Built 2000 4Runner - 11,500
CSL
Built 2000 4Runner - $9,000
POST UPDATED. NEW PRICE.
$9,000
For sale in Denver Colorado area:
I am selling my customized, off road, expedition, rock-crawling 2000 Sport 4Runner. This rig is my baby and I would not be selling it if not for the fact that my “real” babies are growing up, and the three of them don’t fit well in the back row anymore. I have moved up to a Land Cruiser.
This vehicle is for the buyer that wants the extras that I have put into this rig. This 4runner is meant and built to be a trail rig. This is a Colorado rig, and has no rust underneath.
NOTE: The winch in the photo is coming out and I am keeping it. Sorry.
ASKING PRICE: $9,000
-140K miles
-Auto tranny
-cloth interior
-aftermarket CD player with IPOD controls
-sunroof
-tow hitch
-rear differential locker
front.jpg~original
back.jpg~original
interior.jpg~original
Overview of vehicle:
-ARB front bumper
-Factory rear differential e-locker: If you know what this is, you know it’s value compared to having to do it aftermarket. If you don’t know what it is, this may not be the vehicle for you…well…what it does is locks the rear axle so both tires turn no matter what. This is an amazing off road feature!
-Sport model with hood scoop: Everyone seems to want the hood scoop. It is stock, and non-functional, but looks really cool.
-Husky floor mats: These floor mats for front and rear, cost $180 new. They are made from stuff that lasts forever and they are cupped on the sides so they hold the melted snow water.
-Dual optima battery box and aux. fuse box: I modified this vehicle to fit two yellow top Optima batteries in the stock location. Parts of this mod have been removed, but what is left is still a good start: dual battery box located where stock battery would go, one yellow top Optima battery, aftermarket fuse box. All you need is the second battery and an isolator of your choice.
This was not a cheap mod, but is absolutely awesome. I have no fear of my batteries. I have run my fridge for almost 48 hours in Colorado this summer without starting the vehicle before the alarm went off for the aux. battery. No problem, the starting battery was fine. It was a good excuse to go do some rock crawling and charge the batter back up!!
Here are some pics to help describe and a link to a thread I posted about it.
http://www.toyota-4runner.org/3rd-gen-t4rs/63214-dual-battery-set-up.html
-OME 882 front coils
Land Cruiser rear coils: These are the front coils off of an 80 series Land Cruiser. They fit 4runners and give about 3" of lift
-Sonoran Steel differential drop: This lowers the front differential to help reduce the CV axle angle…a little. Here is a thread about my install:
http://www.toyota-4runner.org/3rd-gen-t4rs/59416-s-s-diff-drop-experience-photos.html
-5 stock 5-star rims with 5 BFG all terrain 265/75/16 tires: I rotate all 5 tires, so the spare always match. They still have a ton of work left in them.
4runnertread.jpg~original
-Additional overhead light modified into overhead cargo door: I added a light so that I could see while at the kitchen in the back of the vehicle. Here is a link to more details:
http://www.toyota-4runner.org/3rd-gen-t4rs/52230-cargo-door-light-brand-new-mod.html#post426307
-Additional power outlets run to back seat: I added outlets where the ashtray in the back used to be. The cup holders above still work.
rearpower.jpg~original
Tundra front brakes I have the 199mm front brake calipers and rotors from a Tundra. This provides much better braking.
-Deck plate mod
-ISR mod: The intake pipe silencer was removed and replaced with a metal pipe. I still have the silencer and it can be easily reinstalled. This removal is supposed to give you a bit more power, but I doubt it.
-One rebuilt CV axle (last year, by Toyota)
-Poly rack and pinion bushings
-Front sway bar end links moved to rear sway bar for increased length:
-Front sway bar removed: I still have the bar to give with the rig, but I like it with it off. I bought poly bushing because they were supposed to be better but they were so stiff that the bolts in the bracket broke. I thought I’d see how it is without it. It is way more flexy on the trails. It does lean a bit more in turns, but only if your driving crazy. I don’t mind it. I don’t use this vehicle for my daily driver either.
-Extended stainless steel rear brake line
-Homemade roof rack: I bought this rack as just a cage, then welded feet on it so that it mounts in eight places to the roof. I welded uprights on the end so you can put a ladder on top. It has quick fist clamps mounted around it to hold one short shovel, one standard shovel and an axe. It also holds a high lift jack. This is all just on the sides. Inside I can fit four large plastic boxes, or tarp my stuff.
rack.jpg~original
rackmounting.jpg~original
rackquickgrips.jpg~original
-daytime running lights removed: I wanted to be able to drive into camp without shining lights in my friends tents/eyes...also made room for the dual batteries under the hood)
The known problems/issues
I am an honest seller, so I will tell you of the issues that I know of. I just paid Toyota about $250 to look over the whole vehicle and tell me anything that needs to be done.
