Tail Lights LED Project
AlexJet
I've been thinking of this project for a long time. First of all I want to say that this project is completely using stock Toyotas parts, so no warranty problems for those who concerning of doing modifications and loosing the warranty.
Actually I was thinking of doing this by adding some LEDs to the taillights housing, but after a few tries I found that they are not as bright as I want. After some time I found that cdoyle wants to do the same thing as I do, so I contacted him and we've been looking for some LED housing to fit OEM Tail Light housing. He has found one and has done this modification. At the same point I found that '06 model was going to come with LED tail lights, so I've decided to wait. After I saw the OEM LED lights I was so impressed that ordered them at the same day I saw them. After a week time they arrived.
Here they are:
So I opened them and there is the lights out of the box.
They have the same fixtures, so they PERFECTLY fit to original place.
LED lights out of the box:
I took of my old ones from the vehicle. It was simple just unplug the connector and then unscrew two nuts holding the light itself.
Here is comparison of both NEW and OLD tail lights:
Cool, have you installed them yet?
I bet a lot of people are going to be pretty happy they fit!!
Can't wait to see them installed.
:eek: Well it's good to see that they fit. My only concern now is whether the connectors will have to be changed or whether you will have to re-wire anything to get the LEDs to work. Keep us updated!
EDIT: You beat me to it, so you don't have to modify anything?!
Plug and play...WOW...
Well that does it, I'm ordering mine today.
Alex, can you give me a part # for these?
Thanks,
Marco
Finally done and on truck
After all I just reinstall the new lights to the truck back using the same procedure as I remove the old ones, in reverse directions, of course.
So now my truck looks like
Thanks,
Marco
I have to run for an appointment. I'll be back in a couple of hours and will post the part #.
Do you have any night shots of them yet?
I like how the 06 lens don't have that pinkish color over the turn and reverse sections.
That's awesome!
I'm glad to see it's an easy install. I was worried the wiring to the LED's was different! Thanks for trying it out and letting us know about it!
BEAUTIFUL! Thanks for a great detailed write-up; we all appreciate it. [And by the way, you are the man.]
Is the tail housing fastened with any kind of adhesive, or once you removed the bolts - it just came right off?
Erik
