Improving stereo sound in 5th gen
JayBeeeeeee wow that's a lot of work... Thanks for the list of speakers... Want to make sure I get the right ones... And the correct adapters so that I do not have to cut the factory wires is great.... I wish it wasn't so difficult to swap out speakers... But looks like to do it right even if you cut out the factory speakers center and use the frame as a mounting bracket you still need to have some wood skills to make a mounting plate for each speaker... I guess always another excuse to buy a new tool...
Did you have any issues putting on any of the door covers/hatch cover? Wasn't sure if these speakers might stick out a little farther.
I noticed on the dash speakers some people use the bass blocker and some didn't need too.
This is a great write-up you should also post it in the 5th gen section, sure a lot of people would would find this useful.
Kappas in Dash
Dash Speaker Connecting...see this link (post #162 by darkdane)
http://www.toyota-4runner.org/5th-g...ce-kappa-3-5-dash-speakers-11.html#post794787
For Mounting...see this link(post #217 by Kraeken)
http://www.toyota-4runner.org/5th-g...le-difference-kappa-3-5-dash-speakers-15.html
My install...
Factory Tweeter? Passenger Side
Another View
See That Blue Thing?...Don't Throw That Away!
Closeup of Factory Bracket (Don't Throw Away The Bracket....You Will Need it Later)
The Kappas...Plastic Ring Removed...Ready to Install
Shroud Removed From Dash Grille
Kappa Installed...Driver' Side
Grille Installed...Passenger Side
Sound Deadening Install
Driver's Side Front Door...Water Does Get in When it Rains
Pass Side Front Door Lower Section...Don't Block the Drain Holes at Bottom
Remove Styrofoam Block...Save for Re-installation
Place the Material Behind the Bracket
Upper Section Done...Don't Cover the Reinforcement Pipe
All Done...Vapor Shield Put Back in Place
Rear Door Finished
Ready for Speaker Install
JayBeeeeeee wow that's a lot of work... Thanks for the list of speakers... Want to make sure I get the right ones... And the correct adapters so that I do not have to cut the factory wires is great.... I wish it wasn't so difficult to swap out speakers... But looks like to do it right even if you cut out the factory speakers center and use the frame as a mounting bracket you still need to have some wood skills to make a mounting plate for each speaker... I guess always another excuse to buy a new tool....
You could get 6x9s for the front and just glue them like I did the Rear/Tailgate. The plywood plates were not that hard to do. Just put the factory frame on the board face down,
and trace around the outside of the speaker. Borrow a Scroll Saw from your neighbor and cut em out. They don't have to be perfect...nobody is going to see them after the interior
panels are put on.
Did you have any issues putting on any of the door covers/hatch cover? Wasn't sure if these speakers might stick out a little farther..
The new speakers did not stick out alot more than the originals. But I cut those shrouds off because the new speakers were slightly bigger in diameter than the factory ones,
was just trying to avoid any interference and did not want the new speakers touching the door panels at all.
The dash speakers were a different story though. They were a much tighter fit and needed as much room as I could give them. There is a plastic ring glued to the Kappas
that is fairly easy to remove if you are gentle and just give an easy twist.
Ya, I mulled over this for quite some time...did a bunch of reading on the subject. Decided to just go for it while I had stuff apart...no regrets so far. They sound great...
no popping as some have experienced.
Well thanx so much. You could always post a link over there for me, rather than double posting all the pics, etc. :peace:
Great writeup Go JayBee! Pics will help tremendously too.
How's it all sound now?
Thanks for the comp...
"how's it sound?"...well, I think it sounds awesome.:guitar2:
As stated earlier in this thread, when questioned about not adding a sub-woofer & amp:
"You are certainly entitled to your opinion. Yes, the Kappas are "rated" for many more watts than the factory speakers,
but, the factory head unit has ample power to drive them. It's also is a matter of your personal listening requirements.
I am getting to the age where the "quality" of the sound is more important than the "quantity". IMO, simply replacing
the factory wimpy speakers with Kappas was a vast improvement in the sound quality, range, theatre, whatever you prefer
to call it. The sound deadening has also contributed to that."
