GOBI Ladder Install
alvorbn
I installed the ladder tonight. Ran into a few problems which might have been user error.
First, measure about 3 and 3/8 inches from the inner portion of the rubber roof gasket.
IMG_1484.jpg~original
Then line up the plate and pull it toward you and tape in place.
IMG_1485.jpg~original
Next, you lay the ladder on the plate and level it and mark it with tape
IMG_1486.jpg~original
IMG_1489.jpg~original
Then you take off the ladder and head back up to clean up the area under the plate and tape it down.
IMG_1490.jpg~original
This is where I had some issues. The directions say to pull the plate towards you so the metal bend catches the body work as you press on the double stick tape. The problem I had with mine is that the plate bend rested right on the tailgate hinge and in turn would not lay flat enough for the tape to adhere. I bended the plate a little which initially let it lay flat enough for the tape to stick but then when I lifted the tailgate, the plate lifted up again. This might be because I had to initially restick the tape to put the added bend in the metal once I noticed it, or because the metal was still hitting the hinge, I couldn't tell for sure.
This is after I bent it a little.
IMG_1496.jpg~original
Then it kicked back off.
IMG_1499.jpg~original
IMG_1507.jpg~original
Needless to say I continued on and for now it doesn't seem to make that big of a deal. Either I royally screwed up or directions are made to be broken.
Next, you clean up and tape the metal band on the inside of the tailgate and do the same with reinstalled ladder on the bottom.
IMG_1500.jpg~original
IMG_1502.jpg~original
Then you clamp everything together and finish off the bolts on the top of the ladder.
IMG_1506.jpg~original
IMG_1509.jpg~original
One other thing the directions aluded to at the end was the possible need for heavier duty tailgate struts. This was the first thing I noticed opening the tailgate. It noticeably did not spring up as quickly or as high, so I will definitely be getting those. Hope this helps.
Later
Is it me or does it look like you'll be kicking the tailgate at every step you take up?
Any any one added grip tape to the steps yet?
I'm considering the ladder but wondering how much use I would really get out of it (if I dont plan on gettin on top of the truck).
Thanks for the great write up and please keep us posted on the need for heavier duty tailgate struts. Does Toyota offer them?
Do most plan on leaving the ladders on day to day?
If you aren't going to be getting on top of the truck, why would you get the rack? Not being a smart ass, seriously just curious. If what you carry can easily be put on without having to get on top, then the OEM rack should be fine.
The OEM rack is useless if you have anything besides sporting equipment. I load all of my gear from the ground and then stand in the doors or on the tires to strap it down. Seriously, what are you going to do? Climb up the ladder with your cargo in hand?
Besides getting up on the roof what other reason do you actually need a ladder for? And don't get all butt hurt thinking I'm trashing the ladder because I'm not and I think it looks great and I want one. But besides climbing up on the roof everything you need to do can be accomplished from the sides and rear IMO.
I was just curious and I didn't think you were bashing the ladder at all, I thought your question was actually quite good and got me to thinking about it. My roof tent, need to transport heavier gear for treks and photography are the reason I got one, other than that I would have just gotten something adaptable and cheap to carry gear from Yakima or Thule.
Here are a few more pics. I don't have the directions in front of me, but as far as the struts go, the directions made it seem like you could "request" heavier duty struts from GOBI, but I have not confirmed this with GOBI?
I didn't notice any issues with my shoe (size 10) hitting the tailgate while climbing the ladder, but I would guess that is variable.
e12967c7.jpg~original
Sorry for the poor contrast.
4c36feca.jpg~original
192bd9a7.jpg~original
It helps us to have the rear ladder for our roof tent (helps in opening and closing it up, and adds an extra entrance/exit out of the side tent window if needed).
602fcc67.jpg~original
I had the Yakima and it wasn't big enough for my needs. It also sat to high and I just didn't like the way it looked. It looked like a addon wher the Baja seems like it's part of the vehicle.
I agree, sliders work better for loading a roof rack from the side than the ladder so i don't see much use in it in that sense. The only thing I see it being usefull for is to get up on top of the truck to hang out/photography/drinks/etc... With that said, I think the ladder looks great and would love to get one if I knew for sure that there would be enough room behind my rear tire carrier. Great writeup![I[/I]
Just installed my Gobi ladder. Love the look but what a pain! Took two months to finally get it and the instructions were super confusing...
Thanks for the great writeup!! Got mine today and will be putting her on tonight!! Maybe I'll take some good video and put it on youtube for others.
Later
This is on my list, thanks for the detail!
Thanks for the detailed write-up. I installed my ladder today and found this much easier to follow than the directions included by Gobi. I had zero issues and the install was a breeze.
