5TH Gen Sub Cabinet
ChipG
I have been working on my 5th gen stereo install thru the winter and have started on a sub woofer cabinet to fit a JL Audio 8w3v3. This is a small sub for the size of a T4R but I have been working with smaller subs and getting great results.
Here are a few pictures of the progress. I still have to make a faceplate and upholster the cabinet.
IMAG0505.jpg~original
This is the foundation. The feet fit into the pockets on the passenger side rear of the cargo area.
IMAG0518.jpg~original
This is the back side, upside down.
IMAG0520.jpg~original
Front side. A faceplate will be installed so the woofer is recessed.
IMAG0523.jpg~original
Here is the fit in the car. The toneau cover fits above it.
The tie down D-ring will be used to secure the box.
ChipG
This was not a planed endevor
Sorry, I didn't create any plans. I back the truck up into the garage and fit & test fit and re fit each piece until I'm happy. The only thing I templated was the feet that fit into the 2 pockets. The nice thing about working with MDF is it's cheap, easy to sand, cut glue etc. I use a stationary belt sander to get all the bevels right.
The bad thing about working with MDF is it covers my garage and everything in it with dust.
ChipG
nice work!
I think your appreciation for excellent fit and craftsmanship shows in your post here. I look forward to seeing the finished product!
Awesome job. I was trying to figure out how to do it with wood but my woodworking skills are not that great. Instead I did a similar design, but with fiberglass. I'll post pics as soon as I'm done with the install.
Face Plate construction
I got a chance to work on the Face plate for the sub box this evening.
Hopefully, when it's all covered in vinyl, it'll still look good...
IMAG0531.jpg~original
IMAG0532.jpg~original
ChipG
I'm digging it man! Show us the updates as you do more, I am looking at doing that whole quarter trim piece in fiberglass but am scared to do it. I hate sanding, and I'm lazy. This looks like a good alternative.
Covering this weekend
Thanks for the comments.
I'm going to try and get it wrapped in black leather grained vinyl this weekend.
ChipG
Final Product
I got it done and, it looks awesome. Here are some photos of the final product.
IMAG0553.jpg~original
Stuffing the box w/ fiberfill and adding the speaker wire.
IMAG0556.jpg~original
Grade 8 bolt up from below. You've gotta pull the speaker to get the box out.
IMAG0551.jpg~original
View from the back seat.
IMAG0558.jpg~original
View with the Taneau pulled over.
A little more work - calculations
I did a little calculation to confirm I had hit the mark as far as volume for the sub. The JL Audio spec sheet says for a sealed enclosure, the Net volume is .335 cuft. this is the .3 they ask for plus the displacement of the woofer. I just exceeded that at .35 cuft. Here is the rudimentary method I use to calculate an odd shaped box like this.
First, you need a measuring device, a box 12" x 12" x 12" is a cubic ft. I only needed 1/2 that so my measuring box is 1/2 cuft or 12" x 12" x 6" inside dimensions.
IMAG0561.jpg~original
I used Pea Gravel as a measuring medium. Some use Packing peanuts but I don't think they pack down as well. Fill the Sub Woofer enclosure with the gravel and shake it into every corner so it's full.
IMAG0564.jpg~original
Now poor the gravel into the measuring box to figure volume.
IMAG0565.jpg~original
Don't forget to vacuum out the box before putting the woofer back in.
IMAG0563.jpg~original
ChipG
going a little bigger is ok for the sub, if its too small, its going to be punchy, atleast u got cargo space left, i dont with 2 15s.
ChipG, that is some mighty fine craftsmanship! I love it when people really push for the best they can possibly do, instead of just hacking something together. Beautiful work!
Thanks for the complements
I enjoy this kind of project once I get started. Planning it and figuring out how to make somthing fit where it's not supposed to and trying to make it look good.
Next project is to replace the front 2 way components with a 3 way set and figure out how to make it sound right and be invisable or factory looking.
