Seat Heater Install
Mijfwb23
Decided to do my first mod to my 2010 TR4 5th Gen Trail.
I decided to go for heated seats as I felt they were cheap to install and feel good after along day of snowboarding.
I went with this one Amazon.com: WarmSeats Seat Heater: Automotive
As for the install I would say that it went pretty good, no major hicups other then it took longer then I thought. I was being very careful taking everything apart and made the whole install without breaking a clip or scratching anything. My only mistake was drilling the holes for the switches, the drivers side one is a little off center.
I did the passenger seat first and it took me 5hrs to get it installed and working, the driver seat took only about 2hrs. If I did it again I could definitely do it faster, I was being overly careful on the first seat.
There are two unused ignition powered fuse holders in the fuse box so that worked out perfectly. I would have rather hardwired them directly into the fuse box but I didn't want to get into tearing apart the fuse box.
As for the seat heaters and how well they work. On the high setting they get pretty darn hot, I like the low setting for normal use.
This is my first mod so if anyone has any questions feel free to ask, I will help however I can.
The best advice I can give is download the repair manual being offered on the forum, it helped me a ton. That is why I didn't break any clips, I knew were they all where.
Excellent mod! Do you have any other detailed pictures of this along the way? Getting the seats out/apart? Running the wires for the heated seat switches?
congrats on the mod. I've always been a bit weird about seat heaters. Seem to make my feel like i need to #2:hatsoff:
I have some, I will add them when I get back from work tonight.
Getting the seats out was the easiest part just 4 bolts, unplug neg batt cable, wait 90 sec(for airbag), disconnect under-seat plugs, then pull seats out.
As for the wires I ran the passenger wires through the center console, behind the heater control panel, over the steering shaft then to the fuse box. The switch just taps off the main harness and was really easy to route.
The drivers side I ran under the left door jam, kick panel, to fuse box. There was just enough cable to run the switch into the center console.
It is really easy to run wires under the carpet and to remove panels on this truck.
The only thing I didn't like about this kit is that it tells you to remove the tape on the back of the heaters to stick them to the seat foam but mine didn't have tape. I had to use the silver tape to affix it, which worked fine.
Also the seats come apart in only a few minutes. The bottoms were harder to do because you had to remove the hog rings to do a whole seat pad. I posted a pic of the seat heater on that one. The back was really easy just 3hog rings on the bottom, unzip sides, then cut to fit pad and shove in and tape in place.
Again I will post the pics tonight, I don't have many more but I will post what I have.
Get the manual it was a life saver. http://www.toyota-4runner.org/5th-gen-t4rs/65237-tis-fsm-2010-4runner-here.html
Great job! I wish the leather sets in the 2nd row came heated from the factory. Thing feelsl ike ICE when it's cold... lol Looks like you had fun!
:reddance:
Great write up.
I always used to think seat heaters were silly, until I got my first car with them. Now they pretty much stay on in the winter and I turn the heat down.
I've now had 3 cars with heaters and I'd miss it in the winter.
:reddance:
I am sure you could install them in the 2nd row, you cut them to fit anyway.
Glad you all liked the writeup I will try and post more pics later tonight.
Again thanks Nashman69g your manual really was a great help.
Here are the last of the photos I took. Sorry after awhile I got too involved and forgot to take more photos.
I just have a couple more questions before tackling this on Saturday.
1. How do I get the center console taken apart so I can get to the switch blanks?
2. I am installing the seat heaters and some new wet okoles and I cant think of any reason to remove the seat cloth when I can just tape them to the inside of the Wet Okoles. Can anyone think of a reason not to got this route?
My suggestion is to get the manual from Nashman69g it is easy to find just go to the Mod section and it is located at the top, and it will walk you through the entire process of removing the console, also if you go to the section for factory seat heater replacement it will take you through tearing the seats apart also. It is easy to do but me explaining it and you actually seeing pictures makes a big difference. Good luck.
Sorry for the dumb question, but I have to confirm. Leather seats required, or will the waterproof fabric seats work with the seat warmers?
I have heaters under my "water proof" seats. Works just fine. Leather is definitely not required.
