Ousted JBL 10 Speaker System:)
airbur
Thanks again to all the members of this forum that take the time to post their setups. Here is my setup.
1 - Kenwood DNX7100
1 - PowerBass ASA-600.4 - 1600W Max, 4-Channel Amplifier ASA-600.4
1 - PowerBass ASA 1000.1D - 2000W Max, ASA Series Class D Monoblock Amplifier ASA1000.1D
1 - Rockford Fosgate Punch P2D48 - 8" Dual 4 ohms Punch Stage 2 Subwoofer (200W RMS)
1- Sony XS-V690HP - 6" x 9" 3-way Speakers (110W RMS)
1 - MA Audio MA6529 - Shallow-mount 6-1/2" 2-way Speakers (100W RMS)
1 - StreetWires FHXLO ANL Fuse Holder - 1/0 AWG w/150A Fuse
1 - Essentials 62010 Power Distribution Block - 1/0 AWG
Multi - P3 Platinum 1 & 4 AWG Power Terminal Pair
3 Sets - StreetWires ZN5235 - Zero Noise 5 11.5-ft. Stereo Patch Cable
2 - StreetWires UCT14 – 25’ 14 gauge Blue/Copper Speaker Wire
1 - XTC 6x9-inch pair Slim Speaker Baffles
1 - XTC 6-1/2-inch pair Slim Speaker Baffles
1 Case – Dynamat Xtreme Bulk 36SF=
15’ - 1GA Red Power Wire (Battery to Dist. Block) (PartsExpress.com)
10’ – 8GA Blue Power Wire (Dist. Block to Amps) (Streetwires)
10’ – 8GA Silver Ground Wire (Amps to Frame) (Streetwires)
i have my 2nd battery mounted in the same location
i used a kit simiar to this. I drilled holes down into my fender and bolted the plate in that location.
What did that mounting kit cost you? I looked around for one that would fit the optima with side battery posts but everything was really expensive.
Using a deep cycle battery will destroy your alternator.
Those batteries require a short long charge... alternators put out a fast charge. I know this because I'm my shops marine electronic expert... and I warn every customer who wants a deep cycle battery of this. Most marine companies won't warranty an alternator if a deep cycle battery is installed and connected to the existing system. And yes, mechanics can tell when an alternator has tried to charge a deep cycle battery.
Now don't get me wrong, they get the job done just as good and will last for an incredible amount of time especially if you get one with a high enough amp-hour rating. But do not try and charge them from an alternator because it will destroy your alternator! If you install it you need to isolate it from your existing battery and only run use it when the car is off and place a trickle charger on it at night.
hmm
my last 3 cars....multiple amps deep cycle batteries...stock alternators
no problems???
cmar said:
I like how your sub is, was it expensive to get it custom like that?
Thanks. Actually, it was very cheap since I did the work. All it took was removing the stock sub enclosure, cutting a ring out of MDF, glue, screws, and mounting it back up again. Not hard at all.
I'm still looking for some nice trim to wrap around the edge of the stock grill I had to cut out.
Realized I could use the trim ring that came for the front of the Fosgate sub....fit perfectly...
Would you happen to have your stock HU for sale? I have a 2004 with a broken CD player and would like to replace it -- I am content with the sound, since I'm usually on the phone anyway!
I do still have the stock JBL 6 disk HU in perfect condition. Interested?
I PM'd you last week, but I'm not sure you received it? I am interested. Just need to know your price and perhaps get a picture of it so I can make sure it is the same unit. thanks!
Here's pics of the old JBL 6 disk unit....