"I wholeheartedly agree with you that a sub-woofer would add to the range of sound. And yes, the Kappas can certainly
take all the power you can give them. However, the OP stated that he was looking for a solution in the $500 range, and
sounds like he is not interested in ripping his new rig apart to re-wire it (an amplifier would require this)."
"In summary: I was simply trying to pass along my experience with a reasonably priced improvement. The solution you
have proposed would certainly "improve" the sound quality but the cost would probably end up over $1000. Clearly out
of the OP's budget if I read it correctly."
Hope that answers your question:party:
Door & Tailgate Panels
There is a thread that shows this in detail...will link it when found.
Thanks to "sp8ball" & "Antman"...:hail:
http://www.toyota-4runner.org/774421-post389.html
You'll need to remove 3 screws before you can start yanking on the door panels. Be gentle
prying these covers open....the panels are very soft and scratch very easily.
While you are in there, change light to LED.
https://www.superbrightleds.com/mor...bus-led-bulb-5-smd-led-wedge-base-tower/1127/
Door Lights (35 lumen)
The 1st time you remove the Tailgate Panel, it will be tight. There is an arrow molded into
the lower/passenger corner. This is where you start pulling.
While you are in there, disconnect the tailgate cargo lights and install led panels.
Cargo Area Lights
The one on the left...(140 lumen?)
https://store.ijdmtoy.com/ProductDetails.asp?ProductCode=LED_9SMD_D31_SKU24
The one on the right...(70 lumen)
https://www.superbrightleds.com/mor...-bulbs/de3175-led-bulb-4-smd-led-festoon/238/
Some Good Tools to Have Handy...Less Than $20
Good job and thanks for sharing, JayBee.
... simply replacing the factory wimpy speakers with Kappas was a vast improvement in the sound quality, range, theatre, whatever you prefer to call it. The sound deadening has also contributed to that."
+1 Factory speakers seem one-way. One driver would try to reproduce sounds of all frequencies. That's inefficient and "dirty". Vocals or worse yet, treble freqs (fast vibration) sent to heavy, wide speaker cones of stock speakers will sound muddy, muffled.
Two-way speakers like ones you installed send certain frequencies to driver that will reproduce them more efficiently and cleanly, resulting in cleaner, clearer sound.
Re: bass blocker a Ya, I mulled over this for quite some time...did a bunch of reading on the subject. Decided to just go for it while I had stuff apart...no regrets so far. They sound great...
Agree. In line with sending frequencies to proper drivers and blocking those from drivers not meant to reproduce them. For example, bass sent to tiny dash speakers will sound like pops. These are best sent to heavier, wider cones of a woofer/sub-woofer.
Mounting Dash Speakers
The 3.5" Kappas are a tight fit and trying to use the provided mounting holes won't work unless you can fabricate some sort of strap.
I found that the existing factory brackets could be trimmed with a hacksaw to make the install much easier.
Here are some pics, LH (Drivers Side) & RH (Passenger Side) I took after they were installed. But I set what was left of the factory
bracket next to the Kappas so you could see which end was used. The LH & RH factory brackets are not symetrical, i.e. not mirror images.
The Factory Mounts....The One on The Left Taken FRom The Driver's Side
RH-Removing Grille...
RH-View From Ourside....Bracket on Speaker
RH-View From Outside...Bracket Next to Speaker
RH-View From Inside
RH-Re-Installing Grille
RH-Grille Installation...Careful to Not Let it Rub Against The A-Pillar. It Will Leave a Mark!
LH Side Dash
Driver's Side...
LH-View From Outside...Bracket Positioned on Speaker
LH-View From Outside...Bracket Next to Speaker
LH-View From Inside
LH-Grille Re-Install...Don't Let it Scratch The A-Pillar!
My install...
Another View
Thank you for this. I used your bracket method and this was a huge help.
Awesome write up! Hoping to do this on my 2014 4runner soon.
