Toyota - 4Runner . org Forum
Go Back   Toyota - 4Runner . org Forum > Toyota 4Runner Forum > Classic T4Rs
LinkBack Thread Tools Rate Thread Display Modes
  #76 (permalink)
Old 11-24-2009, 01:15 AM
Registered User
Puddy dad I can't believe you didn't paint the access door to match the rest of the rear plastic! I tried to use the factory 5 inch but seem slike they need something extra as they don't work with just -+ wires going to them...Guess 6x9 are in my future as well.
Did the 4 inch speakers bolt right in on the dash?
http://www.dodgecharger.com/forum/index.php?action=dlattach;attach=76101;type=avatar
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!
Registered users don't see this ad. Register today!
  #77 (permalink)
Old 11-24-2009, 08:57 AM
s2kpuddydad's Avatar
Registered User
I ran out of paint and I just found out the color is no longer being made
My photo skills are not very good so most pics are over exposed. That is why the doors look out of place. In the true light, the color I used is pretty much a perfect match to the interior. The darker gray accent trim of the topper molding and door look good together in person.
I may have some paint mixed to do the doors
I am the PuddyDad, Creator of things for the S2000, Part provider to 5 Maltese dogs we lovingly refer to as Puddys. Puddy is a mix of two words, puppy and buddy. Small dogs like Maltese are little like a puppy and all dogs are your best buddy. Put the two together and you have a Puddy. PuddyModRacing@Tampabay.rr.com
  #78 (permalink)
Old 11-25-2009, 02:39 AM
Registered User
Your local paint shop should be able to match the color...mine did and it was perfect!
  #79 (permalink)
Old 11-27-2009, 10:17 AM
Registered User
I installed the tilt gauge yesterday using an unorthodox method….Industrial Velcro LOL
I just did not feel good about removing a 21 year old dash pad that was already in fragile condition.
I used a high speed die grinder to cut the welds on the mounting studs then, removed them. I placed the mounting bracket on the dash then marked off the place I thought it should be then, drilled a hole for the wire.
The setup looks good and seems to be securely mounted. I may move it back about an 1/8 inch, I think that would make it perfect…..
  #80 (permalink)
Old 11-27-2009, 02:00 PM
CJ3Flyr's Avatar
Super Moderator
Simply awesome!
  #81 (permalink)
Old 11-27-2009, 08:10 PM
Registered User
Thanks
I did move it back a little and it sits as it should now. I will take another pic of the finished install tomorrow.
  #82 (permalink)
Old 01-03-2010, 08:54 AM
Registered User
I posted this thread in the audio and electronics section of the forum. I thought I post a link here so, if any of you guys that have been following this thread would like to check it out, you can. By the way the tilt gauge came out great, lights up and functions fine
Navi for my First Gen
  #83 (permalink)
Old 01-03-2010, 01:33 PM
Registered User
Dude you have some serious skills, I wish I had the time, money, room and knowledge to do things like that. I just cleaned the ashtray, replaced the rotor and cap and threw in an air freshener in my 95 SR5 and I feel like I pushed the limits of my restoration abilities
  #84 (permalink)
Old 01-06-2010, 10:14 PM
Registered User
?? the box thats in the back passenger side is that stock? neither of my 86s have it all my shit just slides around the bottom lol truck looks great did you hollow out your "cat"? for better gas millage lol jk
1986 4Runner 4x4 Manual 12" Audiobahn Sub with 2 6X9" Volfenhags neon behind it
  #85 (permalink)
Old 01-07-2010, 10:55 AM
Registered User
I am not sure if the cat is gutted I never checked.
I went to the junk yard and salvaged two 2nd Gen plastic stow compartments. My 88 did not have any and I do not think the 4Runner came with them until the 1990s. I wanted a clean dry place to stow away the factory tool kit and other small items this is why I retro fitted the 2nd Gen plastic compartments.
  #86 (permalink)
Old 01-07-2010, 10:13 PM
Registered User
lol i ment the cat in the picture here kitty kitty that kind and thanks for the info on the boxes i want to find some now handy
  #87 (permalink)
Old 01-08-2010, 12:20 AM
Registered User
That is Joey and he is more fat now MPG is down when he is on board
  #88 (permalink)
Old 01-10-2010, 08:54 PM
Registered User
so my friend had a 94 we are parting out and i looked and it has the boxes now mine can be orginized too. lol thanks for the idea
  #89 (permalink)
Old 01-12-2010, 10:30 PM
Registered User
Pretty much finished with the DVD/Navi install....I want to get another factory radio bezel because, this one was butchered up before I started. I maybe able to repair the trim area but, if not I will just find a cherry replacement.
The unit fits like OEM in the dash and plays great. The DVD will play even when in motion by holding down the power antenna switch for a few seconds, this disables the blackout of the DVD.
  #90 (permalink)
Old 01-13-2010, 09:04 AM
Registered User
if you ground the pink wire that disables the safty feture and you wont have to mess with antenna
  #2     Report Post   IP
Old 07-10-2009, 09:59 PM
Sponsor
Edit/Delete MessageReply With QuoteMulti-Quote This Message Quick reply to this message
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.2
