94 4Runner lift with rear sag questions.
Beckre80
Ok so I am a little confused and it was suggested to come here with my question after some research so here it is.
I bought this with the 4" lift already installed. As you can see the rear sags about 2.5-3 inches. So I'm guessing I should just buy new rear lift coils. Here is the question, do I buy 7" rear lift coils or just new 4" ones in hoping that the rear ones are just saggy from the weight and being old maybe? This is my first lifted truck so any help would be great thanks.
I have no lift and a super saggy booty and a lot of people have different methods of fixing it. I can't decide which to do. I feel 7'' might be a tad much, though.
just do this
your easiest and cheapest option is just to get a new set of ProComp 4'' lift springs and call it a day. The springs cost me $115 in canada. Summit as well as 4wp has em.
Since the truck already had new rear springs installed, it needs control/lateral arm bushings. Replace them with urethane. I did ours years ago, and it has yet to sag. The response is better and the tracking is vastly improved on the road.
With the "rear 4runner sag" issue, it is usually two factors, bad factory springs and bushings. If you have collapsing on the front suspension, it can make it seem worse. Best of luck with it.
regards
