Well they should work. Please post up your info on others who have run into issues. Maybe they won't.....
Please note, I'm not deterring anyone from doing this. Actually the opposite. I've wanted to match these two kits for a while, but don't have the resources (time or money) to test it out myself. Plus, others who have tried this exact match either didn't get them to work or just didn't update their threads.
Based on others research the switch that comes with the kit is sourced from Audi/VW. Both are 5 position heat and one position off.
Now the following threads are specific to taking a high low off switch and making it compatible with the 4Runner switch. The main issues is the controller for the kit is not compatible to the OEM switch and the resistance found in the 4Runner switch itself matching the kit's switch.
Here is the full thread from the blue room I found when i wanted to do this mod:
Wiring Gurus Stock heated seat switch
After some failed attempts including a fried micro temp controllers the OP found a solution by creating a new circuit:
Post 45
Here is the quote he provided at the end:
"I have, but it required me to make my own custom controller that is compatible with the OEM switch.
The main problem is that the resistances inside the OEM switch verses the kit are not the same. With some parallel and serial resisters, you can get a close range to the kit, but something was still not right and it always blew the OPs FET transistor."
Although the switches are both stepper type switches and have the same positions, i have the same concern that the resistance found in the Rosta switch doesn't match the stock 4Runner switch. If it does, awesome. I'll be purchasing this kit this fall.
I just didn't want the OP, or myself for that matter, to purchase the kit based on a "should work" and I was hoping there was documented proof i could refer to.
Good luck to wvanstone or whoever is willing to try this!!! If you do, please update this thread so others can benefit :thumb3:
Cheers