-The clear coat on the hood is peeling and breaking. It should be redone or something.
-Rear bumper has a dent from backing into a tree.
-wheel flares removed for visibilty of front tires while 4-wheeling. This left holes in the body around the wheels. I covered them in grip tape circles with the intention of running rhino liner down the sides. It is a huge benefit while 4wheeling and totally worth it for how I used this vehicle.
-Scratches, as would be expected of a Colorado trail rig...pin-striping…
-The power steering pump is on the way out and needs to be replaced.
-The rack and pinion is getting loose, and could probably stand to be rebuilt someday soon.
-The differential fluid needs to be changed.
-The driver’s door automatic lock doesn’t work.
-Needs new front rotors. I bought aftermarket Tundra rotors and pads and they did not hold up. The rig really needs new Toyota rotors and pads, in my opinion. I am now a believer in only OEM rotors and pads.
The whole rig as is: $11,500
You can choose what you don’t want and subtract the price (all below new cost):
-minus the roof rack (-$150)
-minus the extra Optima battery (-$180)
-minus the National Luna battery isolator (-$250)
-minus the CB and antenna ($120)
-minus the floor mats ($100)
If you don’t want this stuff, I will use it on my Land Cruiser. This would make the price:
$10,700[/b
:wow2:
CSL is a great guy and an honest one at that,
this 4runner is an EXCELLENT BUY at the price...
If you want a completely offroad ready Expedition rig, then this is your 4runner.
I had a feeling...
came in here via Denver craigslist. I'm sitting there thinking...dang this sounds like CSL...
had a feeling you'd be moving up to an LC. Great rig-well equipped!
bump!
Thought I was patient to wait for a buyer that wants to jump right into a built rig, but I don't feel like re-buying stuff for the LC, so...
NEW PRICE:
$10,500
REMOVED FROM ADD ABOVE:
-CB and antenna removed.
-Dual yellow tops and battery isolator removed.
Now has 139,500 miles.
Still has the e-locker and the offroad muscle needed for Colorado Trails. :roadkill:
NOTE to east coast rust rigs: 3rd gen runners in Colorado don't go for as cheap as your rigs do...so no comments about my price, please...it is good for this part of the country.
Do you have the original flares since the holes on the side really make it look a bit rough for a rig costing $10k even in Colorado.
Also when was the TB/water pump last done,brakes?
No comments about our rust. :cool::lmao: Wish I saw this two months ago and you shipped to east coast Canada. :sobbing:
I dont know about his TB/Water pump, but his flares are on LINY4runners Rig...
I hear ya, but this is not a pretty boy rig...its functional first, vanity last. I hope to find a buyer looking for just that. That is not to mean it wasn't loved or mechanically taken care of. Its just not a rig for chasing tail in.
I can self spot without having to get out of the rig, all because those flares are gone...and that's without using wheel spacers.
$200 to $300 will get you rhino lining down the side of the rig. That was my plan until my plans got quickly messed up.
As for the timing belt/water pump, that was done at 118K, right when I bought it. Service sticker on the engine.
New price
So, I've started the build on my Land Cruiser and have begun to steal parts from this 4runner for sale.
New price:
$10,000
Edits from first post:
-No more dual battery set up. I remove the isolator and the two optima yellow tops. The bracket is still left to fit two optima batteries, but you have to buy your own.
-No more CB. I removed the CB.
-No winch (I think I already mentioned that).
-Now has 139,700 miles, but I am not really driving it anymore, and just cancelled the trip to Moab I was going to take in a few weeks. Would have been the last trip in this rig, but my focus has moved to my Land Cruiser.
Go to Denver's craiglist and search "2000 4runner". You will see that mine is priced very, very well for the Denver Metro area. There are other STOCK rigs that they are asking $12,000 or more for.
Here is a video a friend of mine put together of this rig on the trails in Moab. This is what this rig is built to do...
<object width="640" height="385"><param name="movie" value="http://www.youtube.com/v/qDUX_3oIQWw?fs=1&hl=en_US"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/qDUX_3oIQWw?fs=1&hl=en_US" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="385"></embed></object>
Bump and lower price
See new description in original post.
Price is now $9,000
I plan to leave it at this price for a while as it is starting to get to be a pretty low price for this rig...
Price is now $9,000
Might want to update the topic title too, it says 11,5 still.
and if someone doesnt take this thing at 9k they are dumb... cmon guys, I see all these newbies that have bought 4runners recently and this one is waay better than all of those and its already built!
Im tellin ya, if someone doesnt step up! :bash:
huh- I bought a stock 4x4 1 owner 4Runner in Central New York w/135k for $4500 and it aint no Rust Rig :nono:
chrome bumpers have rust some and there is corrosion but no frame issues or rot fwiw
best of luck on the sale - :frog:
Snowman904
