expected, 5th gear useless most of the time, gas mileage in the toilet. No swaying and no problem holding my speed on the highway.
Aren't you supposed to turn off overdrive when towing?
mpaquette- Our Suburban tows just fine. We've made two or three trips to Florida that total over 2,500 miles at least.
Thanx
Welcome to the forum..
I would only use a weight distributing hitch for something that close to the max. There is no special setup for the reciver tube itself..the hitch assembly should slide right in. I think the bigger part of the issues are with passenger tires towing that type of weight. I'm running scared with the stockies.
I've been looking for a decent towing mirror myself. I always had the "slip-on" versions and loved them, but I always added a little more foam on the inside of the mirror to protect and dampen vibration.
Pat
I've towed 2300 lbs (17 ft jet boat) without any problems. Hilly terrain needed a little extra gas, but overall it did well... I barely noticed a difference in the braking too.
Thanx
The rule of thumb is only tow 80% of the OEM (Tow and tongue) rating. You can get away with just the trailer but with it loaded you will most likely have problems. If you are committed to this trailer, this may be your anwser;
Trailer Sway Elimination Guaranteed - Hensley® the ONLY trailer hitch guaranteed to totally eliminate trailer sway.
Koz
How do you turn off just overdrive?
This is a 4Runner forum last time I checked. Unless you mean you were towing a Suburban :shrug: I don't see how that helps.
It was mentioned Gasoline engines are not the best for towing.
Koz
I don't tow much, but only 80% of the OEM rating seems ludicrous. They should already have a pretty big factor of safety built into the rating, especially considering what the tow ratings for identical vehicles are set at in Europe. (i.e. vehicles with zero tow rating here are rated at 2000 and 3000 lbs in the UK)
I agree..
Ive been towing my whole life and never heard that before. The truck companies aren't going to rate em' to downsize them. I am a firm beleiver in a safety factor, but I let happen with quality equipment, and careful considerations to your surroundings.
But...i been wrong before..
Once...
lol, Pat
I have towed our 22.5' Crownline boat (around 4000lb) with gas, trailer, and loaded with stuff. The 4runner did just fine although not as great of acceleration off the line as my 2006 V8 but once going just fine. Braking was adequate and as others mentioned, if hills are involved, its best to keep it out of 5th gear. All in all, I was satisfied with it and it probably towed as well as my 2003 4runner with the non-VVti V8.
If you research on RV sites you find that towing at a vehicles max ratings can be dangerous without safety equipment (WD hitch, sway control, trans cooler etc.). I'm not saying you can't tow up to the OEM rating. I'm saying if you do, you will need safety equipment . If you tow 80% you will be in the safe zone of the rating. There are rules of thumb for the max length of a trailer that can be towed based on the length of the tow vehicle's wheelbase. You NEVER exceed the rated tongue/hitch weight. You need to adjust the weight in the trailer so 10 to 12 percent of the total weight is on the tongue. You need to include the weight of passengers and supplies in the tow vehicle in the total tow rating. You can tow 5K lbs with a vehicle rated to tow 2K lbs. The problems come about when you have to make a emergency maneuver, climb a hill, descend a hill, high winds, etc. Then you start having big problems with the tow vehicle, engine, trans, overheating, brakes, suspension, etc.
There is a big difference between towing a boat and a travel trailer (aerodynamics). Also, 4K lbs is exactly 80% of the vehicle’s rating.
There is also a big difference between a short trip to a campsite or a launch ramp and taking a long distance trip across mountain passes.
If you plan on towing, do some research and protect yourself, your family, others on the road, your vehicle and trailer.
No one has done more stupid towing then me, when I was young (young and dumb). I’m embarrassed to even talk about it. All can say is, I thank God no one got hurt! Towing is serious business, do it SAFELY!
Koz
Does your camper have brakes, like boat trailers do? With that weight, this would be a huge issue. I've owned/towed lotsa boats - no idea about campers.
Koz
Amen Koz.
As someone who has found himself in some sticky towing situations over the years, I cannot stress strongly enough how important proper equipment is.
One cannot appreciate a weight distributing hitch and dual cam sway control setup until one has towed and enclosed car trailer in 40-50+ mph winds (front/rear and cross winds). Then there are emergency type maneuvers thanks to some other "distracted" or just idiot drivers one shares the road with.
With my loaded car trailer I run around 78-80% of my (7K) towing capacity ('04 V8 4Runner) I also invested in a tongue scale and got an actual tongue weight as opposed to a SWAG of my tongue weight. When I measured the tongue weight the first time I found I was about 180 lbs over the max tongue weight. Rearranging some items in the trailer and moving the car 1 foot towards the rear brought the weight almost 100 lbs under the max tongue weight.
BTW, someone in this thread who was looking for better mirrors for towing might want to check out these mirrors: McKesh Mirrors
I have been using them (along with the optional convex mirrors) on my 4th Gen 4Runner since I started towing with it. Be advised I did have to bend the metal anchor that grabs the bottom of the door to make this work properly.
I also use painter's tape on the anchor and on the door sill to minimize scratching.
The safety of you, your family and others on the road depend on Y-O-U.
Good Luck, Have Fun and Tow Safely.
Now days, overdrive simply refers to any gear in the transmission that is taller than a 1:1 gear ratio. In a 5 speed transmission like in the 4runner, the 1:1 gear is typically 4th gear, although it can vary depending on what the manufacturer wants for a given vehicle. So like a couple of other people said, just move the gear selector from Drive (which will use all gears, 1-5), down to the 4 selection, which will only use 1-4. That is the effective equivalent of "turning off overdrive." :) Although honestly, it's probably fine to leave it in Drive while towing, and if you find the engine lugging for some reason and the tranny isn't downshifting on its own, you can downshift it to 4.
In the old days, some cars often had a separate overdrive unit in addition to the normal transmission, but I don't know if any modern vehicles still do that. It's kind of archaic and a bit overly complicated, especially given how many gears automatic transmissions have now days. :)
That's what I basically meant. The 3rd gens have a selector that turns overdrive on and off.
Like you said it's probably not necessary every time you tow, but if the transmission has to constantly shift from 5 to 4 then it's probably creating a lot of heat.
Does the 5th gen have an auxiliary transmission cooler from the factory? I thought I read that somewhere.
