Body Side Molding
P1020988.jpg~original
Pattycakes, you have black fender flares but your tagline says you have SR5. I thought those were only on the TE. Did you paint those, or were they an option in your area? It is not a 4-cyl right, since they discontinued those in 2011? Or did they only discontinue those in the US? Sorry if this was answered elsewhere.
It's those darn Canadian packages, always having to be different, thinking they are soooo special or something :hiding::D:wink2:
I take that as an insult Ryan S . I like the CAN edition SR5 better more ruged , not prissy looking , no chrome nice factory mud flaps and running boards to protect from rock chips . And it only cost $ 45 K . Good Deals up here eh.
I happen to think the extra black looks good on the US TE. Judging on the price of the Can edition sounds like the US price is better.
Actually if you look too quickly at my first pic, it kind of does look like a Ford Explorer lol. Thank god I bought it for the wife and I don't drive it.
On a side note, they finally have the door edge guards for the 5th gen in, in same body color. Mine will be here this week and will put them on next weekend. Was quorted $44 for the set.
bodysidemoulding003.jpg~original
bodysidemoulding008.jpg~original
[/QUOTE]
Very nice. Are the installation instruction easy? I am afraid of not installing them straight and the right height. Any tips you can share will be greatly appreciated.
The factory instructions are pretty good along with the recommended measurements.
I will tell you how I did mine, I'm not sure if its the best way, but it seemed to work for me and it was pretty easy.
1) Make sure the surface area is clean.
2) Use a soft microfiber towel and dampen with rubbing alcohol, gently wipe down the area and let dry (a couple of minutes).
3) I measured the distance and applied blue painters tape to use as a template to make sure the measurements were straight. Double check all of your measurements, I almost made a mistake at this point, but I caught it when I rechecked everything.
4) Make sure you have the right piece of moulding and peel off the backing material, I really slowed this down and took my time when I started to apply the moulding , when it sticks, it sticks! I lined up the bottom edge of the moulding with the blue painters tape and slowly applied the moulding.
5) Use a clean microfiber with a little bit of detail spray to dampen the towel with (This acts like a lubricant and wont scratch the finish on the moulding when you are rubbing the moulding on) and gently rub the moulding to ensure it is on 100%.
6) I did not wash my truck for a few days, just to make sure the adhesive was nice and dry. I then applied a few coats of wax and was finished.
I hope this helped and I`m not sure if this is the best method, but my stuff is on straight and it has not fallen off yet:beer:
I am getting the BSM....thanks for the tips. I am thinking of using dry erase marker sparingly as needed to mark as well. Shouldn't damage the paint I think.
Side Molding Tips
My 4 Runner is a twin to Mike G.'s and his directions are spot on. I put the side molding on mine on a few months ago. The only thing I did in addition was to actually tape the pieces onto the door so I could see if they would not catch when the door opened. Each piece is beveled already, but you install it too tight to the door edge it might bind up when the door is opened.
Definitely use the painters tape that Mike is speaking of and measure,measure and then measure again. I must have sweated off 5 lbs that day!!
Good luck. If you do city driving they are worth the trouble. Mine saved me twice already from a door ding.
Installation Instructions
Attached is the installation instruction document....I requested it from Sport Wing to gauge if I want to undertake the installation myself....looks like steady hands are needed...
Has anyone else had a problem the molding coming off in hot weather? Mine moved and got ruined when it rubbed together when a door was opened. I was very careful in the installation so I'm confident it was put on properly.
Wondered if anyone else had this problem.
