Old 02-10-2016, 12:14 PM #1
C4 Fabrication's Avatar
C4 Fabrication C4 Fabrication is offline
Real Name: Caleb
C4 Fabrication has a spectacular aura about C4 Fabrication has a spectacular aura about
Real Name: Caleb
Install Instructions: C4 Fab Rock Sliders
If you are installing a fuel tank skid with the sliders or already have a tank skid, the sliders will need to be installed first, then the tank skid will fit on top of the rock slider frame mounting plate.
Here is the link to the install instructions on our website: https://cdn.shopify.com/s/files/1/03...f?v=1584660064
For all of you guys with KDSS systems, we have not had access to a KDSS 4runner yet to do an install and take photos. Basically the sliders install the same as the regular sliders. The only difference is that you need to un-bolt the KDSS hydraulic lines from the side of the frame rail and pull them away from the frame far enough to fit the rock slider frame plate up behind them. Then the KDSS lines get bolted back into the same location as before using the 8mm bolts provided by us.
Here is a good link with pictures for the KDSS guys: How to: Install Rock Sliders with KDSS - Toyota 4Runner Forum - Largest 4Runner Forum
Owner/Operator of C4 Fabrication. specializing in custom built Toyota off-road products.www.c4fabrication.com
C4 Fabrication is offline   Reply With QuoteReply With Quote
Old 03-21-2016, 08:53 PM #2
Cymon's Avatar
Cymon Cymon is offline
Real Name: Chris
Cymon is a jewel in the rough Cymon is a jewel in the rough Cymon is a jewel in the rough
Cymon's Avatar
Real Name: Chris
Originally Posted by C4 Fabrication View Post
Hey everyone, we have been working on getting install instructions put together for our current products. Here is what we have for the rock sliders right now.
I know you posted these about a month ago and seeing the installation prior to buying is super helpful. Just in the process of convincing my accountant (aka the wife) that I need these. Keep me/us informed on the next time you're doing discounts or any type of specials!
2015 SR5 Premium 4wd Magnetic Grey w/3rd row: Frontrunner Slimline II 3/4 Rack - Yakima Skybox 16 - Weathertech - 22" Behind Grill Light Bar - TRD Skid w/Full Aluminum RCI Skids - RCI Sliders - Falken AT3 265 SL - Lamin-X - Taxa Cricket
"If I Can Do it You Can" Light Bar Install
ARB Breather Mod
Cymon's Weekend Warrior/MFD Thread
Cymon is offline   Reply With QuoteReply With Quote
Old 03-22-2016, 01:53 PM #3
Real Name: Caleb
Real Name: Caleb
Thanks! we are talking about doing a group buy on sliders in the near future
Old 03-22-2016, 02:40 PM #4
Cymon's Avatar
Real Name: Chris
Cymon's Avatar
Real Name: Chris
I'll start buttering up the accountant now.
ARB Breather Mod
Old 03-24-2016, 10:52 AM #5
Real Name: Caleb
Real Name: Caleb
haha, sounds good!
Old 07-11-2016, 12:06 PM #6
Real Name: Caleb
Real Name: Caleb
Here are some photos of a few additions we have made to the frame mounting plates. The plates now wrap around under the frame to provide a stronger mounting plate and more bolt locations.
http://www.toyota-4runner.org/attach...372%5B1%5D.jpg
http://www.toyota-4runner.org/attach...381%5B1%5D.jpg
http://www.toyota-4runner.org/attach...382%5B1%5D.jpg
http://www.toyota-4runner.org/attach...389%5B1%5D.jpg
http://www.toyota-4runner.org/attach...386%5B1%5D.jpg
http://www.toyota-4runner.org/attach...388%5B1%5D.jpg
For the passenger side forward frame mounting plate that attaches to the transmission cross member, you will need to drill two holes for the thread cutting screws to thread into.
-You will want to perform this step last.
-Once the slider is all bolted into place and tightened down, drill a 5/16" hole through the cross member at each hole location on the mounting plate.
-Once the holes are drilled, you can use a drill with a 9/16" socket attached to it to thread the 3/8" thread cutting screws into the frame. Spraying a bit of WD-40 or tap lube onto the bolt first will help it thread into the frame smoothly.
http://www.toyota-4runner.org/attach...343%5B1%5D.jpg
http://www.toyota-4runner.org/attach...352%5B1%5D.jpg
Old 11-16-2016, 01:57 AM #7
Roboman's Avatar
Roboman Roboman is offline
Roboman is on a distinguished road
Roboman's Avatar
Almost Got It
Hi,
I have nearly completed the install of the sliders on a 2016 TE with KDSS. Bit of a challenge actually just time and patience. Do you have a photo of where the drivers side front flange meets the hydraulic line guard? This would really help me get a visual of final alignment. All is looking great and I can provide some pics of install along the way if needed.
