ANTMAN'S Thread
When you cut and folded the wrap up underneath the hood, did you just adhere it to the underside of the hood? How much excess is on the underside?
Been wanting to do this, just been a little weary of it having a trail hood and working around the scoop with it. Also, did it require any kind of solution to be sprayed on under as you applied heat? Thanks.
I will probably be wrapping my TE hood next...:)
The film is a completely dry application. Basically we pulled the backing off, each grabbed a side and pulled it tight while placing it on the hood. Then the squeegeeing madness starts. Every time we got to a really wrinkled section I thought we messed it up, but a little heat and stretching and it was perfect. I would have done a more thorough how-to, but the experts would have laughed at our fumbling!
I know Gary (Harper7) sprayed some adhesive promoter under his hood to make the edges stick better, we did not.
We cleaned the area under the hood really well and trimmed it about 1/2-3/4" around the hood. Then we pulled and stretched it around. I went around the inside of the hood a few times and pressed it into place firmly.
It seemed to stick great- time will tell.
I'm very tempted to try this now. How are you planning on doing the hood scoop?
I had planned on pulling it over the hole after removing this insert, sticking it to those edges and pop back in the insert.
I just remembered that there was a guy at the FJ Summit that just started his own business making carbon fiber hoods for the FJ. Anyway, he had a Rigid SR mounted in his hood scoop with a RGB LED strip reflecting into the Rigid reflector. Like Ducmonsta's halos, he could change the color to whatever he wanted and create different effects like the scanner effect or strobing. Not exactly my cup of tea, but definitely a clever use of the Rigid SR for reflecting the RGB LED strip!
Yeah- that's how I would do it, and maybe plastidipping the insert and see how well it matches. The insert would not be easy to wrap! I may have some slightly different plans though.
Seen that already about 1000 times. Isn't it awesome?! I told Kraeken that was my plan for the scoop.
The Tacoma scoop is taller though. The Rigid's are 1.5" tall, and our openings are about half that. Not saying it won't work, but it may require some...creativity...lol.
I hadn't thought about Plastidip. That may work really well, but I haven't seen the 3M stuff to compare to my plastidip. I had also thought about leaving it silver to see what it looked like.
EDIT: Well, Amazon just got the best of me yet again. I've got some 1080 Matte Black, a heat gun, and a felt sqeegee on the way.
wow..I am so jealous right now.....any fine fellow forum members want to swap a TE hood with me?? black!! hahahahaha......we can all dream right!!?!!!
** ANTMAN Eyebrows :naughty:
I had a little free time in the garage today, and planned on wrapping some chrome strips with the left over 3M matt black vinyl from Kraeken's hood.
Go figure- the scraps we had left were just a bit short, and I wasn't about to splice it. I started to look for other things to wrap and decided to do the headlights. I did this a long time ago with some plastidip but it never looked quite right, and wasn't durable enough for this area.
I know somewhere on this forum I saw someone else had plastidipped their lights too- can't find the thread though...Anyway-
Basically, I took some paper and taped it on top of the light bezel and traced around the edge with the side of a crayon to get the rough shape. After a few adjustments, I had a template that I could tape to the vinyl and cut out with a pair of scissors. Only need one template- just flip it over to do the other side.
To install the film, remove the backing and carefully line up the front edge. Make sure it's smooth all the way around (fingers and a felt squeegee work great). Then carefully trim some of the excess from the back side (the top of the bezel). Heat small sections with a heat gun (careful, just a little bit!) and squeegee towards the back. With practice and patience it will work out perfectly.
It toook me 3 botched attempts to get it right.
After the film is adhered to the top of the lense, make sure the corners are crisp, trim around the light housing and wrap it around the edges. Pull the rubber weatherstripping back and tuck it in there. Done!
If anyone wants to do this, PM me your address and I'll mail you an Antman Eyebrow Template.:thumb3:
Here are some epic photo's...
Before:
DSCF1441.jpg~original
DSCF1440.jpg~original
After:
DSCF1445.jpg~original
DSCF1446.jpg~original
More pics:
DSCF1439.jpg~original
DSCF1437.jpg~original
Outside in the sun:
DSCF1447.jpg~original
DSCF1449.jpg~original
DSCF1451.jpg~original
DSCF1450.jpg~original
DSCF1448.jpg~original
This is what it looks like...dirty! :lmao:
The film also blocks the sun from shining into the lense and the lights have a darker look in bright sunlight.
Subtle, but noticeable, and it should last!
I'm pretty happy with it- what do you guys think?:confused:
Hey Antman, I love all the things you've done. That headlight mod also takes care of the fogged headlight issue.
It looks like your new subwoofer interferes with your shelf you built, or have you mounted it flat now?
Off to go do the fog light mod. :thanks:
Looks nice, I think Toyota should have done it from the beginning. They definetely need to include your mods in next 4Runner generation : )
I no longer have the shelf- someone on this forum decided they liked it more than me! ;):
Do you have enough vinyl left over to do those two screws in your front bumper?
