My 1989 Build Thread
4runnertank
I didn’t think about taking pictures of everything I did to put them on here until now. So this is more like a timeline for all the different stages of my truck than anything.
I bought my truck on New Years Day 2010. I found it on craigslist in Pensilvania for 3k with 286k miles rebuilt 60k ago, on BALD 30” road tires. It also had an add-a-leaf in the back with the torsions cranked, so it sat about 2 or 3” higher. Drove down there and bargained the truck down to 2600, looking back wasn’t that great of a deal.
And then came the paint job and body work. Had barely any rust on it because it was an Arizona truck for 19 years! Also got a soft top for it off of craigslist for $250.
38395_1541419459327_1350177996_1450438_2138562_n.jpg~original
38395_1541419499328_1350177996_1450439_5665828_n.jpg~original
I ended up selling my tires and rims about 6 months later for exactly what I got them for  and got some 33x12.5r15 Pro Comp Xterrain tires on the same rims.
0904001204.jpg~original
0904001541.jpg~original
0814111218.jpg~original
71775_1658495586157_1350177996_1724835_5195973_n.jpg~original
47148_1597827709498_1350177996_1595982_4205409_n.jpg~original
ak-ash2/59853_1617690086045_1350177996_1641226_5485426_n.jpg[/IMG]
And then came the new lift. Rough Country 5” suspension lift. The rear was easy, the front… well lets just say I spent over 18 hours on the whole thing haha. (no lift or air tools)
377892_2918872334788_2120212808_n.jpg~original
401095_2918873094807_489412466_n.jpg~original
374217_2918873414815_2007795491_n.jpg~original
397189_2918873774824_1125866976_n.jpg~original
397077_2918874014830_443924766_n.jpg~original
403962_2918874534843_2134903167_n.jpg~original
393211_2918875014855_1808115750_n.jpg~original
395173_2918875414865_761822703_n.jpg~original
409003_2918875694872_1062447187_n.jpg~original
405318_2918859494467_47596662_n.jpg~original
401353_2918876614895_1923144903_n.jpg~original
401663_2918877014905_147944062_n.jpg~original
So I had 33" pro comp xterrains on my truck that i got for $213 a piece a year and a half ago. After I put the lift on i needed some new tires. I put my tires and rims on craigslist hoping to get $550 out of them, then buy my own... Then some guy offered a trade, his 36x15.5 Mickey Thompson ATZ's that still had the nipples on them (those are $340 tires)... DONE! Went to his house and swapped them on X-Mas eve! And THE MOST IRONIC THING was he was a toyota fanatic, he had the 36's on his 88 4Runner.
Air Intake
Here's the $33 Intake i got off ebay. Wasn't that hard to install, just had some issues fitting the mounts that they gave me. I noticed very little with it though. Throttle response was slightly better, but when you get the rpm's up to 3 grand it felt like there was a turbo kicking in. And it does make a badass roaring sound.
index.php
index.php
Diff Painting
Just to get rid off all that mud and grime, I wire wheeled and painted almost my entire front end. After putting the lift on I scraped the crap out of almost everything in the front end.
Diff Breather
Just did this yesterday. The stock diff breathers are pretty much junk. They sit on the top of of the diff and get clogged super often, especially with mud. If the breathers aren't working correctly, the pressure inside of the axle has nowhere to go when it changes temperatures, so it presses out the seals, resulting in axle seal and pinnion seal leaks. And if submerged in water, it can get sucked into your axle NOT GOOD!
This is the front breather which i used 5 feet of clear vacuum line to re-route up in my engine bay. I put a filter on the end of it as well.
4runnertank-albums-%26quot%3Bthe+pumpkin%26quot%3B-picture9570-front-breather-filter.jpg
And for the one in the back, I took the hosing all the way into the inside of the bed.
Those wide 36s give it a nice stance :driving:
Edit: Lookin at your pics again.. Hows the ride/ axle wrap with the rear blocks?
What'd you use for filters?
When I got the air intake in the mail, it had a little 2" filter inside, on top of the big one. I think it was a filter you could use for one of the vacume lines. Thats what I used for the diff breather. I didn't use a filter for the back one since there's o way for it to get dirty in the bed.
hey wanna give a couple pictures and a quick description of that side mounted light. Like the look and wanna do the same with mine. Thanks
So here's the story on the spotlight... It was on the truck when I bought it. The guy said he used it when he went hunting, or to mess around with his friends. It worked for 6 months or so untill I splashed cold water on it making it crack, and the handle got stripped :/. I just haven't bought a new light or handle yet because I had other priorities (lift + locker etc.). But it's a General Electric Post Mount spotlight, with a 6" light. The thing is awsome.
DSC05132.jpg~original
DSC05130.jpg~original
DSC05128.jpg~original
The ride quality is HORRIBLE. Like I've said before, it's like riding in a wood-wheeled buggy from the 18th century haha. And the axle wrap is minor. Should've seen this guy's ford. he had like 8" blocks. :lmao:
Diff breather
So here's what the diff breathers look like. And here's how they work.. The little mechanism is made up of three things, the metal cap, small spring, and little piece of rubber. When pressure is released through the little nossel at the top of the diff, it pushes the rubber up to let air out, and when there's isn't any air coming out it's "sealed". There's a few problems with this method. If your axle submerged in water and needs to breathe, it'll take in some water. And if the breather ever gets clogged with mud or ice or anything, the pressure will try to push through all the seals for your axle. I'm pretty sure thats why my wheel seal and pinion seal went out. Hope this helps others!
DSC05136-1.jpg~original