Roboman is offline   Reply With QuoteReply With Quote
Old 11-20-2016, 09:02 AM #8
Roboman's Avatar
Roboman's Avatar
Got It
The sliders are now installed on my 2016 TE with KDSS! Key was removing the hydraulic line factory skid plate. This allows you to align the slider and get that first bolt in place on the front mounting plate. Once you have a few bolts in both the front and rear mounting plates then reinstall the hydraulic line skid plate. From there it's relative easy.
Another note once you remove that hydraulic line skid plate there's a steel tab that must be flattened or cut off. I found it easier to simply cut the tab off. Last note if a few of the mounting plate holes don't line up you may need to lightly grind down the weld from a few high spots on the frame (not slider) for proper alignment of the mounting holes.
The sliders look awesome, function perfectly as a step, and based on the design and fabrication appear to be extremely functional in protecting your truck from rocks.
Old 11-20-2016, 01:33 PM #9
Real Name: Caleb
Real Name: Caleb
Another note once you remove that hydraulic line skid plate there's a steel tab that must be flattened or cut off. I found it easier to simply cut the tab off. Last note if a few of the mounting plate holes don't line up you may need to lightly grind down the weld from a few high spots for proper alignment of the mounting holes.
Glad you got it figured out! Sorry I didn't respond sooner, I wasn't getting notifications from this thread.
Old 01-17-2017, 09:56 PM #10
ArrArr's Avatar
ArrArr ArrArr is offline
ArrArr is on a distinguished road
ArrArr's Avatar
Tip to others (w/ stock skids):
- Between step 2 and 3, remove 3 bolts from the stock skid on the side you're working on that align with the holes in the frame plate of the sliders *before* starting the first bolts of the sliders.
Else it'll be a pain trying to get the bolts nearest the front undone.
- Then the frame plate of the sliders will go under between the frame rails and stock skid.
Ask me how I know...
Current: 2015 TRD Pro | Inferno Orange | C4Fab sliders | SSO Slimline bumper | WARN Zeon 10S winch | Bushwacker flares
Sold: 2006 4Runner Limited | Galactic Gray
ArrArr is offline   Reply With QuoteReply With Quote
Old 04-01-2017, 09:32 PM #11
Seņor_Godric's Avatar
Seņor_Godric Seņor_Godric is offline
Seņor_Godric is on a distinguished road
I was wondering the skid plate for the KDSS do you need to cut it so that I can install the slider and than put it on???
Seņor_Godric is offline   Reply With QuoteReply With Quote
Old 04-05-2017, 11:42 AM #12
Real Name: Caleb
Real Name: Caleb
you do not need to cut any of the KDSS skid plates. The only thing you need to do is hammer the little bent tabs on the ends of the KDSS skid plate so they flatten out before putting the skid back on.
Old 04-22-2017, 04:33 PM #13
LOLSNOW LOLSNOW is offline
LOLSNOW will become famous soon enough
I bent mine out. Also had issues reinstalling it at first since the flap piece on the slider wasn't bent enough. What helped was to skip the KDSS skid plate first and then bolt down the flap then undo one of the bolts and then bolt down the KDSS skid plate.
LOLSNOW is offline   Reply With QuoteReply With Quote
Old 04-24-2017, 07:49 PM #14
Awesome!!! So you installed the rock slider and put the skid plate over it correct??
Old 04-25-2017, 02:14 PM #15
Yep. There will be a gap when you put the plate over it. All you'll need to use is a few of the washers that c4fab supplies. Super simple
HTML code is Off
RCI Rock slider install instructions? Cgullo83 5th gen T4Rs 53 01-21-2019 06:09 PM
Shrockworks rock slider install instructions coletrain09 5th gen T4Rs 57 11-28-2018 08:42 PM
Savage Off Road Rock Sliders Install (Lots of Pics and a Welding Video) wmeredith 3rd gen T4Rs 16 04-20-2018 11:55 AM
Anyone have the instructions for MeatlTech sliders? razzman1 4th Gen T4Rs 2 08-12-2015 03:28 PM
welding on sliders - instructions? MadCityRich 3rd gen T4Rs 5 06-25-2012 11:26 PM
