Subs in the floor!!
SV_Dude
Moderator
I know this isn't a 4 runner, but it's still a toyota. This project was done on my (new at the time) 2010 Tundra Double Cab. I had this truck for about 2 months before I started cutting it up :) I figured I would share this project with fellow enthusiasts!
***EDITED TO ADD ALL PICS AND VIDEOS TO FIRST POST***
The pursuit of sound in a 2010 Double Cab.
Equip: Stock head unit
Zapco I5100.7 amp
front stage: not telling :D But it is a 3 way active and sounds bad @$$!!!
Subs: 2 Image Dynamic q12 v2's
So, I went through a handful of ideas and trials as to where I would house my 2 Image Dynamics Q12 v2's and couldn't come up with much. There's just less than 6 inches of real estate under the back seat. My original plan was to weld in new seat mounts and raise the back seat a couple inches. That was a bad idea because then I wouldn't be able to see much out of the rear view mirror. Other ideas were to build a center console but I like what I have now and I like the fact that I can raise the seat for a 6th seat if I need it.
So... Why not put them in the floor? Here's the plan: put the subs in the floor right where the back seat passengers feet will be. I will cut out the floor board and make a new steel box made out of 1/16th steel and rebuild the floor board to allow me to add a couple of sealed sub enclosures. I didn't take too many pics because I wanted to keep progress going. Here's the progress so far:
A stripped interior to see what my options are:
IMAG0166.jpg~original
Real estate under the truck:
IMAG0168.jpg~original
I spent more time on the passenger side because the driver side is a lot more free for under carriage space due to the exhaust pipes on the passenger side.
After taking my measurements I figured that the passenger side sub enclosure will be 7.5x14x16.5 and the driver side box will be 9.5x13.5x13.5, and after adding a little MDF inside the steel housing, that will give me .75 cubic feet for both enclosures.
Here's both sides of the floor board cut out:
IMAG0173.jpg~original
I made a couple of mock boxes out of cardboard and installed them:
view from passenger side:
IMAG0174.jpg~original
driver side:
IMAG0175.jpg~original
That's about all I got today. Tonight the plans are to cut all the 1/16th sheet metal into the proper sizes, then weld them to make each box.
Hopefully I'll be done with it tomorrow but plans are to make it seem as if the truck is still 100% stock until you hear the stereo. I will fab up some grills with a steel frame and steel mesh so it's strong enough to withstand a bunch of abuse and protect the subs under the carpet.
More to follow tomorrow!!
Exhaust wrapped to keep heat away from sub boxes.
IMAG0176.jpg~original
Sub boxes built and installed:
IMAG0179.jpg~original
IMAG0177.jpg~original
IMAG0178.jpg~original
Boxes primed inside and out for rust and corrosion control:
DSC01372.jpg~original
DSC01379.jpg~original
DSC01380.jpg~original
Some MDF added to the inside to start some sub enclosures:
IMAG0201.jpg~original
IMAG0202.jpg~original
Sealed the MDF edges to ensure an air tight seal:
IMAG0210.jpg~original
IMAG0211.jpg~original
IMAG0212.jpg~original
Subs installed:
IMAG0216.jpg~original
IMAG0215.jpg~original
Grills built, added some 3/4" weather stripping to avoid any rattles:
IMAG0225.jpg~original
IMAG0232.jpg~original
IMAG0233.jpg~original
Grills installed:
IMAG0227.jpg~original
IMAG0228.jpg~original
IMAG0231.jpg~original
Interior re-installed:
IMAG0235.jpg~original
IMAG0238.jpg~original
Flipping a quarter on the carpet:
With some snoop: (not my style but it's got some bass)
VIDEO0005 - YouTube
More so my style, not as much bass but still moves a coin around:
VIDEO0004 - YouTube
Nice job! Throw on some Maiden and get a free foot massage!
Where Eagles Dare would be my choice... :)
Holy H*ll Batman; never would've thought about adding subs under the passengers feet! Pretty sweet! :nicethread:
So sick! Wish we had room to do that
SUV's have all the room in the world for anything you want! It's all in the mind of the creator... and how much fabrication you want to do. You can easily glass in some subs in the rear side panels and make it look factory.
Why do you want 18's? Do you compete in SPL? I try to build my stereos for sound quality. My subs in the truck don't really bump a whole lot. I can turn my gains up and make them bump but that kills the music in my opinion. Eventually I'll glass a 10 or 12 in the rear corner of my 88 4runner and build a mount on the other corner for a couple of amps to drive the sub and a 3 way front stage.
I built it, but thanks!
Hopefully I won't have to worry about someone buying it used for a LONG time. I won't be buying a vehicle that expensive for a long while not do I plan on replacing that truck for a long while.
You sir, get an A+ for fabrication. Great job again.
Can you post a pic from under the truck?
i dont but my buddy does and he works making custom boxes and setups. i get professional systems for dirt cheap. he will go through setups every month and ill usually buy em off him and run them till hes got another for me.
I put 2 12's behind the back seat on one of those Tundras let me see if I can dig up a picture of it.
How do you like those SI subs?
Im impressed by the amount of room behind the seats of a Crewmax. But Im sure if the OP had a Crewmax, he probably wouldnt need to put subs in the floor.
