No More Stinkbug (lowered my rear end)
illzoni
As I'd posted previously,
http://www.toyota-4runner.org/classic-t4rs/66518-what-do-i-have-here.html
Okay, I think I understand "63” chevys" as a reference to oversize rear springs. Is this a popular mod?
and
...as my BIL referred to it as the stinkbug look. The front fender is 36" off the ground, while the rear is at 38-1/4" high.
1987 Toyota 4Runner
It took some effort, but the rear end of my 4Runner is now only 3/4" higher than the front (versus the 2-1/4" it was). It looks much better now. And I hope it drives better too.
The PO had installed 63" Chevy springs on his way to making this a seriously capable offroad machine. (He hadn't gotten to the solid front axle yet.) In doing so, he used 6" shackles at the rear end of the springs.
I shopped around Tucson and found no replacement shackles available, so I decided to drill out the current shackles instead. I figured putting another hole at 3" would lower the rear 1.5". Removing and reinstalling the modified shackles wasn't a big deal, but drilling them was quite an exercise.
Bought the tools needed (1/8" pilot bit, 9/16" main bit, lubricating oil) at Lowes and returned home looking forward to getting it done. I removed the right side shackles with a little effort, and drilled the 1/8" pilot holes with no fanfare. Time for the main holes.....what? WHAT? The @#$% 9/16" bit has a 1/2" shank and won't fit in my 3/8" drill.
After much nashing of teeth over possibly buying a cordless kit (drill, sawzall, circular, etc), I ended up renting a 1/2" drill from Home Depot. With that drill home, it was no big deal to make the 9/16" holes. Then I just reinstalled the right shackles, and repeated on the left.
I'm thinking this change will have several good side effects...
First, my BIL won't be calling it a stinkbug anymore.
The front end will align better (and wear my new tires better).
It should handle better in general.
That's 1-1/2" less drop I'll need at the hitch.
And maybe I'll see a slight improvement in MPG.
Jon
I'm currently experiencing problems uploading to my domain, so I'll try to post some pics directly...
I would like to see more pics of how those shocks are mounted. Also, if you do any offroading, I would consider trimming those shackles down. That "fanging" is a rock magnet lol.
This doesn't show the top mounts, which is what I assume you want to see:
Yeah, I may order some of the correct length, keeping these on hand just in case. And certainly don't want to go through the effort of cutting them. Drilling was enough...but I had to get it done! Just because.
I've been wanting to mount my rear shocks like that, it seems as though it allows longer shocks and more droop. How long are the bilsteins?
Yeah I don't blame you, those thick aftermarket shackles are tough lol. What's your eye to eye measurment with the holes you made? I know the stockers are 3.5" eye to eye.
