The new speakers are in
CMTAZ
We call all agree that the crappy oem speakers in the non JBL system need improvement. After searching around and reading reviews I was leaning towards the OEM audio plus system ($1700 - $2000) or some Focal drop ins ($300 per pair x 3). After some more deliberation and reading some more reviews, and a 10% ebay coupon showed up), I decided to take a chance on the PowerBass drop ins. The total cost for the 3 pairs was $234.00 ((80.00 x 2) x .9) = 144 for the 6.5” and (99.99 * .9) = $90.00 for the 6x9” speakers.
Note: I do not expect these to sound just like the Focals.
First the install:
I won’t go into the panel removal because there’s a boat load of threads and videos on how to do that. I first installed the hatch 6.5” speakers and some noico mat behind them. I did NOT mat the entire hatch, just some behind the speakers. These 6.5” are 100% drop in. Take hatch off, unplug and unbolt the speakers using a 10mm socket, plug and bolt the new PowerBass 6.5” speakers in. That’s all there is to it. I then installed the rear door 6.5” speakers and some noico mat behind them. Again, did NOT mat the entire door, just some areas around the speakers. These too are 100% drop in.
Then the 6x9 component set arrived. I then installed the tweeters in the dash. Still drop in, they took a little ‘finessing’ to fit in the oem tweeter bracket. Note: I found it easier to remove the bracket, put the new tweeter in the bracket and then put the bracket back in. That may be because of the tight spaces (up against the windshield)), and the fact that I am left-handed.
Lastly I installed the 6x9’s in the front doors. While they are still drop in, I did have to drill the speaker bracket to match one of the oem holes. Again, did NOT mat the entire door, just some areas around the speakers.
The longest and most difficult part of this process is putting the door panels back on….
The sound: I put the 6.5’s in 2 days before the 6x9s. Even after install the 6.5’s in the rear doors and hatch it sounded much better (not surprisingly the rear sounded clearer then the front). After installing the 6x9s and the tweeters there is much more clarity in all types of music. While I will probably change the headunit eventually, I believe this upgrade greatly performs beyond it’s price.
pictures are: oem 6.5 weight & back, powerbass 6.5 weight & back, oem 6x9 back & weight, powerbass 6x9 back & weight,
:happy
Still like the sound quality? How’s the bass?I’m on the fence with the OEM Audio plus set up and the focal look great but are expensive for replacement speakers.
Does this help with the volume? I drive with windows down quite often and would like to have more volume coming out from the factory unit.
As on my perception the Entune Premium Audio system has many advantages including the Entune App Suite. This sound system comes standard on the SR5 Premium trim level and is available on the SR trim.
I did the focal drop ins and found that volume went down actually.
Need an amp to drive higher RMS to them to take advantage. The most obvious benefit from the drop ins alone is sound quality in the mid and high ranges
in response to the comments about volume, the 5 channel amp will REALLY bring them to life !!! At the same time I added a Pioneer TS-SWX3002 12" Shallow Mount Pre-Loaded Enclosure. with the windows down on the highway - it is STILL loud enough to cause ear discomfort.
The audioshop that installed my amp was so impressed with these speakers, they picked up PowerBass as their value line. I told him i should get the amp install for free :cool: (no luck with that :().
My amp is in.
My amp is in.
Would you recommend the shop? I've been looking PowerBass option for a few a while now and my front tweeters are starting to give up on me.
Quaility Car Audio - Gilbert AZ. Honestly you could do the speakers yourself. The 4 6.5" coax took me 4 hours (placing dynamat behind just the speaker and taking my time ). The fronts took 1 - 2 hours (placing dynamat behind just the speaker).
A shop will charge 60 - 80 a pair for the install. All 3 pairs cost me $234.00 (with a 10% coupon from ebay) - G/L
My amp is in.
Do you have a picture of what the sub looks like in the back?
It is amazing how janky almost all OEM audio is with Blose taking an exalted throne. Even the Mark Levinson system in my LS460 speakers were not nearly as impressive in terms of construction.
Quite the upgrade.
If you added a nice am putting out 40-60 RMS to each speaker, you music will come alive! Amps do more than anything else to improve sound quality.
nice amp with 150+ watts rms can do better, can you say headroom lol.
running close to 200+ really make certain speakers come alive. really alive.
