Getting the fuel pipe connector apart was a mild challenge. I guess, after 20+ years things just don't want to move easily. Dropped the metal shield that protects the tank. Due to winter, the wheel well needed a boat load of washing out. The sand and debris up there was immense. Even when the access panel was removed, the backside was caked with debris. So, I washed the well out last night and decided to let it dry out over night before tackling the task today.
The local dealer had none of the hoses(upper and lower feeder pipes) or associated gaskets in stock, of course. I already have a new pump and housing gasket, but it would have been nice to just replace everything while in there. That will be for next time. We'll see what if any leaks there will be when I drop the tank after a cup of coffee.
regards
