Wider Tires for 2011 LE
surfratsteve
Swapped out the OEM tires for some Bridestone Dueler H/T 275/55R20's. I love the new look, tougher but not over the top - what do you think?
Surfratsteve - Those are perfect. Do you gave closer pics of the tread. Also, is the tire size actually P275/55R20?
First I've heard of anyone wanting the Duellers, but all that matters is that you are happy with them.
No rubbing at all and the Duelers had good ratings so I thought I'd stick with them. The P275's do have a more aggressive tread pattern which is better suited to the truck in my opinion. I guess you have to see it in person but it really does look better than the OEM width. If anyone's in San Diego I would be happy to show it!
Nice... Maybe all the negative reviews and experience with the Duellers were only common with the 17" wheel sizes.
Here are a couple more looks, yep they are P275/55R20:
Looks good Steve! I think those are the H/L Alenza's, correct? They're pretty highly rated in Tirerack.
I think the lighting in the pics is a bit deceiving - you can tell in the close-up pic how the extra width fills up the wheel well a bit better.
As for the 7 vs. 7.5" wide wheel, you're right at the cusp, so as long as you keep them properly inflated (34-35 psi) and don't drive the truck like you stole it, you should be fine.
Enjoy!
R
Just curious... how much were they and were you able to trade in the OEM tires?
R
They were $198 ea plus installation. I had to buy another set the dealer would not swap them (the original ones used at that point anyhow due to the factory test drive, etc.). I actually had the new ones put on at Discount Tire.
Enjoy!
Yep they are the H/L Alenza's.
Talked to dealer and Discount Tire they both said they were fine.
i wouldnt trust the dealer or tire installer fyi. go to the manufacturer website and give them a call and see what they say. better yet, go to tirerack.com and get their opinion..
Bridgestone Dueler A/T RH-S
here are the specs for tire you chose. the MIN rim width is 7.5 inches for this tire. So you are squeezing a larger tire onto a smaller rim, which is unsafe. not going to get into a spat here, but too many people here have done what you have done and it could potentially lead to a serious accident.
