2010 Daystar 1.5" Rear spacer part number?
sporty87
I want to raise my 2010 4Runner SR5 rear with a Daystar 1.5" spacer but I called Daystar to get the part # so I could search, but was told that they do not make a rear spacer yet for the 2010-2011 4Runner. I see on this forum that people have the daystar 2.5/1.5" kit installed on their trucks. Can anyone tell me what rear spacer part # they are using on their 2010 SR5's (Is it an FJ Cruiser part?).
Thanks.
The Daystar 1.5" rear spacer part number is KT09127BK. It is for FJ Cruiser but fits the 5th Gen.
I too only had the Bilstein 5100 set at 3rd notch (supposedly 1.75" height on average). The vehicle front appears to be slightly higher than the rear and decided to add the Daystar 1.5" spacer.
Thanks, ct221933. When you added the Daystar 1.5" rear spacer did the rear now become higher? The idea behind the Bilsteins set at 1.75" was to level out the truck but if you look at the rockers you can see that the rear is lower. I was thinking about machining the spacer down to 1" because I really don't want that not leveled look but a little higher in the rear would be good.
Thanks
I set my front 5100's at .85 and the truck looks nearly level, with just a very slight rake.
