Old 12-10-2015, 04:57 PM #1
Bad_Vision's Avatar
Bad_Vision Bad_Vision is offline
Bad_Vision is on a distinguished road
Bad_Vision's Avatar
Bad_Vision's 1985 Toyota 4RUNNER TDI Swap (Completed swap)
Updated: new transplant vehicle is a 1985 4Runner frame with a 1987 pickup cab.
I am currently on the hunt for a donor rust free 4runner to put on this frame. And when I find one I will post pictures of the new 4runner body running the TDI engine.
Classic's Section Moderator
http://www.4crawler.com/4x4/CheapTricks/index.shtml
My 1985 TDI swapped 4Runner http://www.toyota-4runner.org/classi...-tdi-swap.html
Bad_Vision is offline   Reply With QuoteReply With Quote
Old 12-10-2015, 04:59 PM #2
Bad_Vision's Avatar
Bad_Vision's Avatar
Here is the power plant donor
2001 Jetta TDI automatic with ALH engine
Got it for $1200 runs and has tranny slip. I will be scrapping left over parts of it in eBay to help fund the project a little bit.
Old 12-10-2015, 05:00 PM #3
Bad_Vision's Avatar
Bad_Vision's Avatar
On my way to pick up the 1984 4Runner today that will be the frame for this swap.
Old 12-12-2015, 03:10 PM #4
Bad_Vision's Avatar
Bad_Vision's Avatar
Ok after reviewing the 1984 and its issues and the fact that the 96 has a strong engine I'm changing the plan up.
The 1985 will get the TDI.
Have a good weekend I won't be updating till late next week once I start my "vacation".
Here is the articles I have been reading the most to give me ideas and information.
http://www.myturbodiesel.com/wiki/im...lacement-tips/
http://www.offroadsolutions.com/tech...fe-conversion/
http://d44tech.com/flipped_chevy_dana44.html
http://cutandturn.com/tech.html
http://sonoransteel.com/phong/retrof....html#safeties
Old 12-14-2015, 07:00 PM #5
Bad_Vision's Avatar
Bad_Vision's Avatar
Steel order came in. And started assembling the parts. I have still not found the donor axle yet so thinking I'll cut the tubes of a passenger drop axle and flip the tubes around.
For those of you who have not seen my shop here are some pictures I took today. Unfortunately my dad had a very large project due this week so I can't start frame building till next week Bad_Vision's 1985 Toyota 4RUNNER TDI Swap (Completed swap)
Old 12-14-2015, 07:07 PM #6
BigRyan1986's Avatar
BigRyan1986 BigRyan1986 is offline
Real Name: Ryan O'Dell
BigRyan1986 is an unknown quantity at this point
Nice shop. One day ill have something like that to play in. Till then back to the gravel i go lol. Sounds like an interesting build. I was doing some research on building my Volvo and someone said something about a supra 5 speed swap if you go over 250hp on your engine and that there is a kit. That being said im going to research that and possibly put a volvo turbo engine into my 2nd gen
4" pro comp lift, pro comp ES9000 shocks, homemade sliders, tinted rear windows, more mods to come
http://www.toyota-4runner.org/classi...d-big-red.html my build
BigRyan1986 is offline   Reply With QuoteReply With Quote
Old 12-14-2015, 07:20 PM #7
Bad_Vision's Avatar
Bad_Vision's Avatar
After doing all the research on diesel swaps with Toyota platforms the TDI was the best option. As a stock direct replace engine in the ALH is almost identical engine specs for horsepower and torque.
That being said with minor CHEAP modifications that motor can put out 150 hp with around 230 foot pounds of torque.
They have some TDI engines that can put out close to 400 hp in over 800 foot pounds of torque that kind of power would of course nap factory Toyota axles like a twig.
I will also be running lifted with 37 inch tires 529 gears
And by most comparison swaps that will still get me close to 30 miles per gallon. So I will not have to give up the daily driver aspect of my toy.
You really need to decide what turbo diesel engine is more suited to your needs.
The OOM 617 is nice but requires a lot of modification to the framework and radiator support.
The 4BT has extra power but it is also extra heavy
All of these engines can be run mechanically as well they do not require any ecu but that cost more money.
in any situation I would recommend buying a running donor vehicle. In my area it was $400 more to buy a running vehicle then just the motor. When all said and done I will sell the parts and make a little bit of money back from the donor vehicles.
Old 12-14-2015, 07:23 PM #8
flyinhawaiian01's Avatar
flyinhawaiian01 flyinhawaiian01 is offline
Real Name: Chris
flyinhawaiian01 will become famous soon enough
Real Name: Chris
HOLY CRAP! That's one large shop alright! Must be twice as big as mine! And I like the 3 axis cnc lathe you got in there! Must be nice to just make your own parts when there's nothing available off the rack!
2011 4 Runner (my daily driver)
1987 Xtra Cab (35's and locked front/rear, the trail toy!)
1985 Supra (430rwhp track toy!)
2006 Honduh Odyssey (the wife's van)
flyinhawaiian01 is offline   Reply With QuoteReply With Quote
Old 12-14-2015, 07:24 PM #9
Bad_Vision's Avatar
Bad_Vision's Avatar
Thanks it has its advantages and disadvantages. I'm never short of a "friend" that needs something LOL
Old 12-14-2015, 09:57 PM #10
v_man's Avatar
v_man v_man is offline
v_man is on a distinguished road
v_man's Avatar
cool project and I'll be looking forward to your build... what do u and your dad do BTW?
v_man is offline   Reply With QuoteReply With Quote
Old 12-14-2015, 09:59 PM #11
Bad_Vision's Avatar
Bad_Vision's Avatar
My dad owns a machine and fabrication shop. I own a remodeling and custom carpentry company.
He lets me use his building and machines and I fix his house and vehicles. It's a fair trade I think!
Old 12-14-2015, 10:04 PM #12
Bad_Vision's Avatar
Bad_Vision's Avatar
Here is a good article I found!
I think I'm going to do this to a factory Toyota front axle I have laying around.
What do you guys think?
Old 12-15-2015, 12:52 AM #13
maclean216's Avatar
maclean216 maclean216 is offline
maclean216 is on a distinguished road
maclean216's Avatar
why not the dana 60?
2001 4Runner 3.4V-6 SR5
Camburg UCA W/ limit straps
6112 Front/5160 rear
ARB front/Detroit rear 4.88 / 35s
TRD supercharger w/ URD 7th injector
maclean216 is offline   Reply With QuoteReply With Quote
Old 12-15-2015, 12:59 AM #14
v_man's Avatar
v_man's Avatar
hard to find and expensive ? at least they are around here...
Old 12-15-2015, 01:02 AM #15
maclean216's Avatar
maclean216's Avatar
Unless its off a 80 series land cruiser, aren't they a little narrow?
Any meets? Aelfwine Toronto / Ottawa / Ontario 4 10-27-2014 11:51 AM
85 4runner meets 96 sr5? Bad_Vision Classic T4Rs 6 11-27-2013 11:48 AM
Texas meets? Craig8d8 General Discussions 1 04-18-2012 01:25 AM
meets in So Cal?? 501runner T4R Meet Announcements & Info 12 12-14-2011 10:22 AM
