LED kits for 5th generation 4runner(Help needed)
By my estimation, I sent packages out friday so everyone who paid should have them today(monday)
Pls install and take pics!;)
Also, sending pm's to spots #37-44. If I happen to miss you the first time around pls bring it to my attention because I am notorious for messing up the copy and paste lol
I am also aware that there are people that are on the list, gotten payment requests, and still have not paid, you can still pay for your kit!:)
Received mine this morning will install later today. Also sending you a PM.
Tips and Tricks...
I have a favor to ask, which might benefit everyone doing this mod..
Can the forum members who have done this mod provide some instructions on how to remove the various light elements to replace the bulbs. It might be a breeze for some, but for people like me, it will save a ton of time and possibly bucks, if the experts can provide some instructions.
Personally, I would hate to take a screw driver and force something off that will break if I do it the wrong way...
Thanks!
Just thought that for buyers you could provide the details of the bulbs and source for future replacement. I was thinking of getting a red bulb map light replacement. TNX
Got my request for payment and will do so tomorrow but first a question.
I see above that you have red (and i assume other colors?). What is the price each for colors that would fit either the map and/or dome/hatch lights?
Also still nothing on reverse lamps?
thanks!
Installation Done
Spoiler: No installation or finished pictures for those looking, but some tips to make your install go a lot quicker.
<a href="http://www.flickr.com/photos/mbw163/6383587997/" title="pic 2 by mbw163, on Flickr"><img src="http://farm7.staticflickr.com/6095/6383587997_5dc64bd6de_z.jpg" width="480" height="640" alt="pic 2"></a>
<a href="http://www.flickr.com/photos/mbw163/6383585901/" title="pic 1 by mbw163, on Flickr"><img src="http://farm7.staticflickr.com/6096/6383585901_3bdbe45ffe_z.jpg" width="640" height="629" alt="pic 1"></a>
Disclaimer: Probably should put one of these here just in case. Use this as a reference, even though it is wordy and has no pictures. I do provide links that have pictures, so it makes up for the lack of pictures in this post. You are responsible for your actions... yadda yadda...
Note: This was done on a Limited with no TV system. It has the traditional middle row dome light and the two lights on the rear hatch.
Note 2: The LEDs are sensitive in which way you put them in (positive and negative). If they don't light up when you put them in just take them out and switch the way you put them in. I don't think putting them in the wrong way will cause any damage, so don't worry about it.
Note 3: Pink wire connects to pink and White connects to White. I used 3 of the connectors. You will understand when you get the package.
Tools Needed:
Flat Head Screwdriver (thinner the better)
and/or
Paint scraper tool
Both of these are just used to pry open the plastic coverings to get to the light bulbs.
All right, so I received my order today from USPS this morning and I installed them this evening. I ran into a minor snag initially and contacted so_LED, and his response was immediate! Great service from him and shipping was quick too since he said he shipped them out on Friday (West to East coast)
I received 13 LEDs in this package and 9 connectors in a ziplock bag. Out of those 9 Connectors I only used the ones that looked like glass fuses. Maybe so_LED can chime in, but I think you only use 3 out of the 9 supplied connectors.
I did not install these from front to back, so what you read next is going to jump around.
4 LEDs for the doors (SR5 might not have these)
http://www.toyota-4runner.org/545938-post1.html Philsey for Reference
Out of all the LEDs that I installed, the 4 door LEDs were the easiest for me. All you need to do for these is just take your screwdriver or scraper and pry open the plastic covering. It will pop out and you can disconnect the light from the source. When that is done, you take the screw driver and press it against the plastic latch to let the covering free to gain access to the bulb. It's kind of hard to explain and I know pictures would help, but I was too occupied to take pictures at the time.
2 Rear Hatch Lights
There are two of these lights in the rear hatch and you will use the two smaller LEDs with the 3m tape. You can pry these lights open by taking your screw driver and pushing against the side of the plastic. FYI, I opened the rear hatch to do this and was standing where the gas cap was on my right. The light furthest from the gas cap is pryed open by taking the screw driver and pushing against it on the right hand side of the rectangular shape. There is a golden metal clip that holds the light in place. If you unlatch that, the light will pop right out. Use the smaller LED with 3m tape and the glass fuse looking connector to install the LED. Again if the light doesn't work, swap the way you put it in.