Oh yeah, love the lights.
Yeah- those screws are pretty ugly. You should buy me some flush-mount Rigid LED's to cover them up! :hiding:
Thanks everyone for the compliments!
** ANTMAN MOD#10
Outside light switch install (Antman Porchlight)
After checking out Jango's super-fast moving build thread with all his switches (I lost count at 10...) I got to thinking about some stuff.
There are lots of times when I'm camping, or launching my boat at night when I use the lights on my Gobi rack. Sometimes unlocking the doors and reaching over to the center console switches is a PITA.
Enter the outside light switch. With a single switch I can power the 4 front, or 1 rear Hella rack lights at any time from outside the 4Runner.
I had a few requirements for the switch. Had to be waterproof, totally concealed yet easily accessible.
I thought I had found the perfect spot, drilled the hole and installed the switch. Luckily, I realized before I buttoned everything up that the switch was in the direct path of the sliding rear window.:shrug: Had to start over.
In fact, the window is the sole reason this MOD is time consuming and required a lot of thought. Wire routing out of the window's path is critical. The wiring path is...circuitous, but along the same path that Toyota deemed safe.
Here's the MOD!
Gotta take the hatch panel off. Start by prying here.
DSCF1496.jpg~original
Leave the panel attached at the window channel and reach in there to unplug the lights
DSCF1497.jpg~original
DSCF1498.jpg~original
Now pull the panel off and here's what you see.
DSCF1499.jpg~original
I decided to hide the switch in the recess of the hatch handle. To see what I'm talking about you must remove the rear garnish. Pull the clear plastic covering off of the hole. You can press it back into place if you are careful!
Before you remove the garnish, rig your tailgate so it won't latch shut. Yeah, I had it latch shut on me...twice.
DSCF1509.jpg~original
Unplug these electrical connectors first. Note- the small plug is for the camera and doesn't need to be removed to pull the garnish off. However, when you drill the hole for the switch it will be in the way and you do not want to drill into the wires!
There are 6 10mm nuts to take the garnish off (2 of the nuts hold the lock tumbler/switch).
DSCF1506.jpg~original
DSCF1507.jpg~original
DSCF1510.jpg~original
This is the back of the garnish.
DSCF1508.jpg~original
For my application I need a single pole double throw switch. The rubber cover will make it waterproof.
DSCF1493.jpg~original
DSCF1495.jpg~original
This is where I mounted the switch. Drilling a 1/2" hole in sheetmetal can be tricky! You don't want to "rip" the metal. Start with a punch and work up to progressively larger bits. Any bare metal was painted to prevent rust.
DSCF1518.jpg~original
DSCF1519.jpg~original
The garnish was dremeled a bit to allow access to the switch.
DSCF1514.jpg~original
Time to wire. The center of the switch will go to +12V power ( I tapped into the red wire for the hatch lights). One outside terminal will go to the front light relay trigger, the other to the rear light relay trigger.
Like I said- routing is critical here. The window fills the void when it's down. Follow the factory path, even though it's a PITA. I got a little pissed and forgot to take all the pictures!
Word of advice- remove both speakers, and the plastic pull handle on the drivers side to make things easier.
After you follow the factory wiring across the inside of the hatch, it travels through a grommet to the outside of the hatch, back across and through another grommet to the inside again. Fish the wire up the hatch to the rubber plug that leads into the truck. Lots of patience and swearing here. Any other routing method is asking for trouble later.
DSCF1523.jpg~original
DSCF1524.jpg~original
DSCF1525.jpg~original
You need to wireloom these!
How to properly loom wires:
Bundle your wires and tightly wrap (stretch the tape) a few times with electrical tape.
DSCF1520.jpg~original
Pull tape straight and slide the slot in the split loom over the tape. Then continue wrapping the end of the split loom with the tape. This method prevents the loom from coming apart and sliding off the wires.
DSCF1522.jpg~original
CONTINUED
Anyway- There is no way to take a picture of the switch once it's installed! Here's how you reach up there to switch it...
DSCF1529.jpg~original
WORKS LIKE A CHARM!
Switched left, it turns on the front lights.
DSCF1528.jpg~original
Switched right, it turns on the rear light.
DSCF1527.jpg~original
That's it!
Happy Modding!
Great Mod and I am amazed that you did not use a hole saw! Just a drill bit and dremel.....very nice. I do have to say, however, that unless the washer behind the nut which tightens the switch unit to the sheet metal is made of rubber or the like, I do not think you are "water proof" yet. Silicone? I am very doubtful any water will enter at your point of placement under the handle, but one never knows.....just a thought. Be Safe
Thanks!
The switch cover is for the marine environment and has a rubber seal along the bottom. As 1engineer would be quick to point out, nothing is waterproof, BUT- it's as water-resistant as anything else in that hatch.:boink:
