Changing Differential & Transfer Case Fluids - Pics Included
Hey Guys, I haven't posted much on here (bought my truck in February and came over from the Mazda forums).
This is a great thread, but I have a question. Amsoil lists a few options for the fluid. Exactly which one did you all use?
I use Mobile1 everywhere (except tranny). More expensive, yes. I've been using Mobile1 for YEARS and never experienced any kind of lubrication failure in any of my 10 cars/trucks/SUVs I've had since mid 1990s.
I honestly don't think the BRAND of lubrication is important, what's KEY is that one CHANGES them. There are people who NEVER change the front/rear diffs and TC let alone the tranny fluid and expect their ride to last over 200K miles.:confused:
It's great to see threads like this to help those of us who are active in maintaining their runner. :thumb3:
07-19-2010, 09:13 PM #32 (permalink)
aika1
Registered User
Posts: 14 these are the part numbers I got from the exploded dealership diagrams for a 2005-2008 4runner...
Transfer case fill gasket 90430-18008
Transfer case drain gasket 90430-18008
Front differential fill gasket 12157-10010
Front differential drain gasket 90430-24003
Rear differenyial fill gasket 12157-10010
Rear differential drain gasket 12157-10010
08-11-2010, 10:58 PM #33 (permalink)
d_clark
Registered User
Posts: 61 late to the party but thought I would add a few more part numbers
transfer case drain plug 90341-18006
Transfer Case Fill Plug 90341-18006
Transfer Case Breather Plug 90930-03172
Rear Differential drain plug 90341-18057
Rear Differential Fill Plug 90341-18006
Rear Differential Breather Plug 90930-03031
Front Differential Drain Plug 90341-24014
Front Differential Fill Plug 90341-18032
Front Differential Breather Plug 90930-03136
Oil Pan Drain Plug 90341-12012
Oil Pan Drain Plug Gasket 90430-12031
Why dont these part numbers match are they for
different years or what ?
:rockthrow::rockthrow:
They don't match cause they are different parts.
the post by aika1 is for the gasket itself. The list I posted was for the PLUGS. I did not post the gasket numbers (except the oil pan )since they were already posted. I added the numbers for the Plugs incase somebody needed to replace a rounded /stripped plug.
Amen!
Ok, i just got back from the toyota dealer and bought 2 crush washers for a whoppin 3 bucks. i was shocked that it didn't cost an arm and a spare tire. Next went over to, ugh, pep boys, and bought me 4 bottels of Mobil 1 75-90.
Not sure if I will use all of it or not. According to the spec sheet I am looking at right now it says 3.17-3.27 US quarts or 3.00-3.10 litters. I am going to say safe on this one with having 4. At least I will have some extra sitting around.
Now I just need to get a dang socket that will fit. My set stops at 7/8" and 22mm!!!
Guess this means another trip to Harbor Freight.
Did this today and it went very smoothly thanks to this great writeup! Bought a torque wrench and everything so I'm good to go!
My front differential was the dirtiest, so I think the rear had been changed before, but the front never has. I'm at 77,000 miles and there was a considerable amount of metallic sludge on the magnetic drain plugs on both the front and rear differentials, can't wait to see how the new synthetic Mobil One feels!
Ok so i hate to sound stupid but is there really need to use a torque wrench? I have always tightened bolts with a wrench for everything and have never had a problem.
I'd say if you have one use it. I didn't use one until I changed my plugs - there was no way I was going to just guess with those. Now that I have one I use it for things like this but I didn't bother when doing my suspension bushings for instance.
Maybe I missed it in this writeup but I couldn't find where each specific washer was actually used? It would be sweet if snowbizx could list the part numbers /washer description after each photo on his first post. That would be super helpful.
I finished the job anyway using the Toyota OEM washers and ended up with one washer at the end that didn't fit the rear diff fill port/nut. I had to reuse the old crush washer on the fill nut.
Note to the guy above asking about the torque wrench. I got one for around $50 specifically for this job. It was interesting to "feel" how little the torque was on some of the nuts when using the wrench. You would be surprised and if you are like me - probably over twisting by hand! It is one of those things that when you use it, and it "clicks" at the correct setting, you know you did the job right.
Edit: my bad here they are - just make sure when the parts guy collects them from the back parts bins at Toyota that they separate and identify them by part number.
Front Diff Drain
9043024003 (x2)
Rear Diff Drain
1215710010 (x2)
Transfercase Drain
9043018008 (x2)
Oil pan drain
9043012031 (x1)
Rear diff drain and fill; front diff fill:
IMG_1806.jpg~original
Transfer case drain and fill:
IMG_1809.jpg~original
Front diff drain:
IMG_1811.jpg~original
I changed both differentials and transfer oil today. Went with Royal Purple 75-90 in all. Rear diff was little dirty, front- really dirty but transfer case was as clean as brand new oil. I noticed transfers old oil was thin almost like motor oil, so I'm glad I changed it to correct weight. I used all new washers except trans case where I just reused flat alluminum ones.
I just did My transfer case and rear fluid differentials. Unfortunately I stripped the Hex nut on the front differential, wish they would have used bolts, I had hex nuts ugh.
Anyone know what the part number is for the front differential Hex nuts?
On page 3.
