FJ vs. Tacoma springs?
gm350reratliff
A lot of talk on here about running FJ springs. But what about running Tacoma springs? Obviously I am comparing the front springs. Would Tacoma springs lift the 4runner more or less than using FJ springs? Another question is, are the Trail Teams Edition FJ springs different than regular FJ springs?
Thats a good ? I would think they would work. The TT springs are the same as the reg. fj but the shocks are a hevier duty Bilstein vs the std. Tokicos.
A lot of talk on here about running FJ springs. But what about running Tacoma springs? IDK but I like the height of of the Taco. Looking at the lower control arm it looks as though the Taco springs are even longer the FJC springs. (That's assuming the top of the strut mount is in the same relative position.) I want to try a set or better yet I want someone else to try a set and write it up:D Obviously I am comparing the front springs. Would Tacoma springs lift the 4runner more or less than using FJ springs? Another question is, are the Trail Teams Edition FJ springs different than regular FJ springs? No difference. The only difference in FJC springs is a slight difference 2wd to 4wd.
:cheers:
Find me a used set and send them, I'll do it:D I'll give my feedback and I'll give the springs back if I don't like them:lmao: I'm ready to go up a little more...
Are they even readily available like the FJ springs are. Could probably get a set for free from someone that upgraded just based on no demand currently.
tacoma springs
has anyone tested this theory yet??? i just got a nice set of bilstein tacoma struts and shocks, but im currently running fj spring and shocks all the way around. now i was riding next to a tacoma with a same size tires and a 3" lift on the highway and his truck did seem to be higher then mine plus where i live in south jersey there tons of lifted tacomas and they all seem to look bigger then me. maybe its and illusion because the tacoma has a taller hood and a more bull nose where the 4runner has a gentle slope to it. any info before i pull the trigger on a set of tacoma spring and have to find out the hard way lol
No one to my knowledge has tried this.
tacoma springs
i found my answer about 20 min ago on fj cruiser forum and this guy put tacoma springs in his fj and turns out his fj is nose high, even if it settled at best it would just be even which on an fj is still a gain since they have a rake just not as drastic as our 4runners have. needless to say ill be doing this as soon as i have the tacoma springs
tacoma springs
ok tomorrow is the big day ill be swapping my fj springs w/ tokicos for tacoma springs with yellow and blue bilsteins which are everything is brand new and i got off ebay the springs and 4 bilsteins cost me 180 shipped. ill do before and after measurements. i will tell u front what i noticed the tacoma springs are heavy and they were pretty tough for my spring compressor to compress so i could get everything together and ready for tomorrow. if it works out the way i think its gonna ill probably need to lift the rear even higher then it already is. btw the rear has fj springs with fj 1.5 spacer and 1.25 bolt in spacer plate and its only and 1in higher then the front right now.
Sorry I didn't post earlier, but I tried this mod. I got some springs off a 2003 tacoma, and they fit perfectly. Be aware I have the 2WD 4th gen. However, the springs were about an inch taller unsprung, and at least 40% thicker. They lifted my front end about 2 1/2 inches, and the ride is surprisingly smooth for truck springs. Its relatively easy to do, and good for a cheap front end lift.
tacoma vs fj
ok the tacoma springs are monsters next to fj springs. before i started from the ground to the bottom of the fender i measured 37 1/8, after i measured 38 7/8. front end is def. nose high. my rear measures 38 1/2. so looks like ill need some new spring and shocks. now with the tacoma struts and springs and a 3 in spacer your front suspension is def. maxed out. im hoping th efront end settles alil but not much since the springs are brand new and as for the rear bilsteins i hoped to use off the tacoma well thats def a no go the bottom holes off the shock are wayyyy to small.
heres a side by side of the fj spring and tacoma spring
Anyone else done this? I have a buddy with a 06 taco that he's lifting and he'd give me the springs if I wanted them. I plan to do 5100's with them if I got them.
So you basically got a 1 3/4" lift over an fj set up? Would that mean 2+" over stock? Just curious before I put the fj's in
I am dying to hear how much lift these give as well. I have a 2.5" daystar spacer up front right now on stock springs but my brother just got a 2014 TRD tacoma and already ordered a complete lift for it so his springs and shocks are mine if I want them. I just want to know if I will get the same amount of lift as I have now with my spacers. Or if I will need to add a smaller spacer to them.
Also can someone explain the rear shocks? Looks like they have a different bolt on the bottom than our 4runners?
So can anyone confirm the total amount of lift gained from Tacoma TRD coils, over stock 4runner coils? I have a set of TRD O/R coils and struts from my 2011 Tacoma that i sold. im only looking for about 2-2.5" lift in the front and 1" lift in the rear, so if i could pair these front coils with FJ rear coils and some 5100s set at .85 i think i would be set for under 350 bucks. not a bad deal at all.
i have an 03 V8 4x4
I am also looking at this option what total lift do TRD Tacoma springs giving on the front from stock?
you will gain close to 2" of lift by using tacoma trd springs plus they are gonna handle off road conditions so much better. I do suggest using the stock 4600 yellow trd tacoma shocks or better since it's a package deal ya know. I ran tacoma trd springs and struts with a 3" spacer and had no issues clearing 33's no body mount chop was needed. I do suggest upper control arms though.
2" lift dang, well i may give that a shot in a month or so, i have the complete springs and yellow bilstiens sitting in the garage at my folks house with only 17k miles on them or so. and im only wanting to run a 32" tire so this would be perfect
