Found- Accent LED's that match dash color
Antman
Just wanted to let you guys know that I found a really nice accent LED that matches the dash color perfectly. I just used them to put cupholder lights in and they are perfect- not too bright, but provide a nice wide beam that works perfectly to gently light up a dark area( I know :worthless, I will do a writeup on the install next week). I plan on using them behind the door handles and in the little cubbyhole under the HVAC knob. LED is :Linrose B4304H3, and you need to solder a 1/2 watt 680 ohm resistor onto the anode (long) side to make them work with 12v. I got them at a local electronics store, but I googled them and you can pretty much get them anywhere. They cost like .60, and the resisters usually come in a pack of 6 for like 3 bucks.
