Thomas' thread: Built not Bought
DeclansDaddy
So here my super slow moving build thread. I picked this baby up for $500 sight unseen. It's an '86 22re Auto DLX.
Here's the up to date pic:
Someone has done some shabby rust repair on the rear wheel wells. Also the front fenders are shot. The truck had the chrome fender trim and I believe that's pretty much the culprit of the rust. A couple little rust holes are pretty much the extent of the rust. The frame seems pretty solid. Here in Eastern Va. we don't see much snow so trucks last a little longer here, just the occasional hurricane flooding our streets with salt water is about the harshest season we have. Here's what I've done to the truck up to date.
-fixed the busted out back glass
-fuel pump and fuel pump bracket replaced
-A lot of shop vac work removing the pounds of dog hair from the int.
-timing chain/guides, water pump, oil pump
-valves adjusted to quiet the tick (not gone but much quieter than most Yotas)
-4" Trailmaster lift kit with all new front end parts (ball joints, tie rods, rotors, brakes, calipers)
-put my 32" Mud Claws/Centerlines on her for the time being
-removed 1980's pushbar
-pillar pod with digital tach, OP, and WT gauges
-new CV Axles
-Spartan locker in the rear
-glass H4 housings with upgraded headlight wiring harness
-Fitted 2nd gen front and rear seats in the truck
Things to do in my desired order:
-Tint front windows
-Body work and paint (this will be a trail rig so I will be painting this truck myself so no show quality work but I've done a lot of painting and I can lay it down pretty good) Planning on going back with the factory blue.
-35" KM2's
-Gears if they are absolutely needed with the tires, but would like to hold off until the SAS is do-able.
-Air locker up front
-Interior (new carpet, diamond plate panels, build cargo area organizer)
-Build my own one-off tube bumpers/sliders
-Softtopper (if the money frees up this will move up the list as far as possible)
-The almighty SAS. Plans are the whole TG 4"swap kit and 4" rear springs with a beefed up stock housing.
-Find a decent 22re and rebuild the bottom end, new head and cam, header.
I'm sure. I will add little stuff along the way but this is my overall goal. My plan is to have as little down time with this truck as possible which is why I'd like to find a motor and rebuild it while I'm still driving the truck so maybe me and some buddies could swap it out in a weekend. Other than my huge box truck I use for work this is my only wheels. Also I'd like to do my homework and have everything needed for the SAS ready to go when it's time. I know that's nothing I want to rush and half-ass but I really don't want to take forever doing it either. Any opinions and suggestions are always welcome.
4Runners crowding up the driveway. I ended up selling the black one to my good friend and he's getting the parts together to get her up and running. I can't wait til we can take them both wheeling
Custom back window!! Filled my 2.5 gallon shop vac twice to get all the glass out of the tailgate. I'm assuming it was down when it got broke. I'm on the hunt for one if anyone can help me out. Would love to find a toyota graveyard around eastern Va. image.jpg
Got that hideous bumper off and plasma whacked the brackets off. Thinking of building my own back bumper, something simple maybe some 2x3 box mitered on the sides to wrap around to the rear tires?? Any suggestions would be appreciated.
Im in the same boat, trying to decide which style of bumper to build. I had the 2x3 box tube before when I had a body lift
Good part about it is the frame ID is the same size so it was hammered into to strengthen the frame ends.
Bad part is with out a body lift some brackets will have to be fabbed up.
Swapped my wheels out today as I believe she'll be on the road before my '95. Anyone know if those push bars were a factory thing? It has a toyota emblem on it that looks factory, it contours with the bar perfect. I'm planning on ditching it but thought maybe someone would want it if it was an option. image.jpg
Does anyone know a link to a thread with pics on patching rear wheel wells with donors? I'm going to hopefully score some donors tomorrow and need to know the best way to do it before I go cutting them out. Is squaring it off better or following a body line. Only thing I've found on here, YT and pirate 4x4 is just cutting out the rust and making bigger wells but that's not what I'm looking to do. Thanks.
Well finally got my fuel pump in and fired the girl up. It definitely has a toyota tick which is louder than I've ever had but I'm hoping a good oil change will quiet it down. But go figure now I have fuel spraying out underneath of the truck somewhere. Guess a whole new gas line is in order.
Add a can of SeaFoam - it will really help with the old gas. Not to mention the water that's sitting in the bottom of the gas tank.
:driving:
Well thanks to the somewhat intelligent engineers at toyota they provided us with a drain plug on the tank so I was able to just drain all the old fuel. And yes it was quite bad.
Would love to find a toyota graveyard around eastern Va. View attachment 120710
I'm going to pass this place in about two hours coming home from the beach. They are a 1st gen junkyard but they're really a glass shop. They have a ton they are parting out. They are on 460 between Ivor and Zuni but very close to Suffolk. BYO tools.
Red's Auto Glass
Suffolk, VA 23434
Phone: (757) 539-0400
Red's Auto Glass
Suffolk, VA 23434
Nice. That's a couple of hours from me but well worth the trip. Thanks a lot man.
Hey. Be sure to call first. I stopped there about three years ago looking for seats. I found them later through a private seller. The place has no business sign. The guy working gave me a business card that said "Red's Auto Glass." I asked why it said it was a glass shop when it seems to be a used parts place (junkyard). I realized tonight that Suffolk is about 15 miles from the yard I went to. It's actually in Southampton County between Ivor and Zuni on 460. They possibly have two locations and one is for glass. There were about 6 1st gen 4Runners and some early pickups out front tonight. When I stopped there were many more behind their fence.
Nevermind I went out on a limb and made the trip out and I'm glad I did. Scored 2 rust free front fenders and a back glass for $90. Might not sound like a deal to some but I'm tickled pink with the trouble I've had finding stuff. I'll definitely go back. Thanks Nervo for the tip.
Snapped a pic of a buddy's 3rd gen today. Living proof that if you maintenance these truck you'll get your money's worth. He's on his 4th timing belt(none have broken, just routine changes). Don't see that everyday.
:wtf::50cal::worthless
i feel like a post ***** tonight its not that i don't believe that truck has ~560k miles im just surprised that that odometer is still keeping track of them....
