Old 05-24-2012, 06:07 PM #1
matthewkristof's Avatar
matthewkristof matthewkristof is offline
matthewkristof is on a distinguished road
bad to leave charger plugged into 12v?
i want to add an additonal socket by tapping into the wiring for the smoker's box that i don't have. i plan to mount this socket in the center console. no issues there. what i want to do is keep an iphone charger plugged in at all times into that added socket, and when i need to recharge the battery, pull the cord from my center console and plug it in.
my question being: is it bad to leave this setup like this all the time? is there any harm to the electrical system or the new socket?
i'm a beginner when it comes to wiring for cars, so be gentle. i do not have the constant power on mod either. thanks in advance.
MCK
matthewkristof is offline   Reply With QuoteReply With Quote
Old 05-24-2012, 06:48 PM #2
R.A. R.A. is offline
R.A. is on a distinguished road
You should be fine. There's no problem leaving something in the socket all the time. There's quite a few who have done it; I will be doing it soon myself. I'm going to do J.A.'s power mod; but it disturbs me leaving it hot all the time (with something plugged in like a charger). However, when I do the power mod, I am planning putting a lighted switch in, so I can turn the sockets on/off as I desire.
The computer and others electronics are constantly on. I see no problems with leaving a charger on too (just don't go bypassing a fuse!). Just my opinion/option in putting a on/off switch in.
R.A. is offline   Reply With QuoteReply With Quote
Old 05-24-2012, 07:06 PM #3
i've thought about a switch as well...found some that can fit in the blanks...just don't really know how to wire it... =P
Old 05-24-2012, 07:11 PM #4
T4rman's Avatar
T4rman T4rman is offline
T4rman is on a distinguished road
T4rman's Avatar
Originally Posted by R.A. View Post
However, when I do the power mod, I am planning putting a lighted switch in, so I can turn it on/off the sockets as I desire.
I hard wired an inverter with a switch similar to this setup. I also installed a voltmeter so I can monitor battery usage. If you run a switch you can leave whatever you want plugged in all the time and just flip the switch if your battery gets too low.
This is what I have. It's great for $30
http://www.summitracing.com/parts/SUM-G2983-1/
Edit:
I can help you with anything you have trouble with but its really not that hard. Most switches come with directions. I have the contra rocker switches that will fit in the factory blanks with a little work. They look almost oem too.
4Runner Build
T4rman is offline   Reply With QuoteReply With Quote
Old 05-24-2012, 07:24 PM #5
Those switches are nice. I was looking at those too. Putting a switch in is no problemo.
Old 05-25-2012, 12:11 PM #6
ok so how would i wire a switch? i thought about this one:
Switch Rocker Lighted Red 3 Blade, 58328-04, Cole Hersee
it goes next to the rheometer setting thingy. i like that the light tells you its status. i read antman's post on his 5th generation mod, but i'm still hazy on wiring.
ANTMAN'S Thread
i like what he did to make it look oem. i don't want something to look tacky. i like your switch setup too. any help is greatly appreciated. just now getting into some small mods...not sure what took me so long.
Old 06-03-2012, 04:44 PM #7
T4rman's Avatar
T4rman's Avatar
I use these guys for 12volt switches. They have whatever a lot of different stuff. Look for a SPST(single pole single toggle) switch. Or just pick up one like you posted. Yours is rated to 25amps which is plenty for anything you will plug into your 12v socket.
http://www.otrattw.com/
On a lighted 3 blade you will have(from
Left to right on the diagram)..
1) a positive wire comming from the battery to the switch.
2) a positive wire going to your socket and then to a ground (like a bolt that is connected to metal)
3) a ground wire to another bolt.
Like this...
Sorry for the terrible diagram, sharpie on paper towels is pretty hard to work with.
4Runner Build
Old 06-03-2012, 09:26 PM #8
See if I understand this:
I can tap into any positive wire (like the unused cigarette lighter in the center console) and run that to the first pole. Then the second pole will be connected to the 12v socket, and the other wire from the socket will go to a ground point. Number three is self explanatory.
