Originally Posted by delgadog
ok, i'm getting closer, i'm looking at pics of the engine and where the leak is, there seems to be an exhaust manifold there i think? it cuts across the engine and attaches at either side of the headers or something. anyone have a pic of the engine without that part on?? can't seem to find one online. also, i think i've narrowed it down to the water bypass outlet and the tubes attached to it... i just want to verify if there is anything else back there that can leak or have coolant running through it. thank you in advance!
My educated guess on the location of your leak would be the radiator fluid bypass tube that's located at the back of the engine.
Mine had a spot that had rusted through (VERY common), and leaked radiator fluid in a way that looked like it was coming from the head gasket.
Here is the part --
Here is where it had rusted through --
Here's the location of the bypass tube at the back of the engine --
Replacing it is -- fun. to make it easier remove the intake manifold.
Hopefully it's this, or better yet - just a heater hose has a leak.