Hopefully all the parts listed are still the same on mine as yours.
some of the drivers he used are now discontinued
here is my dream setup
Dash 53.95 per pair
Reference 3002cfx - Infinity US
Reference 3002CFX
3.5" 2way 85-21Khz 3ohm 91db sensativity
25W/75W
Diameter (in) 3-1/2'
Total Depth (in) 1-7/8" ( mag to top of tweeter)
Cut out Diameter (in) 3-1/8"
Mount depth (in) 1-7/16"
Mount flange to top of tweeter 7/16"
Front Door 95.95 per pair
Reference 9602ix - Infinity US
Reference 9602ix
6x9" 2way 46Hz–21kHz 3ohm 94db sensitivity
100W/300W
Rear door/rear hatch $$??
Kappa 62.11i - Infinity US
Kappa 62.11i
6.5" 2 way 45-25Khz 2/4ohm 95db sensativity
75W/225
still working out the the best sub to install in the factory enclosure/ may require additional depth gained by using spacer rings under factory cover and/or possible cutting factory cover open and using spacers right up to the factory exterior
Possible options
Image Dynamics ID8 D2 V.3 85.4db sensitivity
alpine SWR-8D2 83.5db sensitivity
Kicker solobaric ( Square) 83.6db
Pioneer TS-SW2002D2 Shallow Mount 86db sensitivity most efficient
Helix Esprit E8W 85db
Dash 53.95 per pair
Reference 3002CFX
25W/75W
Reference 9602ix
100W/300W
Kappa 62.11i
75W/225
Gotta ask why you would use a better speaker in the rear than the front doors.
in this case look at the db sensitivity differences.
when the rear sound propagates the loss in db from the rear door to the front ears will be about 2 to 3 db lower then the front. negating the effects of the seat blocking sound. So there will be rear fill but would not pull the sound stage back/ down. Also note the rear and front door speakers you can switch the tweeter -3db to also prevent pulling the sound stage to far back and/or down.
of course this is all theory crafting not actually having access to a spectrum analyzer like i had back in my stereo install days.
IMHO the best sub to replace the factory one with....
Image Dynamics 8" DVC
The super low FS for an 8" is where its at.
everything was simulated with VC being run separate off of OEM AMP assuming 45 watts RMS per channel.
-3dD point
Best: ID8 D2V4 @ 36hz
Better: Pioneer @50hz
Worst: Alpine @64Hz BAD!!!!!!!
RMS power capability per VC (modled using rms power per VS and not peek per VC so very conservative and safe power/thermal limit numbers.
another way to think about this is any power over the limit at this point is in a major way being converted to heat instead of mechanical/acoustical energy
Best: ID8 D2V4 @ 33 hz with 75w per VC
@ 25 hz with 24.9W per VC
Better: Alpine @ 54 Hz with 175W per VC
@25Hz with 8.13W per VC ( very low thermal limit here but it is only a 8" sub
Worst: Pioneer @83 Hz with 75W per VC thermal roll off point is very hi for a Sub.......
@25Hz with 0.66W per VC
ID8 D2V4 has the best d-phase/d-fq
The Alpine has the best D-msec/d-fq for the really true audiophiles. ( but usually below 60Hz you will never notice group delay unless its extreme on the order of +20msecs)
If including a +12db per octave Cabin gain /transfer function starting at 50 hz ( this was an estimate based on internal volume of the 4 runner)
ID8 D2V2 puts out higher dB than the other 2 subs in the frequencies that everyone wants in a sub woofer.
Cone displacement is good on all and is below mechanical limits
For these 3 the ID8 D2V2 is the best choice only negative is getting the 4.75 mounting depth to work. May require a spacer ring on the front of the enclosure and removal of the internal ribs on the back inside of the enclosure.
Also to improve db recommend to cut the factory cover and use either a 10" grill or 12" grill to allow the pressure wave to couple with the internal volume of the 4 runner more efficiently.
Ya i know guys most likley way more info than you were looking for lol Mechanical engineer with passion for acoustics :)
If you want me to model another driver to compare just let me know; if the manufacture publishes the T/S pentameters I can model it.
