Originally Posted by Bump N Run
ACC is what you want to use. If your add a circuit tap has two fuse slots, use a 2A fuse in the slot for the CB and put the original 15A in the other slot. The package should specify which fuse slot is which. My add a circuit fuse holder said that the fuse slot close to the red power wire is for the CB,GPS, radar or whatever you are adding to the car. The 15A slot will still protect just like it was originally. The 2A fuse will protect the CB only. (or whatever is tapped into that red wire) Hope this helps.
Thanks Bump, I didn't realize before I opened the package on the circuit tap that it has two slots. I did exactly what you suggested, and it worked great... I have a functioning CB now... thanks for the help!
Followup question... how would one add another aux device? Obviously it wouldn't be a good idea to plug a circuit tap into the existing circuit tap. If I wanted to plug in my GPS, would I have to add an aux. fuse panel, or is there an easier way?