For the light closest to the gas cap, you pry at the same location as the other one.
I remember someone posting a picture showing which direction, I tried searching and posting it as a reference, but came up empty handed. If you find the link tell me and I will update this...
6 LEDs down and 7 more to go!
1 Middle Dome Light
This one gave me the most trouble, because I tried prying the whole housing off and the pink and white wires on the glass looking connector fuse weren't securely touching the metal ends. (This was probably a fluke from the manufacturer, because the other 2 for the rear hatch were perfectly fine)
For the middle dome light I used the largest square LED with 3m tape. Pink with pink and white with white.
Tip: For me, the white wire side went in on the right hand side and the pink went on the left.
You do not need to pry the whole housing off! Just go at the clear plastic piece and it will pop right off.
2 Center Console Map Lights
Follow the instructions here by Enduro
I used painters tape and it just worked fine. Wiggle the light bulb out and you won't break it.
2 Side Mirror Puddle Lamps
Snooperstyle and Philsey have this one covered
Link 1
Link 2
Note: These two are probably the most daunting out of all.
As they said, 3 fingers will do with some force. I managed to break one of the clips on the mirror, but its still sturdy after putting it all back together.
Depending on the screw driver you use, you might need to move the motor downwards to gain access to the screws.
2 License Plate Lights Optional @$4.50
2 screws hold the light together. Easy access!
You might notice that the housing stamped R is actually on the left and L is on the Right.
When you put the LEDs in, it will put light away from the plate, but will provide enough to light it up. In other words, the LEDs aren't directly focused on your plate, but since these LEDs are multidirectional ample lighting will be focused on the plate.
Snooperstyle modded the way they were pointing by splicing the wires. I didn't feel comfortable doing this, so I left it and I think they just look fine.
Read the second paragraph
Mtn. Rush also chimed in on this issue and says that they should be like that as there is a diagram in the manual.
Reference to Mtn. Rush's response
Ending Bits
That should be all 13 LEDs that I installed. For those of you keeping track, the only lights left for me to change are the 2 visor mirror lights (vanity mirrors??).
Sorry for the wordiness and the lack of pictures. I know pictures would have definitely helped, but I think some of those references I posted will get you through.
Misc reference pics from Snooperstyle
Thanks to so_LED for setting up all of this for us and Jayhawk for testing the kit out! I'm sure that these LEDs will be as dependable as the vendor selling them and his tester.
Thanks to Snooperstyle, Philsey, Mtn. Rush and Enduro for their input about replacing the light bulbs in the other thread!
This isn't the best write-up, but I hope it provides an insight for those installing or planning on installing in the future. PM me and I will fix or add anything that would help others out!
all went great, except for the map light bulb that exploded on me. Thank goodness I need reading glasses. The bulbs really make a difference. I really like the amount of light from the middle dome light. It just started to rain, so I'll have to get pictures later. good job putting this kit together.
Spoiler: No pictures tonight for those looking for pictures, but some tips to make your install go a lot quicker.
Tools Needed:
and/or
Paint scraper tool
More to come....
Thanks for that Mason! I saved a copy of that in case someone needs instructions:)
thanks!
Nothing on reverse lights yet but I do have green, blue, amber, yellow and red for the interior kits but I only stock the white. On my next order I will stock up 2 sets of each color
Currently I can do map lights but since they are colored panels and not bulbs, it will be an extra $5 to add onto any kit
I have a bunch of red panels for map, dome and hatch lights(3 sets)
Woah be careful! That happened to me, stupid oem glass bulbs:roadkill:
^^^^ Yes... Warning to those out there replacing the Map Lights...
Follow the steps done by Enduro seen here
Having little pieces of the light bulb shattering while you are looking up at it isn't the best for the eyes.
Wear glasses or safety goggles if you are that accident prone or just cautious.
I can do that later.
Also, Mason - both rear hatch lights are pryed from the same side. Drivers side of the vehicle.
I only had a wonder about the middle dome and rear hatch lights. Since they are LEDs on a board, how or what to stick them too? They do come with nice sticky rubber on the back of them.
Or at least post pic of which lights go where as none were labled :confused:
