Old 12-10-2016, 08:07 PM #1
C4 Fabrication's Avatar
C4 Fabrication C4 Fabrication is offline
Real Name: Caleb
C4 Fabrication has a spectacular aura about C4 Fabrication has a spectacular aura about
Real Name: Caleb
14+ 4runner Lo-Pro Winch Bumper install instructions by C4 FAB
Hey everyone, here are the install instructions for our new 14+ 4runner Lo-Pro winch bumper.
Tools required:
-10mm wrench/socket
-12mm wrench/socket
-14mm wrench/socket
-19mm wrench/socket
-9/16" wrench/socket
-1/2" wrench/socket
-Small flathead screwdriver
-Large flathead screwdriver
-Die grinder or airsaw to use for cutting plastic bumper.
First off the plastic bumper cover needs to be removed from the vehicle.
Start by opening the hood and removing the plastic clips that hold the radiator shroud cover in place. Use the small flathead screwdriver to pop the center of the clip up, and then pull the clip out of the hole. Completely remove the cover and set it aside with the clips.
14+ 4runner Lo-Pro Winch Bumper install instructions by C4 FAB-dscn3975-jpg  14+ 4runner Lo-Pro Winch Bumper install instructions by C4 FAB-dscn3976-jpg  14+ 4runner Lo-Pro Winch Bumper install instructions by C4 FAB-dscn3978-jpg
Owner/Operator of C4 Fabrication. specializing in custom built Toyota off-road products.www.c4fabrication.com
C4 Fabrication is offline   Reply With QuoteReply With Quote
Old 12-10-2016, 08:11 PM #2
Real Name: Caleb
Real Name: Caleb
Now remove the plastic clips and screws with 10mm head that attach the bumper cover to the steel radiator support.
14+ 4runner Lo-Pro Winch Bumper install instructions by C4 FAB-dscn3979-jpg  14+ 4runner Lo-Pro Winch Bumper install instructions by C4 FAB-dscn3981-jpg  14+ 4runner Lo-Pro Winch Bumper install instructions by C4 FAB-dscn3982-jpg
Old 12-10-2016, 08:16 PM #3
Real Name: Caleb
Real Name: Caleb
Then remove all of the small screws with 10mm head that hold the plastic fender liner to the bumper cover. Note where the screws go so you can put them back into the same locations. Some screws are different lengths and diameters than others.
Also fully remove the small black plastic cover that goes from the bottom of the plastic bumper cover to the frame of the vehicle.
14+ 4runner Lo-Pro Winch Bumper install instructions by C4 FAB-dscn3985-jpg  14+ 4runner Lo-Pro Winch Bumper install instructions by C4 FAB-dscn3988-jpg  14+ 4runner Lo-Pro Winch Bumper install instructions by C4 FAB-dscn3990-jpg  14+ 4runner Lo-Pro Winch Bumper install instructions by C4 FAB-dscn3991-jpg  14+ 4runner Lo-Pro Winch Bumper install instructions by C4 FAB-dscn3992-jpg
Old 12-10-2016, 08:22 PM #4
Real Name: Caleb
Real Name: Caleb
Now disconnect the fog light wiring harness from the light and then the bumper cover will be ready to remove.
Start at one corner of the bumper cover where it meets the fender. Firmly pull out and forward on the plastic to remove it from the clips that hold it in place.
Follow the same procedure on the other side of the vehicle and the bumper cover will come right off in one big piece.
14+ 4runner Lo-Pro Winch Bumper install instructions by C4 FAB-dscn3995-jpg  14+ 4runner Lo-Pro Winch Bumper install instructions by C4 FAB-dscn3994-jpg  14+ 4runner Lo-Pro Winch Bumper install instructions by C4 FAB-dscn3998-jpg  14+ 4runner Lo-Pro Winch Bumper install instructions by C4 FAB-dscn3999-jpg  14+ 4runner Lo-Pro Winch Bumper install instructions by C4 FAB-dscn4000-jpg  14+ 4runner Lo-Pro Winch Bumper install instructions by C4 FAB-dscn4001-jpg
Old 12-10-2016, 08:27 PM #5
Real Name: Caleb
Real Name: Caleb
The aluminum crash bar can now be removed from the frame of the 4runner.
Use a 14mm socket to remove the nuts holding the crash bar on, then remove the crash bar mounting brackets from the frame as well.
Be sure to save the bolts that hold the crash bar brackets to the frame, these will be re-used to hold the new Lo-Pro bumper in place.
14+ 4runner Lo-Pro Winch Bumper install instructions by C4 FAB-dscn4016-jpg  14+ 4runner Lo-Pro Winch Bumper install instructions by C4 FAB-dscn4018-jpg  14+ 4runner Lo-Pro Winch Bumper install instructions by C4 FAB-dscn4019-jpg
Old 12-10-2016, 08:31 PM #6
Real Name: Caleb
Real Name: Caleb
Next we are going to start on the bumper cover cutting process.
First remove the silver plastic trim cover from the front lower area of the bumper cover. Use a flat head screwdriver to pop the plastic clips out of the back side of the cover.
14+ 4runner Lo-Pro Winch Bumper install instructions by C4 FAB-dscn4002-jpg  14+ 4runner Lo-Pro Winch Bumper install instructions by C4 FAB-dscn4003-jpg  14+ 4runner Lo-Pro Winch Bumper install instructions by C4 FAB-dscn4004-jpg
Old 12-10-2016, 08:40 PM #7
Real Name: Caleb
Real Name: Caleb
Now the bumper can be marked for cutting. Use masking tape to create an easy line to follow when cutting. Basically the cut is made right along the deepest part of the groove where the silver plastic cover used to meet the edge of the bumper cover. Also lay out a line right above the slotted holes below the lower grille mesh area. The slotted holes are where the silver plastic cover used to fit through the bumper cover.
When cutting the left and right side, be sure to cut right in the center of the deep grooved area on each side. This will ensure good fitment to the new Lo-Pro bumper. The area that needs to be cut along the slotted holes doesnt have to be a perfect smooth straight line. This area will get covered by the new Lo-Pro bumper.
Any rough edges along the cut can be cleaned up with a sanding pad on a die grinder or with a knife and file.
14+ 4runner Lo-Pro Winch Bumper install instructions by C4 FAB-dscn4005-jpg  14+ 4runner Lo-Pro Winch Bumper install instructions by C4 FAB-dscn4007-jpg  14+ 4runner Lo-Pro Winch Bumper install instructions by C4 FAB-dscn4006-jpg  14+ 4runner Lo-Pro Winch Bumper install instructions by C4 FAB-dscn4010-jpg  14+ 4runner Lo-Pro Winch Bumper install instructions by C4 FAB-dscn4008-jpg  14+ 4runner Lo-Pro Winch Bumper install instructions by C4 FAB-dscn4011-jpg  14+ 4runner Lo-Pro Winch Bumper install instructions by C4 FAB-dscn4012-jpg  14+ 4runner Lo-Pro Winch Bumper install instructions by C4 FAB-dscn4013-jpg
Old 12-10-2016, 08:53 PM #8
Real Name: Caleb
Real Name: Caleb
The plastic bumper cover can now be installed back onto the 4runner using the original hardware. We have discovered that it is actually much easier to install the Lo-Pro onto the 4runner first, before the plastic bumper cover is installed. The light bar and winch can be installed into the Lo-Pro, then the Lo-Pro can be installed onto the 4runner, then the plastic bumper cover can go on after that.
The aluminum crash bar and brackets along with the small plastic skid plate DO NOT get installed back onto the 4runner.
Push firmly on the corners of the bumper cover to clip it back onto the fender area. Make sure to plug in the wiring harness for the fog lights before re-attaching the plastic fender liner to the bottom of the bumper cover.
14+ 4runner Lo-Pro Winch Bumper install instructions by C4 FAB-dscn4022-jpg  14+ 4runner Lo-Pro Winch Bumper install instructions by C4 FAB-dscn4023-jpg  14+ 4runner Lo-Pro Winch Bumper install instructions by C4 FAB-dscn4024-jpg
Old 12-11-2016, 02:12 PM #9
Real Name: Caleb
Real Name: Caleb
Now that the plastic bumper cover has been re-installed, a couple other things need to be done before the Lo-Pro bumper can be installed.
You will need to trim off some plastic from the air dam on the driver side so the bumper upright support can fit without interference. Cut off a portion that resembles the shape in the picture. You may need to test fit the bumper real quick to make sure you have trimmed enough.
Next if you are installing a winch into your Lo-Pro bumper, you will need to slightly bend the A/C condenser line to make room for the body of the winch.
In the photos you can see where the winch would interfere with the line if it is not adjusted out of the way.
When adjusting the line, carefully and slowly bend the line a little bit at a time in a slight arc to create a gradual bend. This will prevent the line from kinking when it is adjusted. Also support the line where it attaches to the condenser to make sure the line does not crack loose from the fitting.
MAKE SURE TO CHECK ALL CLEARANCES BETWEEN THE BUMPER, WINCH AND A/C LINE BEFORE THE FINAL INSTALL! If the A/C line is rubbing on the winch or the bumper somewhere, it can puncture the line and allow the Freon to leak out.
It is also a good precaution to add a piece of rubber hose around the A/C line in any areas where rubbing may occur.
Also some winches may interfere with the small metal grille support bracket right in the center area in front of the condenser. This bracket can be slightly bent back with a mallet or crescent wrench to create the necessary clearance.
14+ 4runner Lo-Pro Winch Bumper install instructions by C4 FAB-dscn4025-jpg  14+ 4runner Lo-Pro Winch Bumper install instructions by C4 FAB-dscn4028-jpg  14+ 4runner Lo-Pro Winch Bumper install instructions by C4 FAB-dscn4031-jpg  14+ 4runner Lo-Pro Winch Bumper install instructions by C4 FAB-dscn4033-jpg  14+ 4runner Lo-Pro Winch Bumper install instructions by C4 FAB-dscn4038-jpg
Old 12-11-2016, 02:19 PM #10
Real Name: Caleb
Real Name: Caleb
Now it is time to install the Lo-Pro bumper onto the 4runner.
If you are installing a winch and/or LED light into the bumper, do it now before the bumper is installed onto the 4runner.
If you are installing an Extreme LED 30" Pro series 2D light bar into the bumper, you will need to use the two small "L" shaped tabs provided in the Lo-Pro hardware kit to install the light. Do not use the tabs that come with the light, they will be too tall. Install the "L" tabs onto the light with the longer leg attaching to the light and the shorter leg mounting to the tabs that are welded into the bumper.
There is a photo of the mounting tabs at the bottom of this post. There is also a photo of one of the tabs mounted to the light inside a bumper as well.
Once your bumper accessories are installed, you can lift the bumper into place on the vehicle. Have a friend get one bolt on each side at the top of the frame mount threaded in enough to hold the bumper in place. Then the rest of the bolts can loosely be installed. Use the provided grade eight 3/8" flat washers with the factory bolts when installing the bumper.
Adjust the bumper up or down on the slotted holes to align it with the plastic bumper cover as desired.
The remaining bolts can now be tightened down.
14+ 4runner Lo-Pro Winch Bumper install instructions by C4 FAB-dscn4276-jpg  14+ 4runner Lo-Pro Winch Bumper install instructions by C4 FAB-dscn4279-jpg  14+ 4runner Lo-Pro Winch Bumper install instructions by C4 FAB-dscn4692-jpg  14+ 4runner Lo-Pro Winch Bumper install instructions by C4 FAB-dscn4708-jpg
Old 12-11-2016, 02:25 PM #11
Real Name: Caleb
Real Name: Caleb
Now install the extra frame support brackets on the back of the bumper which attach to the sides of the frame rail.
There is a left and right hand bracket, make sure you use the correct one on each side, they should only fit one way.
Loosely attach the bracket to the back of the bumper with the provided 3/8" carriage head bolt. Then thread the provided M12 bolt into the side of the frame rail. Use the provided 1/2" flat washer on the bolt as well. Adjust the bracket so it sits flat on both surfaces and tighten down the bolts.
14+ 4runner Lo-Pro Winch Bumper install instructions by C4 FAB-dscn4280-jpg  14+ 4runner Lo-Pro Winch Bumper install instructions by C4 FAB-dscn4282-jpg  14+ 4runner Lo-Pro Winch Bumper install instructions by C4 FAB-dscn4285-jpg  14+ 4runner Lo-Pro Winch Bumper install instructions by C4 FAB-dscn4286-jpg
Old 12-11-2016, 02:32 PM #12
Real Name: Caleb
Real Name: Caleb
Lastly you will need to install the flat brackets that attach the original plastic bumper cover to the bottom edge of the Lo-Pro bumper.
The flat bracket goes on the inside of the Lo-Pro and plastic bumper.
Set the bracket into position and install the 3/8" carriage head bolt up through the bottom corner of the Lo-Pro bumper and through the flat bracket. Loosely install the washers and nut.
Now install the provided 5/16" bolt through the hole in the plastic bumper up through the flat bracket. Install the washers and nut and tighten everything down.
Your Lo-Pro bumper installation is now complete! Finish wiring the winch and light, and you are ready to hit the trail.
Thank you for purchasing your Lo-Pro winch bumper from C4 FAB!
14+ 4runner Lo-Pro Winch Bumper install instructions by C4 FAB-dscn4287-jpg  14+ 4runner Lo-Pro Winch Bumper install instructions by C4 FAB-dscn4291-jpg  14+ 4runner Lo-Pro Winch Bumper install instructions by C4 FAB-dscn4294-jpg  14+ 4runner Lo-Pro Winch Bumper install instructions by C4 FAB-dscn4296-jpg  14+ 4runner Lo-Pro Winch Bumper install instructions by C4 FAB-dscn4298-jpg
Old 05-27-2018, 11:05 PM #13
ProShooter1 ProShooter1 is offline
ProShooter1 is on a distinguished road
Power Steering Line
Iím In the middle of installing the C4 Lo Pro bumper and the power steering line is in the way of the winch control box. Anyone experienced this? It isnít a line that is easily bent like the AC line. I wish I had known this would be a possibility before I took a Dremel to my brand new truck. It does not fit cleanly across the top of the box like what I have pictured in the attachment.
14+ 4runner Lo-Pro Winch Bumper install instructions by C4 FAB-1f458cb2-bf0d-4fd5-b21a-9e74e4f9b594-jpg
ProShooter1 is offline   Reply With QuoteReply With Quote
Old 04-16-2019, 10:54 PM #14
kkruel55 kkruel55 is offline
kkruel55 is on a distinguished road
I really like this bumper, but I have a couple questions:
Does it come powder coated? Can it come powder coated?
What is a good time estimate for a reputable shop to install it?
kkruel55 is offline   Reply With QuoteReply With Quote
Old 05-21-2019, 08:11 PM #15
T4R_KAI's Avatar
T4R_KAI T4R_KAI is offline
Real Name: Josh
T4R_KAI will become famous soon enough
T4R_KAI's Avatar
Real Name: Josh
2014+ 4Runner Lo Pro Winch Bumper | C4 Fabrication
2017 TRD Off-Road -- Dobinsons 3/2 Lift w/ Camburg UCAs, Method 701s, Falken Wildpeaks AT3W, SSO Roof Rack, Xenon HID Low / LED High, Cali Raised LED, N-Fab Nerfs, Pro Grill
T4R_KAI is offline   Reply With QuoteReply With Quote
bumper , hybrid , led light bar , plate bumper , winch bumper
HTML code is Off
Factory Bumper Winch Install stickw 4th Gen T4Rs 24 01-21-2018 11:55 PM
Anyone install their winch after installing their ARB bumper? Derek G 4th Gen T4Rs 1 12-03-2013 11:34 PM
BudBuilt Winch Plate Install Instructions? RyanC 5th gen T4Rs 27 12-11-2011 01:34 PM
Winch install w/o aftermarket bumper thetaxguy Off-Roading 17 08-25-2009 06:12 PM
