Toyota - 4Runner . org Forum
Go Back   Toyota - 4Runner . org Forum > Toyota 4Runner Forum > Gallery
LinkBack Thread Tools Rate Thread Display Modes
Old 09-22-2006, 05:38 PM   #1 (permalink)
Registered User
AlexJet's Avatar
ARB Bumper installed
Some of you may already seen my review on ARB Bumper, but I decided to post it here, because I'm getting many questions on the posts and PMs.
2005 4Runner Limited V6
TRUCK of the MONTHJune 2006
Engine: aFe Intake, Safari Snorkel, TRD Cooling, Optima Battery, Painless Wiring.
Interior: Sherwood/Woodview Dash, Lexus GX470 Steering Wheel, Garmin Nuvi760 GPS, Cobra 29 Classic CB, XM Commander, Custom Switch Panel, Custom cargo organizer.
Exterior: Canadian Window Visors, Canadian Hood Deflector, Valor Exhaust Tip, Wilson CB-Antenna.
Suspension: Custom 5”. ARB RD132, 4.56 Nitro Gears
Wheels/Tires: Summer – ProComp Xtreme M/T 315/70-R17 + ProComp 7105, Winter – ProComp All Terrain 35/12.50R17 + AR Baja.
Lighting: Philips H.I.D., Hella Rallye 4000, Hella 500, PIAA 510, KC Baja, ‘06 LED Taillights, ‘06 Projector Headlights.
Off-Roading Equipment: ARB Front Bumper, WARN 9.5xp, WinchLine Trail/Fire synthetic line, WinchLine Aluminum Fairlead, WARN Shackles, Rear Diff Breather, Off-Road Clinometer, Custom Roof Rack, Custom Full Undercarriage Protection: Engine, Transmission, Transfer Case, Fuel Tank and Exhaust Skid Plates, Custom Rock Sliders/Steps, CBI Rear Bumper.[/color]
Coming up:
Write-ups:
My 4Runner Project
4” Custom Lift
Tail Lights LED Project
HID Conversion on 4th Gen.
Surco Safari Rack
ARB Bumper Install
Alex’s Garage SALE
NEW - GARAGE SALE 2
AlexJet is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!
Sponsored Ad   #
Advertisement
Old 09-22-2006, 05:39 PM   #2 (permalink)
Registered User
AlexJet's Avatar
Finally after month of waiting till ARB will develop their bumper I got myself one. Actually I didn't wait till ARB starts delivering the bumper for 4Runner. There were two issues. First, I didn't like the way they make
Coming up:
Write-ups:
My 4Runner Project
4” Custom Lift
Surco Safari Rack
ARB Bumper Install
Alex’s Garage SALE
NEW - GARAGE SALE 2
AlexJet is offline
Old 09-22-2006, 05:40 PM   #3 (permalink)
Registered User
AlexJet's Avatar
Sorry guys, but I didn't take pictures while I was removing the stock bumper.
I do remember the process and if you have any questions just ask.
First you have to remove the lower grille portion from the bumper. The best ways to do it is use a flat screwdriver and gently remove the grille from front and rear at the same time going from the side to the center.
Then remove plugs from fog lights and turn signals.
Now you have to remove the bolts and clips from the inner fender which attaches to the bumper.
After you done this raise the truck and remove all bolts holding the bumper under the truck.
As soon as you will do this, pull the bumper out. It should go easily.
The next step is to unscrew the bolt which holds the reinforcement bar and remove the bar itself.
Last thing you have to do is to remove side brackets which were holding wings of the stock bumper. Note: do not remove the headlight bolt.
Here you can see the truck with stock bumper removed.
Coming up:
Write-ups:
My 4Runner Project
4” Custom Lift
Surco Safari Rack
ARB Bumper Install
Alex’s Garage SALE
NEW - GARAGE SALE 2
AlexJet is offline
Old 09-22-2006, 05:41 PM   #4 (permalink)
Registered User
AlexJet's Avatar
ARB thought about us. They include full hardware package for the installation.
At the time I opened the package, I thought that they bought half of local hardware store. The package includes everything from bolts and nuts to electrical terminals.
First I had to install support brackets. This should eliminate the common problem with ARB bumpers on previous generations. Some earlier bumpers (2nd and 3rd Gen) were just attached to the frame without support brackets and cause breaking under extreme loads while winching.
After it I installed the bumper bracket with reinforcement bar. You can see that it attached to the frame and to support brackets installed earlier.
Coming up:
Write-ups:
My 4Runner Project
4” Custom Lift
Surco Safari Rack
ARB Bumper Install
Alex’s Garage SALE
NEW - GARAGE SALE 2
AlexJet is offline
Old 09-22-2006, 05:41 PM   #5 (permalink)
Registered User
AlexJet's Avatar
The bumper didn't have appropriate side skid plates, so I had to use cable-ties to hold the inner fenders.
Meanwhile the bumper was installed and it was looking great.
Coming up:
Write-ups:
My 4Runner Project
4” Custom Lift
Surco Safari Rack
ARB Bumper Install
Alex’s Garage SALE
NEW - GARAGE SALE 2
AlexJet is offline
Old 09-22-2006, 05:42 PM   #6 (permalink)
Registered User
AlexJet's Avatar
In those two weeks I finished fabricating skid plates and put some more lights on.
