4Runter New member Dec 6, 2012 #2 Step 2. Go back to the dealer because they forgot to give you some parts you ordered. On the bright side, they had this in the showroom. Attachments fj.jpg 84.5 KB · Views: 342
4Runter New member Dec 6, 2012 #3 My truck: 3.0 V6 4x4 Automatic 128k Miles Here's the run down of parts I ordered from the dealer: 35178-30010 TRANS GASKET 12157-10010 GASKET 35303-35010 TRANS STRAINER 12204-65010 PCV 00295-01281 GASKET SEALER 23300-65020 FUEL FILTER 90919-21579 WIRES 19102-70160 ROTOR 19101-65040 CAP DIST +Assorted crush washers Amsoil dealer: Front Differential Rear Differential Transfer Case Transmission Engine
4Runter New member Dec 6, 2012 #4 Drained and replenished the oils, but ended up not dropping the tranny pan. Will periodically drain the tranny and add oil, repeat until it is cleaner. Also changed the fuel filter.
4Runter New member Dec 6, 2012 #5 Pulled the spark plugs. I'll let the pictures do the talking. Attachments spark plugs.jpg 89 KB · Views: 393 4 plugs.jpg 99.9 KB · Views: 357
