Toyota - 4Runner . org Forum
Go Back   Toyota - 4Runner . org Forum > Toyota 4Runner Forum > Classic T4Rs
LinkBack Thread Tools Rate Thread Display Modes
  #1 (permalink)
Old 02-08-2010, 06:07 PM
Registered User
Rear window stopped working
Hey all,
The rear window just stopped working. No click when I push the button on the consol and the rear key switch doesn't work. I can't seem to find the fuse? Any help would be appreciated.
Phil Brochu
Proud owner of Old Thunder!
1988 4Runner
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!
Registered users don't see this ad. Register today!
  #2 (permalink)
Old 02-08-2010, 09:14 PM
fourwd1's Avatar
ROCK ABUSER
Location: central MD - I fart in your general direction
Rear window is on a ckt brkr, not a fuse. Upper right corner of the fusebox IIRC.
FOUR WHEELER mag July 2006 and OFF-ROAD mag Feb 2007
'89 4Runner SR5 - stock
  #3 (permalink)
Old 02-08-2010, 11:08 PM
Registered User
Thanks for the advice. Is this a usual problem or is there something else I should be looking for?
Phil Brochu
1988 4Runner
  #4 (permalink)
Old 02-09-2010, 12:21 AM
Registered User
Mine problem was caused by a faulty relay...it is located in front of the left rear tail light and can only be accessed by removing the large rear side panel. I got one at a junk yard for $10.
1994 Toyota SR5 4WD 3.SLOW, 168,000 miles
There's a growing pile in the garage of future mods.....more to come!
  #5 (permalink)
Old 02-09-2010, 12:42 AM
BornToRun's Avatar
Registered User
According to the 1987 FSM, there are two inputs to the "Power Window and Wiper Relay." One input begins at the Battery, runs through an 80A fuse, and then through the circuit breaker to the relay. The other input begins at the battery, runs through a 30A fuse, through the ignition switch, and then through the "ENGINE fuse" before entering the relay.
To rule out the motor itself, run hot and ground wires from the battery directly to the motor to see if it functions. Be careful to only briefly touch the wires to the motor. (I assume your window is stuck in the up position, so you don't want the motor to keep on trying to role the window up...might break something!)
There are several components to check, but the motor itself is the best place to begin.
BTW, use at least a 16Ga lamp cord and not some small gauge wire...be safe!
87 SR5 5-Spd 22REC : Aussie Locker rear : welded front diff
  #6 (permalink)
Old 02-09-2010, 07:00 AM
Registered User
Thanks for all the advice. Got a lot of work ahead of me today.
Phil Brochu
1988 4Runner
  #7 (permalink)
Old 02-09-2010, 02:10 PM
Registered User
Hey all,
I agree with everyone else but if it gradually got slower/weaker it may be the window motor. Just happened to me.
864runr
  #8 (permalink)
Old 02-15-2010, 05:42 PM
Registered User
Fixed, the safety was not disengaging when I closed the rear door. Cheap and easy fix. Thanks for all the great advice.
Phil Brochu
1988 4Runner
  #2     Report Post   IP
Old 07-10-2009, 09:59 PM
Sponsor
Edit/Delete MessageReply With QuoteMulti-Quote This Message Quick reply to this message
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.2
