Toyota - 4Runner . org Forum
Go Back   Toyota - 4Runner . org Forum > Toyota 4Runner Forum > Classic T4Rs
LinkBack Thread Tools Rate Thread Display Modes
  #1 (permalink)
Old 08-28-2008, 01:33 PM
92 with rear end sag
Hey everyone,
I've had my 4runner for about 4 years now and have had nothing but good things to say about it.
This month and the next I'm going to be rebuilding the entire body of it since I decided to keep it.
The 1 thing I haven't found as a easy eco-fix was how to get the rear end of the 4runner to be equal and higher.
I don't want to do a lift kit or anything but if anyone knows of a rear coil swap I can do like from another truck that would do the trick let me know please! Or if there's a aftermarket company that already has this addressed with a remedy that would be great.
I would love for it to sit up right nice and strong lookin' after I get all the body work done.
I'm going to be building a full length roof rack with a step ladder and Line-Xed bumpers aswell as the bottom 1/4 of the truck will be Line-Xed.
Thanks in advance everyone!
Vince
Vince K.
1992 Toyota 4runner V6 Auto.
2002 Subaru WRX 222awhp 224awtq
vkinnovationanddevelopment@gmail.com
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!
Registered users don't see this ad. Register today!
  #2 (permalink)
Old 08-28-2008, 03:09 PM
depending on the year of your truck you can swap your coils for fj coils (landcruiser), and put in some ball joint spacers. should be pretty cheap. i know the rears from an fj will definately work on your 4runner and will for sure give it that stronger look you want, but you'd have to check on the fronts if your interested
  #3 (permalink)
Old 08-28-2008, 03:17 PM
It's a 92 4runner v6 auto.
I thought the FJs are leaf springs in the rear? Or do they come in coils for certain year(s)?
I want the rear to sit taller than the front by a bit too. I'm going to be using this as a camping vehicle for the family so it's going to be loaded up with some weight. It's my daily winter vehicle too so 100kms a day it'll be driven.
Vince K.
  #4 (permalink)
Old 08-28-2008, 10:08 PM
Ok, I assume you have IFS? What you need for cheap lift from rear coils is a 80 Series landcruiser rear coils, and you need the 7 wrap ones. probably around year '97 would be good. this will give you about 4 inches of lift in the rear. I think ball joint spacers can give you about 1.5inches of lift just so you know. Obviously you will use the ball joint spacers if you have IFS. This will be a cheap method of lifting it. just make sure you will get the 7 wrap coils and not the 8 wrap. So you know, i have none of these things installed but i PLan to install the fj coils. you can probably get a deal on 2 coils for about $50. now if you want a better ride to it, you can go with a kit. here is a link to a great kit being sold for much cheaper than those $1000+ lift kits.
http://www.yotatech.com/f37/new-comp...s4u-com-54794/
you can go with that if you want, talk to phil on there (strap22) he is a good seller and will help you out any way he can.
both options should hold up the weight with no problems, it just depends how much your looking to spend and what ride quality you are looking for.
  #5 (permalink)
Old 08-28-2008, 10:20 PM
Cool! So that's it? FJ rear coil springs and ball joint spacers for the front?
Seems to easy lol
You wouldn't happen to have a part number for the coils?
For the ball joint spacers, who makes those so I can search for the correct items?
Thanks for the help man!
Vince K.
  #6 (permalink)
Old 08-28-2008, 11:56 PM
yep that should be it. currently i may be buying some rear coils, i have yet to buy the ball joint spacers. for bj spacers, probably look for SDORI spacers, 4x4 or 2x4..whatever you have. sorry but i have no part number for the coils i recommend looking in classifieds/craigslist etc. for some, you will get them cheapest there. i would also recommend doing a little research to see if you would need any thing else, though i doubt it.
  #7 (permalink)
Old 08-29-2008, 01:07 AM
Are these 7 or 8 wraps?
http://forum.ih8mud.com/sale-parts/2...ml#post3568580
Vince K.
  #8 (permalink)
Old 08-29-2008, 03:23 PM
I'm pretty sure those are 7 wraps. Not 100% on that though. funny thing is, thats actually the pair i was looking at. i've tried contacting the guy a few times but he hasn't responded. not sure whats going on with those.
  #9 (permalink)
Old 08-31-2008, 12:02 AM
n8buddy's Avatar
Registered User
2 other option are the Moog cc225 heavy duty coils or Old Man Emu heavy duty coils, both will get you leveled.
Moog described
here
Old Man Emu here
4Runner of the Month August 2006
1991 Toyota 4Runner SR5 V6 5 spd
Old Man Emu N98 Front Shocks, Old Man Emu N72F Rear Shocks, Old Man Emu 901 Heavy Duty Coils, SDORI Ball Joint Spacers
Eagle Alloys Series 185, Toyo Open County M/T, Aisin Manual Hubs
Sony CD/MD Double-Din HU, Sony 12inch Sub, Sony 1200W Amp, XM Satellite Radio, Xantrex XPower 1000W Inverter
JDM Inclinometer, Hella 550 Fog Lamps, Wayfinder V7000 digital compass, Cobra 19 DX IV Citizens Band Radio, 4' Firestik Firefly CB Antenna, Magellan Triton 1500 GPS
  #10 (permalink)
Old 09-03-2008, 02:52 AM
i had same problem of sag. so i replaced my springs with heavy duty king springs only $150Aus
1989 4Runner RN130 with 22R (Full Rebuild)
  #2     Report Post   IP
Old 07-10-2009, 09:59 PM
Sponsor
Edit/Delete MessageReply With QuoteMulti-Quote This Message Quick reply to this message
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.2