Thanks for your help!!!
2007 SE, Galactic Grey Mica - original owner
Mods/Upgrades: Oh Crap Handle on driver's side, Hilux Surf Trash Stash, Amber Colored Auto-Dimming Mirror w/compass, USB ports using 115V switch, LED interior, Weathertech Digital Floor Liners, Homelink Garage Door Opener, Footwell Lighting, Automatic Headlights, Dual Cargo Organizers, Maplight Mod, Morimoto 5k HID Low-Beam and Fogs, LED exterior, 15% 3M tint, AVIC-6100nex, Pioneer speakers (TS-G1345R, TS-G1645R, TS-T110), Limited Grill, Mini Backseat Organizer, Heated Cloth Seats, KO2s
Old 06-05-2012, 12:43 PM #9
What if I use a Toyota switch?
http://www.toyota-4runner.org/audio-...-115v-mod.html
I know it's technically not 115V but I like the OEM style switch and how it lights up. Can I wire up the extra 12v the same way with the above switch?
Thanks again!
Old 06-05-2012, 03:50 PM #10
T4rman's Avatar
T4rman's Avatar
I believe so, I haven't used OEM Toyota switches before (they are expensive!) but if someone can provide you with the diagram for the switch you buy it will be easy.
I'm not one hundred percent sure which positive wire you are talking about but most of them are only hot during certain situations, like ignition on/off. I usually run mine off the battery to make sure I'm not going to over load any circuits. Maybe someone else could provide you with the cig socket diagram and tell you if it could handle the load and turn on when you want it to.
4Runner Build
Old 06-05-2012, 05:13 PM #11
I have a diagram for the Toyota switch (it's in that link on my previous post), and I also have one for the cigarette outlet. I know it can handle the load (only to charge cell phones). I was just wondering if it's possible. The Toyota switch has the relay for the inverter which I'm not hooking up.
My only concern would be where to hook everything up. Would the extra 12v socket attach to wires #3 and 4 per the 115v mod? I know how to get to the rheostat power but not sure about position #6
Old 06-07-2012, 10:04 AM #12
T4rman's Avatar
T4rman's Avatar
Originally Posted by A/V1 View Post
6. is the power "in" from ignition circuit for the "on" lamp
5. (not used)
4. The switch switches ground in this application. This is the wire for the inverter relay which gets the ground through the switch
3. is the ground for the the inverter relay and "on" lamp,
2. illumination ground (through the rheostat)
1. illumination power
The way the switch is designed to be used is to have two hot wires, 6 and 4, that connect to a common ground that can be switched on/off.
Tab 6 will need to come from a positive wire. This is for the little light at the top that turns on with the circuit.
The 12v socket will have one power wire going to the socket from another source (the unused 12v socket power) then connect the ground wire to your switch at tab 4.
Tab 3 will just be a wire from the switch to a ground.
Hope that helps.
4Runner Build
Old 06-07-2012, 12:38 PM #13
That helps immensely. Thank you so much!
Old 06-10-2012, 12:32 AM #14
T4rman's Avatar
T4rman's Avatar
Yeah glad I could help. Let me know if it works out.
4Runner Build
Old 06-14-2012, 12:09 PM #15
14 gauge wire would be sufficient right?
HTML code is Off
is it bad to keep something plugged into power plug 24/7? matthewkristof Engines / Suspension / Wheels / Tires / Audio / Accessories 3 02-06-2012 02:38 AM
Plugged my new trailer into 4R and brake lights/turn signals don't work mac0822 4th Gen T4Rs 3 05-23-2011 12:50 PM
Can They Leave Toyota Alone? Mark86 General Discussions 13 05-14-2010 04:17 PM
if you want to kill yourself, leave us out of it dsongalong Off Topic 13 02-06-2005 10:00 PM
i plugged my bumper.. what'd ya think? BlkSS1755 Engines / Suspension / Wheels / Tires / Audio / Accessories 18 12-18-2003 11:03 AM
