livetoride
Looking for new tires and would like to know what is the largest size of tires I can get on without rubbing.
I thought it would. I have 17" rims, so would 265/75/17 be fine? Thx
:lol:
I think that the question you SHOULD be asking is
"what are the biggest tires i can put on my stock rig and NOT rub BADLY on the trails when I go offroad and try to flex my suspension --which I will need to do in order to make it up the trail"
The answer is 31" or 265x70xR16 - IMO
...265/75/16...Looking for new tires and would like to know what is the largest size of tires I can get on without rubbing.
...No...I thought it would. I have 17" rims, so would 265/75/17 be fine? Thx
Rockdawg has 35s stock. Lol I don't think can even turn.
While the general consensus is 265/75/16 there are some exceptions.
No, the general consensus is 265/70/16 not 75 unless you want major rubbing on the trail with your stock suspension. The rubbing can make you worse off than with the smaller tires because you can't go up the trail due to flex rubbing.
Other than that sorry to jump all over your post fellow San Diegan!
...265/75/16...
Bridgestone Dueler A/T Revo with UNI-T AQII P265/75/R16
Toyota 4Runner Highlander Tire Upgrade
J.A.
...No...
Miata.net Tire Size Calculator
Tire size calculator
So even if you have a 265/75/17 it wouldnt fit? Sorry if it sounds stupid but i dont understand how changing the rim size would effect it as long as the tire is the same size.
The reason i ask is because i have a chance to get a brand new set of 265/75/18's and i was thinking about getting an 18 inch rim for them. I have no idea if it would work or look good, just looking into it since i have the chance.
