Audio in my Limited
Limited2K
This is my audio setup. No competition setup here, but it actually does really well. Head unit is a little beat up, but it's been a good one for about 3 years now. I have the ipod adapter that allows control from the HU.
This is my custom box. It is a 10" Kicker CVT that I had bought to go under the back seat in my old Chevy. It's shallow mount so it worked really well here also. It's a 2 ohm single coil setup. Many people are surprised when I tell them it's just one 10". I will never buy another sub except for Kicker. It has been the best and I've been through quite a few.
A little customization to match the woodgrain elsewhere. The box fits great and with the grill cover it keeps the storage space really usable.
My amp fit like a glove in the storage compartment. I used the straps and a bar to keep it in place so I didn't have to permanently mount it. It's a class D so the tight quarters isn't as issue. It's wired for 2 ohms 350 watts rms to the sub.
I do have the front speakers replaced with Infinity reference 6.5". It turned out really well, and much better than the stock setup. Still need to replace front tweeters and the rear door speakers.
Looks good! And it all tucks away nicely under the tonneau cover.
I'm currently working on my false-floor amp rack and storage drawers. Well, I was before it got so damn hot here! I still don't know where my sub is going to go. It might just have to float for a while, until I figure out where I want it. Ideally, I would build an enclosure in the storage compartment area. Fiberglass and birch ply. I'd like to try the SI BM mkiii in that spot.
Thanks! I've seen a few really good looking enclosures using the storage compartment. I haven't heard of SI but it looks like it will fit the bill since using that compartment would yield less volume. Keep us updated on what you end up going with. Sounds like it's going to be a great setup once you get it finished up!
limited 2k - Nice I like it, thats all i would need. I also like how well you hid the AMP looks like a great spot. Any overheating issues with it in there?
Nope, no overheating issues whatsoever. It helps that it's a class D mono block amp so it puts off less heat.