Skids (by the way you can see how perfect they align with my engine skid plate):
Side skid view:
Overall view of the bumper:
I have trimmed the inner fender by cutting triangle pieces with some of the inner fender itself.
Here are the pieces I had to trim:
And the rest of the inner fender I screwed to the side skid:
Coming up:
Write-ups:
My 4Runner Project
4” Custom Lift
Surco Safari Rack
ARB Bumper Install
Alex’s Garage SALE
NEW - GARAGE SALE 2
AlexJet is offline
Old 09-22-2006, 05:53 PM   #7 (permalink)
Registered User
AlexJet's Avatar
Here is the side picture. You can see approach angle.
Some people asked me about the instruction on cutting off the piece from the stock bumper and gluing it to ARB.
As I wrote in other post, it's not necessary to do it. There is an another solution.
I took the lower grille portion which I had to unclip when was removing my stock bumper; drill 3 holes in it and then attached it to the frame using 1/8 x 1-1/2 bolts and 1" spacer.
Coming up:
Write-ups:
My 4Runner Project
4” Custom Lift
Surco Safari Rack
ARB Bumper Install
Alex’s Garage SALE
NEW - GARAGE SALE 2
AlexJet is offline
Old 09-22-2006, 05:56 PM   #8 (permalink)
Registered User
AlexJet's Avatar
The project is mainly finished. I need a winch, which will be coming soon.
Coming up:
Write-ups:
My 4Runner Project
4” Custom Lift
Surco Safari Rack
ARB Bumper Install
Alex’s Garage SALE
NEW - GARAGE SALE 2
AlexJet is offline
Old 09-22-2006, 11:10 PM   #9 (permalink)
Registered User
loner's Avatar
That looks DARN good! (Of course, your other mods really help a lot too!)
I'll be installing my combination bar tomorrow. I can't wait.
05 V8 Sport 4WD - Icons, black FJ Cruiser wheels, BFG Muds, ARB bull bar, Gibson exhaust
loner is offline
Old 09-22-2006, 11:33 PM   #10 (permalink)
Registered User
hey buddy!! looks great!
what rear teail guard did u go with!
sadly ive been hittin some trails without u
nothing too serious
very easy stuff as im new
cant wait to meet up and see it in perosn!
cheers!
schwalmy
2003 sport V8
Jaos bull bar
PIAA 525 Aux lights
Led tails
HID lights
Alpine in dash DVD player
Volant CAI
S/S break lines
schwalmy is offline
Old 09-23-2006, 09:00 AM   #11 (permalink)
Registered User
AlexJet's Avatar
nothing too serious
cheers!
schwalmy
Yes, it was a long time since we met last time. Looking forward to hit some trails with you as well...
The rear bumper guard is mine. I'm fabricating it.
By the way, if someone is interested in this bumper guard or any other fab stuff on my 4Runner, let me now. I made most of the metal work on my truck and can fabricate them for you.
James, would you like to meet on Thanksgiving. Next weekend from Thanksgiving I'm going to my friends place. He owns some land, so I might be wheeling there. I'll ask him if he wouldn't mind to have some extra people there.
Coming up:
Write-ups:
My 4Runner Project
4” Custom Lift
Surco Safari Rack
ARB Bumper Install
Alex’s Garage SALE
NEW - GARAGE SALE 2
AlexJet is offline
Old 01-20-2009, 11:09 PM   #12 (permalink)
Registered User
Mike07SE's Avatar
Any chance on fixing the links for the photos in your writeup Alex?
2007 4Runner Sport Edition V6 4X4 - Natural White
Performance: Doug Thorley Long Tube Headers | TRD CAI
Off Road: Daystar Lift | BFG A/T 265/70-17 | Rear Diff Breather Mod
Stereo: 3.5" Tweeter Mod
Exterior: 4300K HID Lows & Fogs
Mike07SE is offline
Old 01-21-2009, 10:06 PM   #13 (permalink)
Registered User
AlexJet's Avatar
Fixed.
Coming up:
Write-ups:
My 4Runner Project
4” Custom Lift
Surco Safari Rack
ARB Bumper Install
Alex’s Garage SALE
NEW - GARAGE SALE 2
AlexJet is offline
Old 01-21-2009, 10:56 PM   #14 (permalink)
American-BADASS
shootmymime's Avatar
Send a message via AIM to shootmymime
it looks a little strange with out a lift, any ideas about a lift?
1996 T4R SR5~218,679 miles~K&N Cold Air Intake~31" Mitchelin AllTirain Tires~ GORHINO-3000 Series Brushguard~Aircraft Flying Lights~Front Hood Protector~Four Window Visors~Pioneer Headunit~MTX Sub~Rockford Fostgate Amp~Thunder Box~All Weather Floor Mats~Driver and Passenger Seat Covers~Two 55 Wat. KC 57 Series Fog Lights~Two MTX Jackhammer Subs~Sylvania Silver Star Head Lights~
http://www.cardomain.com/id/Shootmymime
shootmymime is offline
Old 01-21-2009, 11:07 PM   #15 (permalink)
Registered User
AlexJet's Avatar
All of the images are with OME 3" lift. First pictures with 32" Bridgestone Revos and last ones with 33" GoodYear MTRs.
Coming up:
Write-ups:
My 4Runner Project
4” Custom Lift
Surco Safari Rack
ARB Bumper Install
Alex’s Garage SALE
NEW - GARAGE SALE 2
AlexJet is offline
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.2
