OBD-II Port?
PolkManiac
Can someone tell me where the OBD2 port on the 2010 model is? Is it accessible, or do I have to take stuff apart to get to it?
Yep, stick your head by the pedals and look UP! Tucked under a bit, but nothing needs to be taken apart. Hooked/scanner my reader up to it last week to confirm it worked, all was well. Hopefully I will never need to use it though :)
I'll probably never use it but my local Department of Environment Quality and Overregulation will use it when I need to get my tags renewed.
Yep, just stick your head down where your left foot rest, look up, there should be something that looks like this...
OBD-2Port.png~original
I keep my scangaugeII plugged in all the time.
A little off-topic, but mine came with a 2 year inspection sticker so I won't be seeing my inspection people till dec of 2012. I wonder if other states do that as well. (2 year tags)
It's 4 years here in Oregon where the inspection and tag renewal happen at the same time. I swapped plates from my 2007 FJ Cruiser trade-in and only had to pay a transfer fee. I will have to renew in Feb '11 so I'll be inspected at that time. And yes, you have to come up with four years of tag fees at the time although our fees are not as high as some others.
My OBD port is not working
I bought this OBD II adaptor from Amazon.. Plugged in under my 2002 Toyota Corolla and the red light lit up.. Plugged in under my 2010 Toyota 4Runner and nothing happens. No light no feedback. All lights in my car are working including the cigarette lighter. I don't understand what could be the reason.
Tried looking for the OBD fuse in the fuse box but could not figure out which one it is.. So please help on the fuse location or anything else i would need to do!! :(
I don't know about a fuse for the OBD port but I found through experience that some of the Chinese OBD adapters that Amazon sells don't work with Torque Pro. The second one I ordered from them did work, however. It was this model: OBD from Amazon
Thanks.. I ordered this.. It will arrive on saturday. Will return the other one...
So the Amazon link that was posted in the earlier post, It arrived today and thats not working either.. So I am assuming its something to do with my car. I just got the Inspection done few weeks ago, is it possible that they disabled the port?
I doubt they disabled the port, not even sure if that's possible, unless you mean physically disabled it by breaking it, lol.
Have you checked the fuse for the OBD port? It's in the under the dash fuse box. See attached diagram below, please report back because I am curious myself :)
As Suspected.. The fuse was removed.. replaced the fuse and got it working.. I have a techstream software but it does not work with the OBDII adaptor that i have.. Will have to get the mangoose obd II scanner..
